997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
jond58
PostPosted: Fri Dec 27, 2019 2:25 pm    Post subject: Exhaust replacement Reply with quote
Well I’ll keep everyone updated with what happens and any tips I obtain from doing it. It’s a full exhaust replacement I’m going to do on Monday. I have every clamp, bracket, gasket, all marine grade fixings. In my arsenal of weapons are an induction tool, laser stud extractor, rounded bolt bits and the Stomski drill jig!!
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
 Filesize:  110.32 KB
 Viewed:  1470 Time(s)
jezgreen911
PostPosted: Fri Dec 27, 2019 3:29 pm    Post subject: Reply with quote
Stay
Looking forward to your updates, I will be tackling my manifolds in the next few weeks.
I should be out in the garage working on it now but currently building the Lego RSR instead Floor
2003 996 C2
jond58
PostPosted: Fri Dec 27, 2019 3:41 pm    Post subject: Reply with quote
A Lego rsr!??! That sound easier ! Unlike to have too many seized bolts. In all honesty I’ve been putting it off all year but I’m determined nows the time. My friends an engineer and he’ll help. Today he asked ‘has anyone managed to remove all twelve without any snapping’ I admire his optimism! As misplaced as it obviously is
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
Hughb
PostPosted: Fri Dec 27, 2019 10:39 pm    Post subject: Reply with quote
Ditto, looking forward to seeing how you get on.... looking at you parts box you certainly seem to be going the whole way with new brackets etc.
And that’s a comprehensive range of tools aimed at the manifold and bracket studs. Is the induction tool included to get some heat into the studs and get some temperature difference between them an the aluminium block?
I would be interested to know what year/mileage your 996 is, and what manifold/silencer you have chosen in moving away from OEM. This project is on my longer term ‘to do’ list.
Are you on a ramp or axle stands?.... and when you say Monday, do you have Tuesday and Wednesday in reserve?!
Best wishes for a successful (and well documented) day (or so).
jond58
PostPosted: Fri Dec 27, 2019 11:02 pm    Post subject: Reply with quote
My theory with the induction tool is that some heat will help although I think if they snap and leave something for me to grab hold of with the stud extractor then it’ll work well. It’ll be less effective with the manifold in place I think as some heat will disperse into the flange although without having done it before I’m somewhat speculating!
I have a unit for work (I’m a joiner) that I’ve fitted with a four post ramp so that’s a big help, my friend is a good mechanical engineer so it’s always good to have a bit of moral support. I’m competent with the spanner’s but I work on motorcycles so it’s a step into new territory but efffectively I need to undo a lot of bolts, some of which are seized?! It maybe a Porsche but Harry Potter didn’t build it with a wand!
I’ll try a few things, heat, rattle gun, 1/4 drive, 3/8, shocking bolts etc and report back.
The cars a 3.4 with 90k on it and already has dansk boxes and top gear cats. I’ve gone for milltek boxes, top gear x pipe, toyosport chinese manifolds and everything else is brand new Porsche. I’ve accumulated it over a year so the brackets and frames are new old stock for various places at cheap prices but it’s nice to know it’s all new and shiny.
Finally, yes I’ll be there Monday and Tuesday I suspect and if it all goes horrible the car can sit there all month which is a nice luxury to have I guess.
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
jond58
PostPosted: Fri Dec 27, 2019 11:08 pm    Post subject: Reply with quote
I’m stepping into it eyes open, I know it won’t be fun!
That said I did install a new system on my 30year old nc30 motorcycle that’s done 50,000 kilometres without snapping or stripping anything and those manifold studs are m5 fine thread.
It’s about being patient and understanding it’s should take an hour but will probably take ten!
I’d be over the moon if by Monday night it was all dissembled and ready for the new parts, in fact even if one side was ready I’d take that!
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
Scholester
[quote="Today he asked ‘has anyone managed to remove all twelve without any snapping’ I admire his optimism! As misplaced as it obviously is[/quote]
Me!
Fortunately, all bolts (not studs & nuts) wound straight out. That said, I had been liberally spraying them with penetrating fluid for weeks in readiness for the big day. Not sure if being a Mezger block helped?
I replaced all with titanium as this seems to be what is recommended. All other fixings throughout the exhaust system were screwed and it's a very trying job getting things separated but I got there in the end.
Best of luck and just be as patient as possible and take as many breaks/days off as you need and you will get there in the end. Thumb
jond58
PostPosted: Fri Dec 27, 2019 11:14 pm    Post subject: Reply with quote
That’s great news! I’ll tell him the gauntlet has been laid down and someone has spun them all out! He’ll have his engineering brain into gear working out how we can’t be beaten.
I’ve been soaking them for a week with the new wd40 fast release stuff, it has great reviews. I also have two tins of pb blaster and some plus gas to use up on the job!!
You could do with it on its roof ideally though, the angle of them doesn’t help them with soaking.
