997 : 2004- 63
Boxster : 1997- 26
Slippydiff
PostPosted: Sat Jan 04, 2020 12:34 pm    Post subject: OE 3.4 Cayman/Boxster 987 R/S Front discs 318mm X 28mm Reply with quote
A pair of OE front discs removed from my Cayman R.
These were removed due to the commonly found corrosion on their inner faces. They've since been skimmed by the good folk at BG Developments :
http://www.bgdevelopments.co.uk/
To ensure they run true, both mounting faces have also been ground perpendicular to the disc wear faces.
New the discs are 28mm thick and 318mm in diameter, having been ground one disc is now just under 27mm thick, whilst the other is just over 27mm.
£40 pair.
Due to their weight, these can't really be economically posted or sent by courier. So they'll need to be collected (or if practical I'll meet up with the buyer to deliver them)
Any enquiries please email me at : henmarcu@gmail.com. Please do NOT PM me.
