997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Cayenne : 2003- 4
Shalmaneser
PostPosted: Mon Jan 06, 2020 9:55 am    Post subject: Reply with quote
If you have a multimeter things become a lot easier and simpler, but basically there are five wires coming from the phono leads. There is one common ground, and the other four wires are front left/back left/front right/back right.
I jumped the leads at the large connector by pushing some resistor wire down the crimp housing and wrapping in electrical tape (alsong with the unused phono leads) which was simple and easy. If I have any issues I'll go back and solder or crimp but it appears to have worked well.
In other general 996 news my trip computer tells me I've done 1000 miles after a trip to South Wales this weekend for a wedding.
Car was great on the motorway, although the back boxes are noisy when accelerating they are pretty quiet when cruising which is a good result. Out of interest did 27mpg including driving in and out of London and around South Wales which I think is pretty reasonable!
After thrashing the car about in Wales I'm more and more happy with the exhaust, sounds simply fantastic when you're on it, and the handling is spot on.
Only criticism is that the car does feel very crashy over expansion joints on the motorway or poor road surface. Is this common with other 996's or does it point to possibly tired dampers?
205 GTI 2.0 16V - BMW E36 M3 Evo - BMW E46 M3 - Porsche 996 C2
maldren
PostPosted: Mon Jan 06, 2020 1:01 pm    Post subject: Reply with quote
If you mean that section on the M25 near junction 10, yes it's probably a common problem, it's awful with Ohlins and their hard springs!
Mike
Dagerous
PostPosted: Mon Jan 06, 2020 2:06 pm    Post subject: Reply with quote
Haha! So glad it's not just me then Maldren! I had my (Ohlins equipped) C2 on that stretch of the M25 after New Year and dear god it was unpleasant! Everywhere else the Ohlins was fine (Not plush... not comfortable but fine) but on that ridged concrete of the m25!? Sheesh....
Oh and I too used to have an E36 Evo (In Techno Violet). Had it for about 10 years and loved it's analogue / you-get-yourself-into-trouble-and-you're-on-your-own nature. Great car but now I've had a couple of 911's I don't think I'd ever go back to it or probably any M3.
Shalmaneser
PostPosted: Mon Jan 06, 2020 4:29 pm    Post subject: Reply with quote
The ride is actually pretty good on standard (non-M030) suspension but it just seems like it's not very good under high speed impacts.
I know the (squeaky!) coffin arms need replacing - this is next on the to do list - so hopefully that will improve things somewhat and give me a good opportunity to check everything down there more closely.
Dagerous - I'm jealous - techno violet is my favourite E36 M3 colour! Really looks ace.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Jan 06, 2020 5:16 pm    Post subject: Reply with quote
The spring rates are pretty high even for non M030... the rear ones are firmer than the front as they have to support the engine weight, so the front generally feels more supple than the rear.
Shalmaneser
PostPosted: Wed Jan 15, 2020 3:28 pm    Post subject: Reply with quote
Small post xmas update.
Having done 1200 miles in the last coupe of months I thought the car deserved a small xmas present:
I did say a small present. It turns out one of those is the perfect size to fit to your airbox to blank off the helmholtz resonator:
It is indeed a perfect fit. This supposedly frees up a bit more of an induction bark which is a nice thing to have and cheap and very easy to reverse mod! I've got a spare if anyone wants it...
I'll eventually get a 45 degree silicone hose to replace the existing OE part. You need a 80mm-90mm reducing bend according to my measurements:
But for now the standard part is back on.
I've also got myself a spare headlight to practice fitting a projector from an e90/91/92 which are readily available online secondhand on Ebay:
As good as the projector group buy look I'm a product designer with access to CAD and a 3D printer I can't resist a project like this. It's going pretty smoothly so far, I'm at the point where I need to buy a set of headlights for the actual build. If anyone has any getting dusty in a corner please let me know!
All I need to do now is get a plastic metallised shroud for the ugly bits of the projector and figure out how to incorporate sidelights. I'm fighting the temptation to add some LED halos...
maldren
PostPosted: Wed Jan 15, 2020 4:06 pm    Post subject: Reply with quote
Do you have any pics and dimensions of the E90 projector unit to see whether it would be an easy fit into a facelifted car? Are these E9* cars all fitted with Xenon lights or are the base models halogen?
thanks
Mike
Mike
Shalmaneser
PostPosted: Wed Jan 15, 2020 4:21 pm    Post subject: Reply with quote
I reckon these projectors would be a fair bit too big for the litronics. They're a 3" lens whereas I think the litronics is a 2.5" lens.
