997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
PostPosted: Wed Feb 12, 2020 1:18 pm    Post subject: Reply with quote
stucart wrote:
Superb work, really impressed with attention to detail and workmanship. worship
Agree
PostPosted: Wed Feb 12, 2020 3:28 pm    Post subject: Reply with quote
systech1 wrote:
C11BRA wrote:
First road test was at 8pm last night so with mechanical empathy, I was just running everything up to temperature, resetting steering angle sensors etc. Stopping at every service station for a quick check etc. Always a bit of burning off of oils, joint sealant etc. It can be quite smoky but wasn’t too bad. Got followed by the Police for a mile. I thought I was going to get a pull but didn’t.
So. No real performance runs yet. What I did notice is a sweet spot at about 2500 rpm where the sound just peaks with a buzz. Just lovely.
On my second service station stop I connected my temporary vacuum system to operated the 2 gundo valves for the first time. Both worked perfectly. And nice that they are just visible from under the bumper. Oh wow. Even at idle, it was transformed. I set off down the A1 towards home. Under the M25 flyover, I couldn’t resist an idiot blip. Really really nice sound. Not as viscous as the system I’ve just removed, but really deep and just perfect for how I wanted it to be.
All in all, I couldn’t be happier.
The quiet mode will be a blessing on our long Euro trips we hope to enjoy in the coming years and hopefully will pass the track day DB tests with ease. (Although the X pipe possibly makes it louder than stock. I’ve never driven a stock 996 or 997).
The idiot mode will be great for Ace Cafe meets & tunnel hunting with my 13 year old lad.
All I need to do now is figure out how to activate the valves via the GT3 (spoiler button delete) switch pack I installed recently. I already use the suspension & TC off buttons but I have pre-wired the redundant sport button for this very purpose. (My car is non sport). I truly hope I can work out how to use the spare sport signal to operate a relay & then the solenoid to make the exhaust mode operation appear to be factory fitted. Things like that give me a buzz.
DucatirRob, myself and others have used the OEM PSE switch panel via a latching relay (rather than via the ECU) to control the vacuum solenoid as described in detail here....http://911uk.com/viewtopic.php?t=116327&highlight=systech1.
Works very well and remembers the last setting as a bonus
Ah perfect that was the thread I was looking for to post up , I knew some had done it Thumb
C11BRA
PostPosted: Thu Feb 13, 2020 10:52 pm    Post subject: Reply with quote
Thanks guys.
Ok. After a bit of head scratching (thanks to pins 12 & 13 on the switch pack being reversed vs the Porsche wiring diagram) I finally worked out the wiring and with a bypass on the circuit board, I finally got the Sport switch to activate the exhaust valves (GT3 style....kinda).
Road testing tomorrow.
2006 997.1. Project GT3C. C stands for ???
2018 Audi A4 Avant Black Edition.
Ex 996 C2 Man.
Ex Ram Cobra V8.
Ex Series 1 RS Turbo.
C11BRA
PostPosted: Fri Feb 14, 2020 5:42 pm    Post subject: Reply with quote
With valves closed I did a DB test today. Approx 1 metre from the exhaust at 45 degrees.
https://youtu.be/YtSdVreclQE
Maxed out early at 102db. Very happy with that. Hopefully enough to pass 103/105 DB track day tests.
However, in Gundo 2” idiot mode. Well........
https://youtu.be/Pb8cbKhr0n8
Sounds incredible!!!!!
Ex 996 C2 Man.
Ex Ram Cobra V8.
NickHappy
PostPosted: Fri Feb 14, 2020 8:46 pm    Post subject: Reply with quote
Ooohhh - that sounds nice. Pleased with the quality of TopGear??
997 turbo Manual.
996 turbo Manual. ex.
C11BRA
PostPosted: Fri Feb 14, 2020 9:06 pm    Post subject: Reply with quote
Yes. Good value & quality was fantastic. Would highly recommend.
Ex 996 C2 Man.
Ex Ram Cobra V8.
C11BRA
PostPosted: Fri Feb 14, 2020 9:27 pm    Post subject: Reply with quote
Final post on this thread will be when I tweak the pipe outlets with a couple of new joints. These will allow me to remove the tailpipes for occasional polishing.
Thanks for all your comments & kind words throughout this thread. I hope to meet some of you at meets & events. You’ll hear us coming (unless I’m in stealth mode!! Grin )
Ex 996 C2 Man.
Ex Ram Cobra V8.
Goto page Previous  1, 2, 3, 4
Page 4 of 4
