997 : 2004- 60
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
jond58
PostPosted: Fri Jan 03, 2020 9:37 pm    Post subject: Gear lever self centring Reply with quote
Whilst I was under the car with the exhausts I cleaned the gearbox linkage parts, oiled and greased. Ever since I fitted the 997 short shift kit it’s not self centred very well. Feels like the lever is under tension. I assume that when it’s gone back together in the car one or both cables are too tight? It feels stiffer going left ie first, second, reverse. Would I be right in thinking if I take the centre console off, lock the lever with the tool and back the left hand end thing a turn or two this would help? Or do the cables push and pull like a twin throttle cable set up? I can I guess just keep adjusting things till I’m happy but I’d rather accept some advice and commence in the right direction!
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
elwyn
PostPosted: Sat Jan 04, 2020 8:22 am    Post subject: Reply with quote
hi ,did this before xmas, the locking tool wont fit short shift , just center your gear stick in neutral , and pop your cables in as they fall on the slots, make sure car in neutral before you start job, best mod i ever did, makes huge difference to driving experience . regards elwyn Thumb
jond58
PostPosted: Sat Jan 04, 2020 5:50 pm    Post subject: Reply with quote
The tool does fit a 997 short shift in fact it’s supplied with one. It won’t the after market bm ones I know. Anyway I’ll have a twirl of the adjusters. It’s not undriveable it just wants a tweak I think
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sat Jan 04, 2020 6:09 pm    Post subject: Reply with quote
There are four things that can be stiff.
The mechanism in the gearbox
The cable
The gearlever bushing in the housing
The fitting which connects to the cable / translates left right on the lever to forwards backwards on the cable.
I would start by marking the cable end at the housing end and disconnect the left/right cable. Then move the lever to see if it is stiff, if it is then investigate the lever mounting in the housing. If it moves freely then reconnect and disconnect the cable end at the gearbox. The lever should move VERY freely with the cable disconnected at either end.
PostPosted: Sat Jan 04, 2020 6:50 pm    Post subject: Reply with quote
Yeah
DarthFaker
PostPosted: Sun Jan 05, 2020 1:44 pm    Post subject: Reply with quote
Sorry to hijack a thread, I had a 986 with a 5 speed, then changed to the 996 6 speed.
My 996 has about a 50% shorter throw is that normal? Or has this mod already been performed?
PostPosted: Sun Jan 05, 2020 6:44 pm    Post subject: Reply with quote
Lift the gaiter up and have a look.
