997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
Littlered996
PostPosted: Sun Dec 29, 2019 11:48 am    Post subject: Disconnecting battery with auxiliary wiring Reply with quote
I need to bring the battery indoors for a deep charge (no power at garage).
Since I last did this, I have had audio work done, and two new auxiliary leads have been connected, one to each battery terminal (see photo). Result: when I disconnect the negative terminal, the alarm sounds.
Is anyone able to walk me through the correct sequence for disconnecting the various wires to avoid deafness, and then for reconnecting them to avoid death? Thanks!
 Filesize:  40.34 KB
 Viewed:  392 Time(s)
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Dec 29, 2019 11:53 am    Post subject: Reply with quote
Key in and turn ignition to position 1, then disconnect earth. Same for reattaching.
Littlered996
PostPosted: Sun Dec 29, 2019 4:29 pm    Post subject: Reply with quote
Thanks MisterCorn. I knew that, but managed to forget it in the last 12 months and focussed on the new wiring.
Such a key tip, and nothing about it in the manual. Same for the bonnet release wire under the left rear light fitting. That’s why this forum’s a life saver, I guess.
