997 : 2004- 65
Boxster : 1997- 26
Stoddy
PostPosted: Wed Jan 08, 2020 8:08 pm    Post subject: Reply with quote
Ok, I’ll get the wheels off tomorrow too. Thanks for the help gents.
Stoddy
The world is flat
2005 997.1 3.6 (Rufus the Red)
2002 996 3.6 C2 (Henry) For sale.
Restoring THE COLONEL, 1973 914.
X 944 S2 Cab (Miller)
X 3.2 Carrera (Gordon)
X 3.4 Cayman (George)
Stoddy
PostPosted: Wed Jan 08, 2020 10:30 pm    Post subject: Reply with quote
27.5 inches from floor to wheel arch, travelling through the wheel badge, both sides.
I’ll whip the wheels off tomorrow and check the legs.
Stoddy. Dont know
The world is flat
P9XX
PostPosted: Wed Jan 08, 2020 11:43 pm    Post subject: Reply with quote
Using a block of wood and a hammer on the raised threads, is it possible to CAREFULLY tap the nut and threads back down ? If yes, then top mount is N/G.
2008 997.2 C2S PDK Basalt Black
Stoddy
PostPosted: Thu Jan 09, 2020 11:02 am    Post subject: Reply with quote
Just tried that, no movement at all. Hit it with a wooden mallet and also a large hammer with some wood between.
Obviously I was suddenly aware I was taking a hammer to a nice red Porsche, so was very careful as well!
PC
Stoddy.
The world is flat
PostPosted: Thu Jan 09, 2020 7:09 pm    Post subject: Reply with quote
I see what P9XX is getting at .. if you jack the car up that side so the wheel is off the ground then if the top strut mount is knackered then the threads will drop down .. or you can again hit it to see if they go down.
If the above makes no difference then its possible it has the wrong top strut mount fitted which in this case as you have no problems then you wouldn't worry about .
What is really frustrating for me .. it's a 10 min job to have a look and say what's wrong or if its fine and don't worry ...
Not being able to see the car .. hmm .. annoying to say the least ... either i need to move further north or people need to move to Brighton Floor
Indy Mechanic .
Stoddy
PostPosted: Thu Jan 09, 2020 8:52 pm    Post subject: Reply with quote
No Brighton’s lush, though I never really thought of the Wye Valley being North of much! Floor
Here’s a few pics of the near side/ sticky up suspension leg.
Please excuse the road dirt, I’d just got back and it was beginning to rain!
Stoddy worship
The world is flat
 Filesize:  159.11 KB
 Viewed:  546 Time(s)
Stoddy
PostPosted: Thu Jan 09, 2020 8:53 pm    Post subject: Reply with quote
Pic
The world is flat
 Filesize:  139.34 KB
 Viewed:  544 Time(s)
Stoddy
PostPosted: Thu Jan 09, 2020 8:54 pm    Post subject: Reply with quote
Pic
The world is flat
 Filesize:  143.87 KB
 Viewed:  542 Time(s)
Stoddy
PostPosted: Thu Jan 09, 2020 8:55 pm    Post subject: Reply with quote
Pic
The world is flat
 Filesize:  92.38 KB
 Viewed:  540 Time(s)
Stoddy
PostPosted: Thu Jan 09, 2020 8:56 pm    Post subject: Reply with quote
Pic
The world is flat
 Filesize:  132.57 KB
 Viewed:  538 Time(s)
Stoddy
PostPosted: Thu Jan 09, 2020 8:57 pm    Post subject: Reply with quote
This is the off side.
The world is flat
 Filesize:  98.95 KB
 Viewed:  534 Time(s)
P9XX
PostPosted: Thu Jan 09, 2020 10:25 pm    Post subject: Reply with quote
Firstly, I must apologise for asking you to hit your car with a hammer albeit carefully. It was getting late.
Thanks for the photos. I've zoomed into 2 of them, nearside and the one offside and joined them together.
I can clearly see the large domed washer, No 6 in the parts diagram.
I've highlighted part of its edge in yellow.
Both top mounts look about equally "weathered" to me and look like they're probably the originals fitted to the car. The tops are also similarly "weathered" from your earlier photos.
I think the lip of the washer is about level with the top coil of the spring on the nearside.
The offside looks subtly different although the angle of the photos is not quite the same. It looks like the lip is close to the 2nd coil.
I think this may explain why the threaded end of your nearside damper rod has apparently moved upwards by a few millimetres. I don't think it will move up any further because the large domed washer underneath is limiting the movement.
As DeMort says, difficult to tell without seeing the car or in my case, without taking it apart to have a look.
