997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
MarkC4S
PostPosted: Sat Dec 28, 2019 7:57 pm    Post subject: Damp Frunk Reply with quote
I have just discovered that the bottom of the frunk is quite damp / wet.
Is there a typical fault that allows water ingress to this location?
Question
Suggestions as to what to look and check for would be most appreciated. Thanks
pzero
PostPosted: Sat Dec 28, 2019 8:07 pm    Post subject: Reply with quote
http://911uk.com/viewtopic.php?t=137122&sid=582c538bdbc4b10bb775a63fb6746dc3
Recent thread.
There are others to be found through searching the forum. thumbsup
991.1 Carrera GTS
PostPosted: Sat Dec 28, 2019 8:29 pm    Post subject: Reply with quote
I was about to answer this but my answer is already on the link above by Pzero .
Indy Mechanic .
MarkC4S
PostPosted: Sun Dec 29, 2019 6:24 am    Post subject: Reply with quote
Thank you I shall read and search. It was a quick and lazy post just after I discovered the problem and had to run off and do something else.
MarkC4S
PostPosted: Wed Jan 01, 2020 4:53 pm    Post subject: Reply with quote
All sorted now, 4 blocked drain holes! Must make this a regular check.
Thanks for the help.
