997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
Stoddy
PostPosted: Sat Jan 04, 2020 11:10 pm    Post subject: Rusty manifolds Reply with quote
Hi, are these manifolds about to die?
They look like they are!?
Cheers,
Stoddy Dont know
The world is flat
2005 997.1 3.6 (Rufus the Red)
2002 996 3.6 C2 (Henry) For sale.
Restoring THE COLONEL, 1973 914.
X 944 S2 Cab (Miller)
X 3.2 Carrera (Gordon)
X 3.4 Cayman (George)
 Filesize:  104.37 KB
 Viewed:  836 Time(s)
jl-c
PostPosted: Sat Jan 04, 2020 11:19 pm    Post subject: Reply with quote
Manifold bolts and silencer support bolts, yes. Manifolds themselves are probably good for some time yet. Be easier to tell when bolts are out/removed.
berni29
Watkins Glen
PostPosted: Sat Jan 04, 2020 11:34 pm    Post subject: Reply with quote
Hi
Nice to see some of the features of the 993 and previous incarnations carried through to the 997 (and probably later).
There are many threads about removing the manifold studs. I did it myself on my 993, and it is one of the few jobs I would rather leave to a trusted indie, having first worked out a treatment plan and discussing exactly what they will do if and when the studs break. More when than if in my opinion.
Maybe 997's are easier than those that have gone before in this respect.
All the best
Berni
993 C2 Tip 1994 187k miles. Black and Grey. M029 & Bilstein HD's, Elephant Racing RS bushes F&R, RS mounts, strengthened engine carrier, 100 cell cat inserts, HID's. Solid steering arms mod, top of the engine rebuilt, mapped by Wayne, suspension set up by Chris.
kurlykris
PostPosted: Sun Jan 05, 2020 12:04 am    Post subject: Reply with quote
Your manifolds will probably be fine after a good wire brushing, the manifold bolts are a known issue on 996/997 unfortunautely, don`t touch them until you have to as they will more than likely have to be drilled out to replace them Hand
A job best left to an indy who knows the procedure and will do it far less painfully than you will be able to Thumb
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
Stoddy
PostPosted: Sun Jan 05, 2020 12:08 am    Post subject: Reply with quote
Cheers Gents,
I guess I’ll leave it to the pros!
Better to replace sooner rather than later I reckon!
Stoddy thumbsup
The world is flat
FZP
Estoril
PostPosted: Sun Jan 05, 2020 4:30 am    Post subject: Reply with quote
Leave them alone until they start blowing. They look normal with plenty of life left.
freshy
PostPosted: Sun Jan 05, 2020 6:25 am    Post subject: Reply with quote
Mine have looked like that since I bought it 3.5yrs ago, not planning on touching the manifold until it starts to blow and will be dealt with by an indy.
2005 996 'C4S Plus' Cab Manual in Atlas Grey X51
Stoddy
PostPosted: Sun Jan 05, 2020 9:43 am    Post subject: Reply with quote
Ok, great.
Good to know it’s not abnormal.
Many thanks,
Stoddy. thumbsup
The world is flat
PostPosted: Sun Jan 05, 2020 7:12 pm    Post subject: Reply with quote
Can i just add my voice to the above .. DON'T touch them until there is a problem such as an exhaust leak .. they can and do go on for years and years looking like this !
Flange bolts corroded then fair enough .. change them .. leave the manifold ones along though .
Indy Mechanic .
Stoddy
PostPosted: Sun Jan 05, 2020 11:24 pm    Post subject: Reply with quote
Thanks man, appreciate that. thumbsup
The world is flat
rickprice
PostPosted: Mon Jan 06, 2020 12:15 pm    Post subject: Reply with quote
If you have a warrantee, these are covered (mine were), so they should be good for 100k miles.
They are quite pricey to replace so if you have the option and are convinced they are about to fail, might be worth buying a warrantee and getting Porsche to do? This would be reliant upon you passing the 111 check (presumably they will look at these) and then at some stage your OPC agreeing they need changing. Blowing is an MoT failure, which is when I got mine done.
Of course if you take the punt and they don’t fail, you’ve lost a grand in warrantee.
Rich
Dagerous
PostPosted: Mon Jan 06, 2020 1:52 pm    Post subject: Reply with quote
They look just like mine did before I swapped them for some new tubular stainless items. As has been mentioned 6 of the 12 manifold studs snapped trying to remove them but thankfully the car was with my trusted Indie as I had expected this to be the case. They called out a local specialist to drill the remainder out then fitted the new manifolds with the TDF / Poppopbangbang titanium studs & K-nuts. A bit overkill perhaps but I just couldn't bear looking up under my car and seeing that rusted mess on show...
I know. I should get out more!
Stoddy
PostPosted: Mon Jan 06, 2020 4:00 pm    Post subject: Reply with quote
Thanks for the advice and input.
I think I’ll leave them for now and get them sorted as and when a problem occurs.
Great stuff. Thanks!
worship
The world is flat
