997 : 2004- 60
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Hughb
PostPosted: Fri Jan 24, 2020 11:04 am    Post subject: Silencers, compatability between variants Reply with quote
Got the opportunity to buy some good condition used silencers (part numbers ....3170/3270) off a C4, 2006 but I have a C2, 2003. (part numbers 3168/3268)...(all non GT/turbo)
Two questions:
Will they fit? I presume so, as all the aftermarket replacements fit all the variants with a single offering.
and
Will they work ok? ... or is it a complete no-no because of different back pressures or things like that?
I fully appreciate that the theoretical answer is no, but when you look at the number of third party suppliers selling 'universal' solutions to the non GT/Turbo model range, there must be some wiggle room.
Anyone actually done this or similar?
2003 996 C2 manual 87k
PostPosted: Fri Jan 24, 2020 7:32 pm    Post subject: Reply with quote
I can say the brackets don't fit as the holes are in different places .. if you swapped the brackets over from your old silencers then all you are left with is dimensions .. i would be concerned about the pipe diameter .. if that's the same then technically they would fit .
Get some measurements basically and compare to yours .
Rule of thumb though .. different part numbers mean they ARE different .
Indy Mechanic .
Mallone
PostPosted: Sun Jan 26, 2020 12:06 pm    Post subject: Reply with quote
I know you can fit boxes from a .2 car to a .1 car as that's exactly what I did when I got hold of the Carnewal boxes for mine.
Can't speak to the specific years you mention, but I'd imagine that things would swap over without issue.
Previously: 2000 996 C2, 2004 986 Boxster S
Current: 1999 996 C2
Hughb
PostPosted: Mon Jan 27, 2020 10:42 am    Post subject: Reply with quote
Thanks for comments.
By brackets, deMort, do you mean the two pairs of 'ears' on the silencers themselves...ie that these would have to be removed from the original boxes and welded onto the C4 boxes in place of whats already there? ..a bit fiddly?
Please, deMort, i don't dispute your wisdom one iota, (I am awed at it) but how come the aftermarket suppliers offer 'one size fits all, (C2,C4,C4s) etc' replacements?
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Mon Jan 27, 2020 11:16 am    Post subject: Reply with quote
I fitted new/unused genuine 3.6 C4S boxes to my 3.4.
I just needed to swap the tailpipes as the widebody c4s has them in different location in the bumper, easy swap.
They are apparently slightly "free-er flowing" than the original 3.4 items.
997 boxes will bolt up just fine too. But you will need to chop / weld your old tailpipe attachment to them are they are different.
996 parts cache sell off
Hughb
PostPosted: Mon Jan 27, 2020 11:27 am    Post subject: Reply with quote
Thanks for that wasz ... I was wondering about the tail pipes as well, as i can see they are also a different part number, but was hoping that they were a bumper positioning issue as you confirm.
