997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
waynew
PostPosted: Wed Jan 01, 2020 5:31 pm    Post subject: Noise when braking Reply with quote
I have started to notice a kind of throbbing noise from the rear when braking in my C4S.
It sounds a bit like a wheel bearing worn in tone, but it only happens when I brake. Any ideas?
Only had the car for 3k miles, not sure when the pads and discs were last changed, but the pad material looks thick enough.
Wayne
Wayne
996 C4S - Tip
Back to Porsche after 3 years with Aston.
Now to drive and not to look at..
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Wed Jan 01, 2020 11:23 pm    Post subject: Reply with quote
What sort of shape are the rear discs in, bearing in mind that the inside surface is probably a lot worse than the outside...?
cvega
PostPosted: Thu Jan 02, 2020 9:50 am    Post subject: Reply with quote
Usually it's the passenger shitting themselves.. but i think that's not the case here
2003 996 C2 (Ohlins R&T suspension, Toyosport/Spyder exhaust)
waynew
PostPosted: Thu Jan 02, 2020 2:56 pm    Post subject: Reply with quote
Having a closer look they are showing quite a lip on the outer edge, cant see the inner yet but the outer is looking worn
Wayne
996 C4S - Tip
