997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Jackzi
PostPosted: Thu Jan 16, 2020 4:33 pm    Post subject: 997 C4S Future Proofing Reply with quote
We usually talk about future proofing a 997’s engine. Over and above getting a low temp thermostat (check), having an 06 MY IMS (check), frequently changing oil and using the right thickness (check) and being gentle with a cold engine (check), there isn’t much more I can do (apart from a rebuild). Mine was ‘scoped at purchase and had the all clear – so I’m happy.
Let’s talk about structural bodywork then.
Given how many rusted and corroded 911s I saw before I bought mine, I thought it prudent to have a look underneath to see how things looked.
Off to Classic Heroes it went for an inspection on the ramp.
I’m happy to say that things looked very good indeed, but that didn't mean it was perfect. Small areas of surface corrosion were starting to form in places such as the front and rear chassis legs, in between the wheel arches and wheel housings and at some of the spot welds, etc.
I was advised that this was nothing to worry about, but that if left untreated could become a problem in just a few years time.
Thus, the plan was to remove the plastic, clean everything up underneath and address the rusty bits with chemical rust neutraliser, bring the parts that needed to back to bare metal and treat accordingly, apply anti stone chip product, treat with clear cavity wax and treat all alloy suspension components, nuts and bold with Tectyl ML.
Below are some pictures.
There’s also a video walkthrough right here: https://vimeo.com/385281858
All in all I’m glad I had it done. It’s what DeMort calls the ‘waxoil service' Wink
I'm also really happy with the job Classic Heroes did https://www.classicheroes.co.uk/
Sometimes you have to see your fair share of ***** cars to pledge that your own will never, ever look like that.
997 Carrera 4S
BMW M5 (E39)
Jackzi
PostPosted: Thu Jan 16, 2020 4:42 pm    Post subject: Reply with quote
Here are some pics
997 Carrera 4S
BMW M5 (E39)
 Filesize:  587.87 KB
 Viewed:  1285 Time(s)
 Filesize:  1.75 MB
 Filesize:  1.7 MB
 Filesize:  662.21 KB
 Filesize:  682.59 KB
 Filesize:  604.19 KB
 Filesize:  460.52 KB
 Filesize:  812.36 KB
 Filesize:  413.4 KB
 Filesize:  720.75 KB
Jackzi
PostPosted: Thu Jan 16, 2020 4:45 pm    Post subject: Reply with quote
Looks like some of the pics went missing. Here they are again:
997 Carrera 4S
BMW M5 (E39)
 Filesize:  438.59 KB
 Viewed:  809 Time(s)
 Filesize:  499.86 KB
 Viewed:  809 Time(s)
 Filesize:  442.63 KB
 Viewed:  809 Time(s)
 Filesize:  470.69 KB
 Viewed:  809 Time(s)
 Filesize:  549.8 KB
 Viewed:  809 Time(s)
Jackzi
Some more
997 Carrera 4S
BMW M5 (E39)
Porkaholic
PostPosted: Thu Jan 16, 2020 6:57 pm    Post subject: Reply with quote
Thanks for posting those pics and video Jack. Certainly food for thought on maintaining a great car to a decent level for as long as possible. Interesting to see the relatively small amount of corrosion just starting to manifest itself and nipped in the bud. Costwise it surely must make sense if you can to take these
steps particularly if you plan to keep the car long term. Some nice Beemers too!
2009 997.2 4S manual cab, light mods
2017 Cayenne S
2015 Mini
Volvo 460 GLT (Rally toy, 'The Meatball')
Jam911
PostPosted: Thu Jan 16, 2020 7:32 pm    Post subject: Reply with quote
Good work, well done, do you fancy doing mine ....it looks like lots of work.
I will try to do mine ....
Current '07 997 C4S
Ex '99 2.5 Boxster
997_2_C4S
PostPosted: Thu Jan 16, 2020 7:59 pm    Post subject: Reply with quote
Had mine done too recently. Very reassuring.
diceman
PostPosted: Fri Jan 17, 2020 9:57 am    Post subject: Reply with quote
That's a great service and looks exactly like what I am looking for.
I've been thinking of doing similar myself to my 50K mile 05 C2S but I think I'd need access to a ramp & steam cleaner.
Maybe I could PM you to enquire about the anticipated costs?
2005 997 C2S Manual - Midnight Blue
2003 E46 M3 Manual - Silver
1991 Celica ST185 RC - Grey
Jackzi
PostPosted: Sun Jan 19, 2020 10:58 am    Post subject: Reply with quote
Sure thing diceman. Just send me a message.
I'm not sure I'd go about doing it myself as it took very many hours of work to do it properly.
But certainly worth doing as there's no better maintenance than preventive maintenance where it's a known quantity.
997 Carrera 4S
BMW M5 (E39)
997_2_C4S
PostPosted: Sun Jan 19, 2020 1:28 pm    Post subject: Reply with quote
My 49,000 C4S was £3k to have done
Jackzi
PostPosted: Sun Jan 19, 2020 6:13 pm    Post subject: Reply with quote
Mine was less than that, but every car is different and will need more or less doing depending on condition and who does it/where you have it done.
Consider how much it would cost to 'restore' if the corrosion really gets hold further down the line and it could be a bargain Very Happy
997 Carrera 4S
BMW M5 (E39)