As far as I can see the litronics uses a halogen bulb below the projector for the flash (as per a lot of BMWs) and there isn't much space at all around the e9x projector in the 996 housing for squeezing that in.
Xenons were an option on e9x models but were fairly common and a lot are being broken at the moment. The same module is also used extensively on Audis, Jags, Merc you name it.
I just did some searches on ebay for "xenon lens" and a lot came up:
https://www.ebay.co.uk/sch/44240/i.html?_from=R40&_nkw=xenon+lens&LH_ItemCondition=4
Here's one for example:
https://www.ebay.co.uk/itm/BMW-E92-E93-Coupe-bi-xenon-headlamp-headlight-lens-projector-projektor-linse-UK/143360748640?epid=2211200983&hash=item2160f76c60%3Ag%3AZIkAAOSwT1tdXBzb&LH_ItemCondition=4
berni29
Watkins Glen
PostPosted: Wed Jan 15, 2020 5:04 pm    Post subject: Reply with quote
Hi
Great car and am enjoying reading about your updates. I like how the cars are getting more and more "grown up" as it were. The 996 should keep you happy for a while, unless you just have to have more grunt.
I tinker with my 993 all the time, and its enough car for me.
All the best
Berni
993 C2 Tip 1994 187k miles. Black and Grey. M029 & Bilstein HD's, Elephant Racing RS bushes F&R, RS mounts, strengthened engine carrier, 100 cell cat inserts, HID's. Solid steering arms mod, top of the engine rebuilt, mapped by Wayne, suspension set up by Chris.
maldren
PostPosted: Wed Jan 15, 2020 6:33 pm    Post subject: Reply with quote
The facelift Xenons are 3" dia and look similar to the e9* units. There are also some well priced Sinolyn units from China on Ebay but it's hard to identify the best solution, they have a BMW type units as well as a Hella replacement.
However, like the Retrofitlab lights, they don't have the option to switch from RHD for continental use.
Mike
Shalmaneser
PostPosted: Wed Jan 15, 2020 7:34 pm    Post subject: Reply with quote
Maldren - I'll take some pics and measurements tomorrow for you. Note however that these modules don't have the ability to swap between rhd and lhd as far as I can see.
Berni - thanks for your kind words. It's funny that while you're right, I am growing up through the cars - I'd say the 996 definitely feels closer to the 205 than the e46 m3, especially with the rs engine mounts, and it's all the better for it!
TV8
PostPosted: Wed Jan 15, 2020 8:34 pm    Post subject: Reply with quote
Like the updates and good for you for taking on the headlight up-grade. I must get my running thread started.
So the car has a "helmholtz resonator" ? Must check what is in the air box next time I am in the garage.
I looked in Halfords at the unit you fitted and it was a big surprise how much cheaper head units are than I remember and what a choice and stack of features, especially on-line.
The existing unit put up a bit of struggle to come out and whilst searching YouTube, I spotted a video of someone fitting the Continental unit and ended up getting one of those - very retro looking and a good sound I hope!
All being well, it will come before the weekend..
2000 996 Coupe
Shalmaneser
PostPosted: Fri Jan 17, 2020 2:55 pm    Post subject: Reply with quote
TV8 - The standard head unit was a real fight to get out. I had to put a screwdriver through the rings of the removal tools otherwise I think I would have severed a finger pulling before the bloody thing came out!
TBH with the head unit my favourite method has just been to go onto Ebay and buy a second hand unit with the appropriate colour lighting and the features I need. Especially now that most are mechless (ie. no cd player) if you go for a decent brand (Sony/Pioneer/Kenwood etc) they're extremely reliable. All I want to do is play music from my phone over the speakers, I'm no audiophile, and for £30 or whatever I paid for this unit it's been excellent.
Something that has recently been bothering me - does anyone have a method for tightening up the release cables for the front and rear boot lids? Mine nearly get to the end of their travel before they pop, I want to improve this situation if possible!
Goto page Previous  1, 2
Page 2 of 2
