997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
NedHan79
PostPosted: Tue Jan 07, 2020 10:56 pm    Post subject: 997 gt3 brake master cylinder upgrade Reply with quote
Is there any point in opting for the larger 27mm 997 gt3 brake master cylinder? I’m pretty much re-piping the whole car so bleedings not gona be an issue. I’ve found that trw make the part and can be bought from AUTODOC for £76 iirc. Thats if I can figure out how to bypass the registration part that brings up my c2s details.lol.
Any one done this?
The rest of the brake set up is standard btw. Atm at least
#modified996mk1
skinny_monkey
PostPosted: Tue Jan 07, 2020 11:17 pm    Post subject: Reply with quote
Depends what you're looking for. It will (afaik) give you a stiffer pedal / less movement for a given brake pressure.
I think you'll probably need some new pipes made up out of the m/c.
BTW, i've heard of this being done with the 996 gt3 m/c but not the 997 but i could well be wrong. In fact, i have a GT3 M/C waiting to go on (well it's the equivalent TRW, i think it was the same as some Audi)
NedHan79
PostPosted: Wed Jan 08, 2020 6:22 am    Post subject: Reply with quote
On a quick google I get 997 results coming up first. I’ve always found the brakes disappointing so this is the first logical step seeing as I have the car in bits and the rest of the pipes off
#modified996mk1
crash7
PostPosted: Wed Jan 08, 2020 9:55 am    Post subject: Reply with quote
Yes it can be done, as Skinny says you will get shorter pedal travel. - You will need a custom brake pipe made.
Does your car have PSM? If so it wont like the GT3 master cylinder and will constantly be in fault mode.
It can be rectified by adding a brake bias valve to reduce the flow to the rear calipers.
NedHan79
PostPosted: Wed Jan 08, 2020 10:21 am    Post subject: Reply with quote
Hi crash. No psm. Mines an early car so it’s pretty basic. Making a new pipe wouldn’t be any bother at al so I’ll maybe get one and give it a go. This would be the time to do it
#modified996mk1
RXBoxster
PostPosted: Wed Jan 08, 2020 10:29 am    Post subject: Reply with quote
It will just make it harder to press the pedal,
Stuart
2004 Porsche 996 GT3 Mk2
PostPosted: Wed Jan 08, 2020 1:09 pm    Post subject: Reply with quote
I fitted the 997 master cylinder to my 996.2GT3, firmer brake feel, more confidence, easier to H&T. It's a known 'upgrade' for the 996GT3. I bought part number TRW PMN166
skinny_monkey
PostPosted: Wed Jan 08, 2020 1:38 pm    Post subject: Reply with quote
In what way do you find the brakes disappointing? If it's that they feel lifeless / wooden / need a hard shove (all common comments) then the gt3 m/c will make all these things worse.
NXI20
Paul Ricard
PostPosted: Wed Jan 08, 2020 2:29 pm    Post subject: Reply with quote
The MC / brake piston size ratio will be wrong if you're using the standard 4-pot calipers on the front. The bigger master cylinder piston size works OK on the 6-pot calipers (more fluid needed to move all 6 pistons) but I suspect you'll just wind up with a really hard pedal that's difficult to modulate and lacks feel.
Nick
NedHan79
PostPosted: Wed Jan 08, 2020 11:00 pm    Post subject: Reply with quote
All very interesting points. I’ve never had any faith in the brakes but that’s maybe more down to old Tyres and lack of grip.
I had just started to get the hang of heel and toe just before I took the car off the road. Had thought the master cylinder would have helped me get on with it Question
#modified996mk1
Chris_in_the_UK
Estoril
PostPosted: Wed Jan 08, 2020 11:42 pm    Post subject: Reply with quote
Known (good) modification for 6 pot front brakes - done it on my Cayman which has PCCB's.
Better pedal feel and proportionate braking.
2006 Cayman S PCCB's
RXBoxster
PostPosted: Thu Jan 09, 2020 9:41 am    Post subject: Reply with quote
You could always put a bias box in there, and have some properly adjustable brakes Smile
NedHan79
PostPosted: Thu Jan 09, 2020 10:26 am    Post subject: Reply with quote
Think I’ll stick with the gt3 item Very Happy
#modified996mk1
