997 : 2004- 62
996 : 1997-2005 29
Boxster : 1997- 26
Parsley
PostPosted: Tue Jan 14, 2020 12:00 pm    Post subject: Wheel offset help needed Reply with quote
Hi folks, do you know if an 11" rear rim with an et51 offset will fit the rear of a 996 C2.2 (narrow body)
Someone is selling a set of standard 996 wheels but they are 8" and 11"?? I'm just not sure what is what and have read loads. I'm slightly confused if I'm honest. I'm currently non 19" wheels and wanted a standard looking set. Many thanks for any help.
PostPosted: Tue Jan 14, 2020 12:06 pm    Post subject: Reply with quote
This website is Mint for this kind of info:
https://www.willtheyfit.com/
911Time
PostPosted: Tue Jan 14, 2020 12:32 pm    Post subject: Reply with quote
Mark
I'm not a perfectionist - I just want everything done 'Right' Wink
Current: GT Silver 991.1 C4S with a few 'special bits'. Previous Owned: C63 Estate, BMW e92 330d Coupe (700Nm/Custom Exh/Map/BBK/Quaife/Breytons), ML63AMG, Alpina e46 B3S Coupe, Alpina e36 B3 Coupe, Lotus Excel SE, Alfasud Green Cloverleaf Ti, Lancia HPE, Capri 2.0S, Marina 1.8 (don't laugh it was my first road car). Bikes: Suzuki TL1000R and BMW R1100S AC Schnitzer.
911Time
PostPosted: Tue Jan 14, 2020 12:33 pm    Post subject: Reply with quote
As HSC911 said - willtheyfit.com is very good Thumb
I also use Wheel Size.com to establish what the factory fitment and offset is for a vehicle, before considering what changes might be possible.
https://www.wheel-size.com/size/porsche/911/
Just select the model, year, engine size, find your current wheel diameter and then click on the '+' symbol to see the factory front/rear wheel size and offset.
Wheel Size also have a 'Tire Calculator' at the top of the webpage - similar to willtheyfit but a bit more comprehensive with more info and alternative options - saves ages working it all out.
Mark
Dammit
PostPosted: Tue Jan 14, 2020 12:37 pm    Post subject: Reply with quote
I hope so, my new wheels are ET 50 and 11" at the rear, going on a narrow body 996.1.
Parsley
PostPosted: Tue Jan 14, 2020 12:50 pm    Post subject: Reply with quote
Ah, what size tyres are you going for? I'd be interested to hear how they fit!!
Parsley
PostPosted: Tue Jan 14, 2020 12:51 pm    Post subject: Reply with quote
Ok cheers for that I'll look.
Parsley
PostPosted: Tue Jan 14, 2020 12:52 pm    Post subject: Reply with quote
Thanks mate I'll look.
PostPosted: Tue Jan 14, 2020 12:56 pm    Post subject: Reply with quote
No big Dill Thumb
cableguy
Watkins Glen
PostPosted: Tue Jan 14, 2020 1:01 pm    Post subject: Reply with quote
For reference a NB 996.2 GT3 runs 11.0j x 18" rears with an offset of ET63.
The wheels you are looking at with an ET51 will be 12mm closer to the outside arch. I'd wager that 12mm may be a tad too much with the correct size tyres and you may need to tickle (roll) the arches to avoid rubbing. Thumb
C.
Pork!
Parsley
I had a look on willtheyfit but will need to find out the offset of the rear wheels that are on it at the moment. The problem is there are 265/30/19 on the rear but on what I suspect are 11" rims. The rear tyres are so pulled in it looks stupid and gives a very hard ride. I'm wanting to either put a 285 section rear on so it does not look silly (hope they don't catch) or go back to 18" wheels.
911Time
PostPosted: Tue Jan 14, 2020 1:08 pm    Post subject: Reply with quote
Hi Parsley, for your current setup take a look at the link I gave earlier and then you can either use the WheelSize or WillTheyFit calculator.
HTH Smile
Mark
Parsley
PostPosted: Tue Jan 14, 2020 1:34 pm    Post subject: Reply with quote
HTH Smile
Ok cheers will do
Parsley
PostPosted: Tue Jan 14, 2020 2:00 pm    Post subject: Reply with quote
C.
Thanks a million mate, great help.
Stotty
PostPosted: Tue Jan 14, 2020 4:56 pm    Post subject: Reply with quote
Sites like 'will they fit' will only tel you the difference in offset, not if they will actually fit your car.
Standard off sets are pretty conservative, which is why you can easily run a 15mm spacer on a 10" et65.... effectively making it et50.
But an 11" et50 (the equivalent of a 10" et 37) is going to be very tight unless you roll the rear arches - 996.2's arches are rolled, but 996.1's have a c.10mm lip inside the arch. Alternatively, you may be able to run more camber, or run a narrower tyre to stop them rubbing (something like a 275.
2000 996, C2, manual, arctic/metropole, Koni shocks, H&R -30 springs, H&R ARB's, Rennline SS engine mounts, cup wheel, 170k miles. 2018 Touareg RLine Plus
Parsley
PostPosted: Sun Jan 19, 2020 7:24 pm    Post subject: Reply with quote
Thanks very much for your input. I've gone for 997 5 spokes with a 10" rear. I think et was 53 off the top of my head so should fit fine
