997 : 2004- 65
Boxster : 1997- 26
Gazc2
Watkins Glen
PostPosted: Mon Dec 30, 2019 5:43 pm    Post subject: Turbo hydraulic ram wiring removal ? Reply with quote
I have levered the micro switches out however didn't want to force the wiring at the top of the ram I am assuming this also levers out just thought I would see if anyone could shed any light on this , also what do you do with these once removed do you need to fit an aerokit harness ? I know you have to code it out also.
2007 997 Turbo & 924s Restored
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
 Filesize:  173.25 KB
 Viewed:  650 Time(s)
 Filesize:  202.1 KB
 Viewed:  650 Time(s)
PostPosted: Mon Dec 30, 2019 5:54 pm    Post subject: Reply with quote
Why do you need to remove the micro switches ?
To remove them you don't lever them out , you lift off the plastic cover as you have done then undo the x2 screws .. no.1 in the image and lift out the switch pack from the base upwards.
Indy Mechanic .
 Filesize:  265.91 KB
 Viewed:  641 Time(s)
Gazc2
Watkins Glen
PostPosted: Mon Dec 30, 2019 6:17 pm    Post subject: Reply with quote
I removed them Ian as I dont know any better Very Happy thanks for that looks straightforward enough Thumb
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
PostPosted: Mon Dec 30, 2019 6:28 pm    Post subject: Reply with quote
lol .. ok .. The usual fault is a warning message on the dash .. this can be because the fluid has leaked out a bit and the ram doesn't go high enough to reach the top micro switch.
Hence removing this pack and looking into the hole when its fully extended will show you if the ram is low .
Indy Mechanic .
Gazc2
Watkins Glen
PostPosted: Mon Dec 30, 2019 8:05 pm    Post subject: Reply with quote
I am changing out the whole lid for a fixed aerokit which is why I'm stripping it out
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
jl-c
PostPosted: Mon Dec 30, 2019 9:20 pm    Post subject: Reply with quote
Then leave the wiring alone, disconnect the plug/socket to the rear of the right side lamp unit within the engine bay, unbolt the hinges and job done. You don't need to touch anything else.
darkhorse
PostPosted: Tue Dec 31, 2019 3:21 pm    Post subject: Reply with quote
As above, there is a connector plug to the RHS of the engine compartment and you can just unbolt and remove the tailgate.
Gazc2
Watkins Glen
PostPosted: Tue Dec 31, 2019 7:43 pm    Post subject: Reply with quote
All good gents spoiler removed safely,and I see the connector on the right hand side, bit confused on whether I need to change this harness for an aerokit one which doesn't show on the turbo PET but is on the GT3/RS list or can you tape up the micro switches and just code it out ? I would probably prefer to fit the aero one as it would tidy everything up.
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
 Filesize:  182.77 KB
 Viewed:  498 Time(s)
PostPosted: Tue Dec 31, 2019 7:53 pm    Post subject: Reply with quote
If you are fitting a fixed wing spoiler then as far as i'm aware you unplug that loom and the connection is to the o/s/r of the air box .. ( right side facing it ) ..
You then need to code the car to fixed wing spoiler .
There isn't a loom on a fixed wing as it doesn't have a brake light in it .
Indy Mechanic .
Gazc2
Watkins Glen
PostPosted: Wed Jan 01, 2020 1:54 pm    Post subject: Reply with quote
Ian the aerokit rear spoiler still has the third brake light ,so as far as the loom goes I still need connections to third brake light,Fan and boot light.
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
 Filesize:  285.19 KB
 Viewed:  433 Time(s)
