997 : 2004- 61
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayenne : 2003- 7
alan Laing
PostPosted: Mon Dec 30, 2019 6:11 pm    Post subject: Misting up rear lamps on 09 GTS Reply with quote
Who else has had the Issue of the Rear lamps misting up inside with
Water, you can actually see it running down the inside of the lens.
alan Laing
PostPosted: Mon Dec 30, 2019 6:13 pm    Post subject: Reply with quote
And does anyone have a cure for it.
Thanks in Advance
Alan
PostPosted: Mon Dec 30, 2019 6:46 pm    Post subject: Reply with quote
There isn't an inherent problem with these having water ingress that im aware of so its due diligence as to what is causing it ...
I Would start by lifting up the spare wheel / tool lid and making sure its dry in there .
Then remove and inspect the light unit .. the lens for cracks and separation basically .. if you can lift any part of the lens away from the backing then that's the problem or possibly a hairline crack in the lens .
Indy Mechanic .
nigel99
2009 Porsche 997 Carrera 2S
PostPosted: Mon Dec 30, 2019 9:40 pm    Post subject: Reply with quote
Pop the lights out and remove the small rubber stickers. This will let the air circulate. I haven't had the issue since doing this a few years ago.
Current: 997.2 C2S, Audi mk3 TTS Stage 1
Previous: Cayman 987.1, Audi TT mk1 , BMW e46
nigel99
PostPosted: Mon Dec 30, 2019 9:44 pm    Post subject: Reply with quote
I should mention that I had the issue on a 997.2, not a Cayenne, but I imagine that both being 2009 will have the similar stickers in place.
alan Laing
PostPosted: Tue Dec 31, 2019 12:24 am    Post subject: Reply with quote
Thanks gents,
Boot and surrounding area all dry,
Removed the lamps last winter, dried them out over a couple of days. Then run sealant around the edge of the lamp I case they were coming apart.
Then refitted. Car only used Oct to March.
Run my 997 Turbo April to Sept.
Will have a look at the lamps again and see if I can find any Rubber stickers.
Fingers crossed.
Matrixxxx
PostPosted: Mon Jan 06, 2020 12:14 pm    Post subject: Reply with quote
I have the same issue, it looked to be coming in through the seal, as the rubber foam seal was very compressed, also could see a flat part of the light directly above a seal where water could collect and seep in, I put in some more foam seal, which stopped it being like a fish tank, but there is still heavy condensation.
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
