997 : 2004- 65
Boxster : 1997- 26
Brucey1
PostPosted: Fri Jan 10, 2020 7:22 pm    Post subject: Swapping steering wheel Reply with quote
My car has the four spoke steering wheel I’m thinking of changing it for one of the more modern looking 3 spoke wheels .
Is it an easy enough job to change it over and would it trigger the air bag light ?
kas750
Shanghai
2006 Porsche 911
PostPosted: Fri Jan 10, 2020 7:27 pm    Post subject: Reply with quote
Easy to change and if you disconnect the battery 30 minutes before you disconnect the airbag it won’t trigger a light.
skinny_monkey
PostPosted: Fri Jan 10, 2020 7:50 pm    Post subject: Reply with quote
Key in position 1 before you disconnect battery otherwise it fires off the alarm.
Changed my 4 spoke to a 3. No issues
Les Richards
PostPosted: Fri Jan 10, 2020 8:05 pm    Post subject: Reply with quote
It triggered the air bag light on my 993 when I changed the wheel to a 996 type.
Does anyone know if the air bag wiring is compatible between the two wheels/models?
My service man suggested there could be a mismatch between the models when I asked if he could reset the light (didn't have the car with me at the time to try).
Les Richards
993
Polar Silver
5152 MU
PostPosted: Fri Jan 10, 2020 8:35 pm    Post subject: Reply with quote
If you had the battery disconnected and swapped them over and then had the airbag light on .. with probably a fault code for drivers head airbag then i would guess the resistances of both airbags are different ... car thinks there is a problem as it's not the correct resistance .
Either that or its not fully plugged in .
I don't know the set resistances of each airbag unit but that is the logical conclusion as nothing else could have caused the light to come on .
Indy Mechanic .
