997 : 2004- 60
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayenne : 2003- 7
SD99
PostPosted: Mon Jan 06, 2020 12:47 pm    Post subject: Brake pads - 957 Turbo part numbers Reply with quote
You would think it would be easy but i`m when checking out Eurocarparts or similar i`m faced with a number of different Textar pad options.
Assume Textar are the OEM supplier but does anyone know what the Textar part numbers are for the fronts and rears?
Billy Bumpsteer
PostPosted: Mon Jan 06, 2020 1:13 pm    Post subject: Reply with quote
Depends on the cars options, cant you put your reg number into their system?
SD99
PostPosted: Mon Jan 06, 2020 8:42 pm    Post subject: Reply with quote
Tried that first but realise that eurocarparts are listing the std Cayenne, turbo and turbo S al for my car. Still. It sure what the part number is but worked out which ones to go for based on the rotor size.
Billy Bumpsteer
PostPosted: Tue Jan 07, 2020 8:43 am    Post subject: Reply with quote
Whats your VIN?
Matrixxxx
PostPosted: Tue Jan 07, 2020 11:58 am    Post subject: Reply with quote
here is a good site to find part numbers etc
https://www.deroure.com/diagrams.asp?TBL=4705&MAK=3&MDL=34&SMA=0&SMO=0&ST=&SC=0
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
