997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Hovis
PostPosted: Sat Jan 18, 2020 9:31 pm    Post subject: Carrera sport wheels on wide body. Reply with quote
Looking to change up the wheels as my Carrera classics are in need of a refurb.
Looking to get some black and with silver rim.
Really like the look of the Carrera Sport but tears are ET67 for c2
My targa 4 is wide body so ET 51.
Spacers the only option for the wheels.
Do Porsche run 15mm?
Might put 5mm on the front and 20mm on the rear.
Any one running this set up?
mark pearce
Approved Trader
PostPosted: Sat Jan 18, 2020 11:25 pm    Post subject: Reply with quote
If you look at the equipment brochure for a Targa 4
The Carrera Sport Alloys , were strangely narrow body fitment with 17mm rear spacers
( from a 997 Gen 1 tequipment brochure)
factory fitted alloys as an option never needed the spacers
Stirlings The Low Mileage Porsche Specialists
mark@stirlings.co.uk
Tel 01736 757755
www.stirlings.co.uk
Passion for Perfection
Why risk the alternative?
NLW73
PostPosted: Sun Jan 19, 2020 11:24 am    Post subject: Reply with quote
Just run hub centric spacers and you will be fine
I have them for my winter wheels on 997 c2s as they are 18s and different off set to the oem set up on 19s
15mm on front and 20mm rear. Sit fine in the arches
first three pics are the fronts. they are Porsche ones with the studs and bolts. you use the oem wheel nuts to bolt them to the hub and then the studs on the spacers go through the wheels and secured with bolts
last two are the rears - they came with bolts to bolt to the hub them use the oem bolts to secure wheel to spacer.
997 C2s Schwarz
 Filesize:  131.62 KB
 Viewed:  693 Time(s)
 Filesize:  103.58 KB
 Viewed:  693 Time(s)
 Filesize:  200.62 KB
 Viewed:  693 Time(s)
 Filesize:  120.25 KB
 Viewed:  693 Time(s)
 Filesize:  122.65 KB
 Viewed:  693 Time(s)
Hovis
PostPosted: Sun Jan 19, 2020 11:53 pm    Post subject: Reply with quote
Thanks.
Strange they had option for spacers from factory and no true wide body fit.
Never ran spacers on a car but know many who have.
Hubcentric all the way but I know it’s been discussed on many forums bolt on or bolt through.
Seems NLSM your running both bolt on stud and bolt on. I see lots of options
monster
PostPosted: Mon Jan 20, 2020 1:32 am    Post subject: Reply with quote
Hovis, Carrera Sport Rears are available in ET50 for the C4/C4S wide body cars as detailed here:
https://www.alloywheelsdirect.net/porsche_alloy_wheels/911_997_gen_1_c4_c4s_alloys/19_porsche_carrera_sport_wheel_1691
Hovis
PostPosted: Mon Jan 20, 2020 7:12 pm    Post subject: Reply with quote
Thanks.
Never knew that and never seen them until now!
I’ll keep and eye out as budget is for 2nd rims with tyres
