997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
Harvster
PostPosted: Tue Jan 07, 2020 10:37 am    Post subject: 19mm Crows Foot Spanner (Derbyshire) Reply with quote
Hi everyone. My oil pressure sender has gone faulty and i have bought a replacement to fit. I understand a 19mm crows foot spanner is required to get it changed but i do not have one.
I like to do these things myself so would rather borrow the tool (or buy if absolutely necessary) for a weekend if anybody has one local to me?
I am in Derbyshire (South Normanton DE55 2EN)
Thought it was worth a try!
Thank you.
Porsche 911 996 4S 2003
maldren
PostPosted: Tue Jan 07, 2020 10:57 am    Post subject: Reply with quote
I bought a set on Ebay that fit a socket bar, quite cheap and works a treat. You can then use the appropriate length of extension.
Mike
Shalmaneser
PostPosted: Tue Jan 07, 2020 2:23 pm    Post subject: Reply with quote
Where is the best place to get the sender for this? Mine is inop also!
205 GTI 2.0 16V - BMW E36 M3 Evo - BMW E46 M3 - Porsche 996 C2
maldren
PostPosted: Tue Jan 07, 2020 5:45 pm    Post subject: Reply with quote
I bought mine from the local OPC. You can get cheaper on the net but people advised against it and it wasn't too dear.
Do a search on 911UK for the recent thread on replacing the sender.
Mike
Lee997
PostPosted: Tue Jan 07, 2020 7:49 pm    Post subject: Re: 19mm Crows Foot Spanner (Derbyshire) Reply with quote
Thank you.
Just buy on eBay, you’ll only use it once, try to make sure you don’t get the ones with retaining logs on them or you’ll be messing about filling them off, also you will probably have to file / grind the front half so it’s thinner as the nut area you have to get into is quite narrow.
PostPosted: Tue Jan 07, 2020 8:10 pm    Post subject: Reply with quote
Ebay set ..
https://www.ebay.co.uk/itm/SEALEY-S0866-CROWS-FOOT-SPANNER-SET-OPEN-END-3-8-METRIC-10-PIECE-SIEGEN-BRAND/192314595502?hash=item2cc6d7d8ae:g:RwwAAOSwMBlZxkpG
cheap and cheerful although i wouldn't want to use them very often .
Indy Mechanic .
maldren
PostPosted: Tue Jan 07, 2020 8:42 pm    Post subject: Reply with quote
Yes DeMort, that's like the set I bought, probably won't survive a lifetime but they're not tools you use a lot. I didn't need to file them down at all.
Mike
Harvster
PostPosted: Tue Jan 07, 2020 9:32 pm    Post subject: Reply with quote
Thanks for the replies everyone, and deMort once again. I just didn’t want to buy a set knowing I’ll never use them again!
@Shalmaneser - just buy from your local OPC, it was about £60.
Thanks everyone!
AdamD
PostPosted: Tue Jan 07, 2020 10:13 pm    Post subject: Reply with quote
I replaced mine last weekend with a OE sender sourced from 9apart. £62 inc delivery IRC and less hassle than picking up from my local OPC.
Also purchased a cheap set of Silverline crows feet socket extensions to do the job but needed to grind down the 19mm socket in order for it to fit.
Paynewright
PostPosted: Tue Jan 07, 2020 10:44 pm    Post subject: Reply with quote
Would a lambda socket work?
I used one of these on a McPherson strut assembly, with a recessed nut.
PostPosted: Wed Jan 08, 2020 8:32 pm    Post subject: Reply with quote
I'm afraid it needs to be an open ended crows foot .. lambda sockets are 21 mm and have a closed type edge .. you get similar sockets of different sizes but this type is always not open and so wont fit as you can't slide it over the bolt head ... very useful for PASM shocks though .
Yup you will never use them again .. i have a set that i've used twice and i do this for a living lol .
They are cheap though and any option that doesn't involve a garage is usually going to save you money !
Indy Mechanic .
