997 : 2004- 62
996 : 1997-2005 29
Boxster : 1997- 26
Geezer 911
PostPosted: Tue Jan 14, 2020 9:22 am    Post subject: Drive belt tensioner high pitch squeal Reply with quote
Morning all,
Last October I noticed on a damp morning every time I reversed the car when coming out of my drive I cain hear an excruciating high pitch squeal which lasts for around 5 seconds and sounded like it was coming from drive belt area.
Before Xmas when I took my car to OPC to change my PDK fluid part of the service was to replace air filter and drive belt. When I picked up the car the advisor said the technician said at the the next service as I should consider replacing the the drive belt tensioner as is the where the issue is occuring but at the same token as the drive belt has just been replaced I shouldn’t have this issue for a while.
The squealing has now started happening everyday this week. For anyone else that had experienced this how long did you wait before you replace the part? As mentioned the noise lasts for seconds but at the same time I do not want to knowingly damage the engine etc.
darkhorse
PostPosted: Tue Jan 14, 2020 9:50 am    Post subject: Reply with quote
If the bearing is failing, you should get it replaced asap... only bad things can happen by leaving it in my experience. Not sure why they would send you away with a known dodgy tensioner bearing.
I would get the belt taken off the tensioner and the tensioners current state closely examined.
Windy101
PostPosted: Tue Jan 14, 2020 10:24 am    Post subject: Reply with quote
Is your car a Gen 1 or 2?
There is a thread on here that describes a common problem with the Gen 2 drive belt tensioner and whats involved with its replacement.
P9XX
PostPosted: Tue Jan 14, 2020 11:12 am    Post subject: Reply with quote
@Geezer 911
I'm guessing your car is 997 Gen2 because of the PDK fluid change.
This is the link to deMorts posting regarding Aux belt tensioner failure.
My own postings are here too.
http://911uk.com/viewtopic.php?t=132158
My car is a 40,000 mile, 2008 registered Gen2 ( a very early one then ) and it had a failed tensioner arm and hydraulic tensioner but an OK tensioning roller. It had an original tensioner arm and was replaced by an updated part with a newer part number. I had the whole lot replaced, bolts as well.
Regarding squealing at start up, I noticed it for a second or so a couple of times which led me to check the assembly as per deMorts guide.
I'm guessing earlier models like mine are more prone because I guess newer Gen2s had the modified tensioner arm fitted during manufacture.
As @darkhorse says, check it asap.
2008 997.2 C2S PDK Basalt Black
Geezer 911
PostPosted: Tue Jan 14, 2020 11:13 am    Post subject: Reply with quote
thanks for reply's it is Gen 2 PDK
darkhorse
PostPosted: Tue Jan 14, 2020 11:19 am    Post subject: Reply with quote
On that basis it's not far off a 'dont pass go' issue that needs rectifying immediately if it was my car. Demort posted a very interesting thread on the gen2 tensioner that I managed to find...
here
http://911uk.com/viewtopic.php?t=132158&highlight=tensioner
Geezer 911
PostPosted: Tue Jan 14, 2020 11:29 am    Post subject: Reply with quote
here
Thanks for the quick response. I am going to get this booked in asap.
darkhorse
PostPosted: Tue Jan 14, 2020 11:44 am    Post subject: Reply with quote
Geezer 911 wrote:
here
PostPosted: Tue Jan 14, 2020 7:51 pm    Post subject: Reply with quote
As already mentioned above then get it checked please.
These cars basically don't squeal .. a partially seized tensioner could allow slack in the belt which could cause this .. i would seriously expect the OPC would have seen if there was an issue with the tensioner as these either need replacing or don't ( its either free moving or it isn't ) .. to say there is an issue but then not change it .. hmm
I really don't get that part to be honest .
Info is all in the link .
darkhorse Thumb
Indy Mechanic .
