997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
Rosselder83
PostPosted: Mon Jan 06, 2020 10:09 pm    Post subject: 996 turbo headlight connector Reply with quote
Hi guys, I’m wondering if anyone can point me in the direction of replacement plugs for my headlights, both are in pretty bad shape, the drivers side one having been held in with a self taping screw.
Brilliant.
I’m replacing the headlight trays so Now’s a good time to unpin the old connector and put in a new one but the internet hasn’t turned anything up yet.
Also any clues as to which unpinning tool would work?
P9XX
PostPosted: Mon Jan 06, 2020 10:35 pm    Post subject: Reply with quote
This site has helped a couple of members with replacement connectors.
https://www.ebay.co.uk/str/Auto-Click-UK?rt=nc&_oac=1
2008 997.2 C2S PDK Basalt Black
Marky911
PostPosted: Mon Jan 06, 2020 10:45 pm    Post subject: Reply with quote
Craig covered this on his thread.
Second last post on page 5 Thumb -
http://www.911uk.com/viewtopic.php?p=1391263
Rosselder83
PostPosted: Mon Jan 06, 2020 11:02 pm    Post subject: Reply with quote
Hi mark, appreciate the link. My connectors are a square white type, gives me hope that I can just buy the connectors from Porsche though!
Marky911
PostPosted: Mon Jan 06, 2020 11:12 pm    Post subject: Reply with quote
Ah right, I didn’t think of that, but yes hopefully Porsche can supply your type as they were the best price for Craig’s type.
The link was mainly to show the removal tool that craig found on eBay. Doesn’t look like he’s posted a link though but you get the idea. If you did want to know where to get that I’ll sure he can pop on with a link. Thumb
Rosselder83
PostPosted: Tue Jan 07, 2020 6:31 am    Post subject: Reply with quote
No problem, the removal tool info is super appreciated also.
If I get anywhere with Porsche I’ll post up here.
Rosselder83
PostPosted: Tue Jan 07, 2020 8:53 am    Post subject: Reply with quote
Just spoke to my parts chap and he tells me that Porsche dont list the headlight connectors.
Not great.
Anyone else got any ideas? I guess i could try ringing some breakers and see if they would chop some off a loom for me, pretty doubtful id imagine.
maldren
PostPosted: Tue Jan 07, 2020 9:02 am    Post subject: Reply with quote
While not wishing to upset your parts man, have a look at the parts manual yourself, sorry I don't have it with me or an online link today.
Mike
Rosselder83
PostPosted: Tue Jan 07, 2020 12:58 pm    Post subject: Reply with quote
A valid point.
Unfortunately i had a look and i think hes right, theres no reference to the connector itself, just the looms.
Ill give breakers a try i think.
Thanks to everyone who contributed thumbsup
cobrars
PostPosted: Thu Jan 09, 2020 8:43 am    Post subject: Reply with quote
Hello,
ok, after checking the parts diagram, I too couldn't find a connector block. But after a little more searching I came across these.
https://www.ebay.co.uk/itm/Headlight-Wiring-Harness-Lamp-Xenon-Front-Connector-Fits-Porsche-Cayenne-03-06/352837790552?hash=item5226c56b58:g:MS4AAOSwUqVdkMZi
Listed for the cayenne, but the block looks identical to me.... Could buy these conversion cables and swap the blocks maybe ???
Hope this helps, good luck thumbsup
Current : Porsche 911 996 C2 Manual With Full Hartech Engine & Gearbox Rebuild
Current : VW Golf 25th Anniversary No 1398
Previous : TVR Cerbera 4.5
Car Thread - http://911uk.com/viewtopic.php?t=118834&highlight=
Rosselder83
PostPosted: Thu Jan 09, 2020 8:47 am    Post subject: Reply with quote
Hi Cobrars,
I too had come across the revelation but on closer inspection the clips that actually clip into the 996 headlight tray appear to be slightly different.
Im half tempted to buy one and see if i can make it work because ive had no luck anywhere else.
The part number of the connector is 999.650.479.40, the chap that runs the ebay store above was a great help but he had a search and said he couldnt get the connector itself.
A chap on ebay said he would sell me a complete front end wiring loom for a 997 which appears to have the same connectors, but £100 for two connectors doesnt fill me with great joy thumbsup
cobrars
PostPosted: Thu Jan 09, 2020 9:10 am    Post subject: Reply with quote
It would seem they are also used on a VW Touareg.
VW part number is : 1J0973837
(Which seems it might be for the opposite end plug 'black one')
Now these are used, but seem pretty decent if they had a good clean
https://www.ebay.co.uk/itm/VW-TOUAREG-3-0-V6-TDI-ORIGINAL-CONNECTOR-CONTACT-PLUG-PIN-1J0973837/223496821567?hash=item340972db3f:g:6C4AAOSwfHBcmStk
https://www.ebay.co.uk/itm/VW-TOUAREG-2003-06-HEADLIGHT-CONNECTOR-CONTACT-PLUG/293228965860?hash=item4445ceefe4:g:k8UAAOSwWspdfNOv
The second link has 2 in stock so if you were to buy both you'd probably get them a bit cheaper ??? maybe £20 the pair ???
I'd say worth a try at that price.... hell of a lot better than £100!! Thumb
