997 : 2004- 62
996 : 1997-2005 29
Boxster : 1997- 26
Moko
PostPosted: Tue Jan 07, 2020 5:36 pm    Post subject: How Much Brake Fluid Reply with quote
I’ve been getting the tools together for my first brake fluid change as looking on the service notes it’s been two years since it was last done.
I’ve got a Seeley Power Bleeder together with a flare nut wrench and all I need now is some Brake fluid.....but how much and which type should I buy? Looking it seems Dot 4 either comes in 1L or 5L cans so what size is required for a complete change?
Thanks as always for your advice
David
Porsche 996 Carrera 02 Tiptronic Seal Grey
PostPosted: Tue Jan 07, 2020 8:02 pm    Post subject: Reply with quote
Any Dot 4 fluid is fine .. we use Mobil at work .
You want about 1.5 ltrs .
Start at the n/s/r and take out 0.5 of a litre then o/s/r and 0.25 .. o/s/f and 0.25 and finally n/s/f and 0.25.
If you drain out the brake reservoir first you can do 0.25 per corner but as this is just about impossible due to the strainer then above is how i do it .
0.5 on the n/s/r gets the reservoir drained and the lines cleared .. i've proved it when changing racing blue to standard .. that was the amount i got out before it ran clear .
Bleed nipples .. hard to explain but they do seize .. basically you are fine if just one per caliper comes undone .. don't force them to get them undone .. i use the palm of my hand to hit the spanner .. if it seems too tight then i try the other nipple .. go mad with too much force and it can snap ... i'm afraid this part is experience as to whether it will come loose or not so i can't say much to help.
Indy Mechanic .
maldren
PostPosted: Tue Jan 07, 2020 8:38 pm    Post subject: Reply with quote
The nipples are fragile and stick, use a T bar on the nipples so you don't apply a bending load, it will help avoid snapping them.
Also, my usual comment, fit stainless nipples to avoid future problems. Lots of threads here.
Mike
skinny_monkey
PostPosted: Tue Jan 07, 2020 8:52 pm    Post subject: Reply with quote
I normally give mine a little bleed every year, it doesn't need it but mostly to stop the bleed valves from seizing (already had it happen once, don't want to go through that again).
Im overdue actually, good reminder Smile
As above, 2l should be fine
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Jan 07, 2020 8:58 pm    Post subject: Reply with quote
Assuming they undo, is it worth swapping the nipples for stainless steel ones while you are at it?
Shalmaneser
PostPosted: Tue Jan 07, 2020 9:03 pm    Post subject: Reply with quote
That's a good tip, thanks for that.
I always make sure I use a 6 sided deep socket to crack the nipple (sounds painful) then nip it up again so I can use a spanner on it while bleeding.
205 GTI 2.0 16V - BMW E36 M3 Evo - BMW E46 M3 - Porsche 996 C2
Moko
PostPosted: Tue Jan 07, 2020 9:15 pm    Post subject: Reply with quote
Thanks as always guys that’s just the information I needed.
PostPosted: Wed Jan 08, 2020 8:38 pm    Post subject: Reply with quote
I would tend to advise against stainless steel ones .. we used to fit them for a short while but they sheared off worse than standard ones ..
I can't say if it was the type we bought or if there is a problem but i do know stainless steel bolts if not fitted with ally grease won't come undone ..
Exhaust flange studs .. i've done these up then had to remove them .. they don't come undone basically .. new bolts and i had to cut them off .. that's because i didn't use grease .
I'm not keen on using grease on bleed nipples .. hence my thoughts .
Indy Mechanic .
Marky911
PostPosted: Wed Jan 08, 2020 8:48 pm    Post subject: Reply with quote
^^^ Yep as Demort says, I’d stick with genuine Brembo replacements.
I had no end of bother with aftermarket Titanium then Stainless ones. They were done up F/T yet fluid kept weeping from the threads. The profile of the nose was completely different to the genuine ones.
Brake fluid capacity on 996s is 2.7 litres but as long as you get the bulk changed any old stuff will be got next time. After all we should be changing the fluid every 2 years. Thumb
Moko
PostPosted: Thu Jan 09, 2020 6:33 am    Post subject: Reply with quote
I ordered two litres from Eurocarparts as they have 35% off Winter Sale at the moment, and it didn’t work for my little order a 50% off Brakes deal as well for anyone interested.
Hopefully my nipples Smile will undo and my bottom won’t fall off !!!
Guywilko
PostPosted: Thu Jan 09, 2020 8:03 am    Post subject: Reply with quote
I heated the nipples up with a kitchen micro blowtorch before removal. Put a decent ring spanner on and gave each a single tap with a light hammer. They all came out.
Used Titanium nipples, no leaks
Griffter
PostPosted: Fri Jan 10, 2020 7:40 am    Post subject: Reply with quote
When undoing bleed nipples for the first time, I’ll clean them up with a wire brush and pop a bit of release fluid on them and down the hole. Then a few taps with a hammer on the top (straight down the thread, not sideways, and careful not to damage them) to try to shock free any seizure before undoing them. I’m not sure whether this works or is a placebo, but a snug fitting six sided spanner or socket, a bit of tension and then a sharp movement to undo them has normally worked.
I’ve heard of people wrapping the threads in PTFE tape to try to stop them seizing.
Moko
PostPosted: Fri Jan 10, 2020 10:09 am    Post subject: Reply with quote
My brakes were all apparently changed 2 years ago so I’m hoping the bled nipples haven’t seized too hard as the car has always been garaged.
Is it worth putting a dap of copper grease on the nipples when I tighten them back up?
skinny_monkey
PostPosted: Fri Jan 10, 2020 10:59 am    Post subject: Reply with quote
No, copper grease is not well compatible with brake fluid. Red rubber grease if you must. But i don't bother, just make sure the rubber dust caps are in good condition
maldren
PostPosted: Fri Jan 10, 2020 12:00 pm    Post subject: Reply with quote
No, definitely not Copperslip grease because the calipers are alloy and copper promotes corrosion between steel and aluminium. Only use ally grease on aluminium (and alloy) components, including your wheel nuts.
Mike
PostPosted: Fri Jan 10, 2020 8:57 pm    Post subject: Reply with quote
Brakes may have been changed but i doubt the nipples .. if they have then they will come undone with no problem .
No grease whatsoever .. it will contaminate the brake fluid .. i can't say to what degree as its just something that's not done .
In short .. don't force any nipple .. a sharp hit with the palm of the hand on the spanner should undo them .. if too tight then your at the point of they could snap .. so in my case we advise the customer and see if he wants us to try more force with the knowledge it might snap .
Yours will probably be fine but we are covering all bases here to make you aware of possible problems so don't be alarmed .
Indy Mechanic .