 Filesize:  75.88 KB
 Viewed:  515 Time(s)
Stoddy
PostPosted: Thu Jan 09, 2020 11:20 pm    Post subject: Reply with quote
Blimey, that’s pretty impressive observation.
So forgive my ignorance, why would that be so? And will it need sorting out, is it dangerous?
Thanks so much for taking the time.
Stoddy. worship
The world is flat
P9XX
PostPosted: Fri Jan 10, 2020 7:21 pm    Post subject: Reply with quote
The following is a photo of my Top Mount. I took a couple of shots this morning and this is the best I got.
Taken with a cheap endoscope attached to the smartphone, so that's how I got inside the coil spring.
I've marked the relevant bits with colour :
Yellow is the domed washer (No.6)
Cyan is the part of the top mount bolted to the body (No.3)
Green is the Inner Sleeve of the top mount (No.3)
Red is the top coil of the spring.
The gap between Cyan and Green is where I believe the rubber bearing is situated.
The only way I can see your Damper Rod and the upper domed washer moving upwards is if the yellow marked washer is resting on the cyan part of the top mount.
I believe these two domed washers (No.6) are a safety feature to prevent the damper rod coming out of the Top Mount in the event the rubber bearing failing.
Top mount failure is not unknown, even on a Porsche.
I've also drawn a schematic of what I believe has happened, colour coded the same as the photo above.
This is only a schematic and may not be 100% accurate.
Searching on the web for other images, I found this for a 996, so not necessarily absolutely identical to a 997.
https://www.renntech.org/topic/40035-carrera-4-suspension-top-mounts/
Whilst these parts do not "move" whilst driving, every bump, pothole or sunken drain cover will have the force of the damper transferred into the rubber bearing in the top mount.
Finally, if it were mine, I would take the car to my local Porsche Independent Specialist (someone like DeMort) to let them inspect it.
All of this is my take on your photos and of course, I could be totally wrong.
Hoping all goes well with this and do let us know the outcome.
Best Regards...…..Stewart
PostPosted: Fri Jan 10, 2020 7:45 pm    Post subject: Reply with quote
P9XX worship
Very impressive and an outstanding effort to come to a solution ..
The washers no.6 are the failsafe to stop a separated top mount bush from having the shock either enter the bonnet or come out the base when airborne shall we say Smile
I had a close look at the comparison pictures and it does seem that one base washer is higher than the other side , clever call to put them side to side.
Couple of points i don't get though .. i've never seen a separated top mount to this degree .. there are no knocking noises which i would fully expect ..
Finally .. how can the road height measurements be the same each side when if this has failed one side will be lower than the other ..
Bemused by the above but fully with P9XX here .. top strut mount failure .
Logically if you jack it up the shock should move downwards.
Indy Mechanic .
Stoddy
PostPosted: Fri Jan 10, 2020 8:50 pm    Post subject: Reply with quote
Sirs, you are legendary. I’ll take the car in tomorrow for a first hand look by an indie (if they’re open) but I really appreciate your attention to detail, it’s heartwarming being part of this forum, I feel like I’m in safe hands and we've never even met! .........yet.
Thank you so much.
I’ll of course keep you updated with any developments. worship worship
Stoddy. thumbsup thumbsup
Meanwhile, the picture shows a hopeful cure in process of a very leaky drivers door.
The world is flat
 Filesize:  90.46 KB
 Viewed:  346 Time(s)
PostPosted: Fri Jan 10, 2020 9:03 pm    Post subject: Reply with quote
Floor a door membrane seal split .. welcome to my world !!!!
That's old age though .. which happens to all of us .. sigh !
Indy Mechanic .
Stoddy
PostPosted: Fri Jan 10, 2020 9:07 pm    Post subject: Reply with quote
It’s the newest car I’ve ever owned! Grin
The world is flat
Stoddy
PostPosted: Thu Jan 16, 2020 6:16 pm    Post subject: Reply with quote
So here’s what CG found straight away, (obviously with the advantage of seeing it first hand)
Bent top mount due to excessive upward force, ie, probably a sizeable pot hole!
Quite a few other things underneath are to be replaced too, including some freshly skimmed discs which to me just looked like new ones, and not the “below Porsche’s minimum thickness required” So thanks to the garage (non Porsche) which I bought him from. nooo
I’ll update when THE DUKE is finished at CG.
What a nice couple of blokes they are too!
Stoddy thumbsup
The world is flat
 Filesize:  507.02 KB
 Viewed:  200 Time(s)
Stoddy
PostPosted: Thu Jan 16, 2020 6:17 pm    Post subject: Reply with quote
O/S
The world is flat
 Filesize:  381.56 KB
 Viewed:  197 Time(s)
Page 2 of 3
