997 : 2004- 60
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
cvega
PostPosted: Sat Jan 04, 2020 9:28 pm    Post subject: Noisy differential / gearbox Reply with quote
Today during my healthcheck at centre gravity, when doing some routine bearing checks Chris discovered a noise when free spinning the rear wheel by hand. Not grinding or laboured kind, but more like a gear ticking. Just another item to add to a long list.. what could it be?
That obviously made me think - time for a LSD Very Happy
Who's the go to guy to fix / rebuild transmission / diff and/or add LSD?
2003 996 C2 (Ohlins R&T suspension, Toyosport/Spyder exhaust)
TurboRob
PostPosted: Sat Jan 04, 2020 10:05 pm    Post subject: Reply with quote
Wheel bearing?
996.2 C2
cvega
PostPosted: Sat Jan 04, 2020 10:14 pm    Post subject: Reply with quote
I'd expect it to be a grinding noise, rather than ticking..
DarthFaker
PostPosted: Sun Jan 05, 2020 1:41 pm    Post subject: Reply with quote
In my experience wheel bearings make all sorts of weird and wonderful noises, whopping, ticking, grinding, Frank Sinatra crooning..
Dont discount it being the bearing.
cheshire911
Estoril
PostPosted: Sun Jan 05, 2020 2:57 pm    Post subject: Re: Noisy differential / gearbox Reply with quote
The answer to your last question is Mike at Sports & Classic.
Does a lot of gearbox and transmission strip and rebuilds for all sorts of problems on these cars.
996 2002 X50 Turbo Manual
cvega
PostPosted: Sun Jan 05, 2020 3:57 pm    Post subject: Reply with quote
Thanks, I'll give him a bell.
Perhaps it is the bearing, I guess without someone in the know listening to it I won't know. It sounds like gears grinding very softly against each other.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Jan 05, 2020 5:44 pm    Post subject: Reply with quote
If possible, I'd get the back end up in the air and use a plastic tube with one end stuck against my ear to try to hear where the source of the noise is.
PostPosted: Sun Jan 05, 2020 6:45 pm    Post subject: Reply with quote
Yeah as MC says. Could be a CV joint.