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
jond58
PostPosted: Fri Dec 27, 2019 11:17 pm    Post subject: Reply with quote
The massive plus for me that I failed to mention is that the previous owner installed the cats and boxes with marine grade fixings so I’ll be bumper off and all that removed fairly quickly. I’ve checked all those parts and fixings and they will spin straight off.
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
Scholester
PostPosted: Sat Dec 28, 2019 12:47 am    Post subject: Reply with quote
Should be a doddle then!
I became an expert at pecking away at rusty, 'blobby', bolts with a light hammer, punch and small chisel. All carried out on my back in an unheated garage with my feet out in the February cold and wet.......fun times!
jond58
PostPosted: Mon Dec 30, 2019 10:04 pm    Post subject: Reply with quote
Well............it’s been challenging!!!!
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
 Filesize:  119.81 KB
 Viewed:  1126 Time(s)
jond58
PostPosted: Mon Dec 30, 2019 10:16 pm    Post subject: Reply with quote
We are currently at the stage where one manifold is removed, every bolt snapped but not before we’d spent an age rounding them off!!! I was hammering 3/8 sockets on!! That’s 9.5mm onto what would have been a 13mm. Honestly we had no chance and to be honest I was praying they’d just snap easy and then we could get on with the inevitable drilling!!
Anyway they’re all drilled out and half of them tapped so I’ll finish that in the morning and then we’ll drill out the other side and then Wednesday I’ll have it all back together!! It’s been tough, drilling with the jig is easy. Bit of setting up and don’t go stupid with drilling but honestly easy. I wouldn’t recommend trying this job if you don’t have a ramp, aren’t mechanically competent and if you don’t have a jig.
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
jond58
PostPosted: Mon Dec 30, 2019 10:23 pm    Post subject: Reply with quote
Also doing it with your mate helps. This kind of work could do you in but we’ve genuinely pissed ourselves laughing all day about it!!!
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
jond58
PostPosted: Mon Dec 30, 2019 10:45 pm    Post subject: Reply with quote
To give an indication of how hard this job can be. My friend is a qualified motor mechanic but now works in the engineering industry with contracts on and off shore in energy. I’ve worked on cars and motorcycles for twenty odd years including Engine rebuilds on v twin Aprilias. It’s fair to say we know which end of the ratchet to hold each of us.
I soaked the bolts which I’ve always been dubious of, they’re so welded in will it even penetrate past the flange to the thread. Got there early, bumper off, boxes off, cats off. All the time I was removing this lot Bruce was hammering the bolts with a bar to shock them down the thread. So on with the induction tool. Cycled all the bolts with heat. Heated again and then attempted to remove. Basically nothing moving at all, mostly rounding off if anything. There was a time I was concerned maybe I’d missed they were left hand thread!! Anyway Bruce breaks out the welder and welds nuts on, mostly two attempts with nuts, one had four attempts so these bolts have had a lot of direct heat and basically they all snapped.
Out with the laser 1/2inch extractor tool and another two cycles of heat and .........snaps what’s left flush.
At that point I realised the futility of trying more and resigned myself to drilling!
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
Scholester
PostPosted: Mon Dec 30, 2019 11:56 pm    Post subject: Reply with quote
Looks like you are getting the sh1tty end of the stick!
Well done for persevering and having a great mate to share the pain. It will all be worth it in the end.
What type of replacement fixings will you be using?
jond58
PostPosted: Tue Dec 31, 2019 12:11 am    Post subject: Reply with quote
Steel studs with aluminium paste, copper/brass flange nuts on stainless spring washers. This is what I’ve done loads of times with motorbikes never had any issues with this set up. Marine grade stainless for literally every other fixing.
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
jond58
PostPosted: Tue Dec 31, 2019 12:15 am    Post subject: Reply with quote
The main thing is to stay positive and cheery!?! We both know it’s not incompetence or poor workmanship it’s just corrosion over time and a large helping of misfortune so we’ve just made a laugh of it and got on with it. For instance should any of that other side come out I’ve instructed Bruce to put them back in and snap them!!? I want to be part of the legendary team that snapped every fixing!!!!!
Current fleet
996
Z4 (the wifes!)
Vito 122
Honda NC30
Ducati 748
INWB
PostPosted: Tue Dec 31, 2019 3:08 am    Post subject: Reply with quote
Congrats on staying cheerful ! It isn't any wonder that many owners delay it until they MUST do it. All of mine broke and I think thee guy ended up taking about 12 hours to finish the job. (only charged me 8 which softened the blow).
Be worth it when finished and will sound great Smile
2003 Manual 996 C4S Midnight Blue
jezgreen911
PostPosted: Tue Dec 31, 2019 8:13 am    Post subject: Reply with quote
Thanks for the update, I guess we all know the likely outcome but with mine to do I was still holding out for more fortuitous news on yours nooo
Did you get any pictures of the bolt heads and what's the age and mileage of your car?
2003 996 C2
coullstar
PostPosted: Tue Dec 31, 2019 11:35 am    Post subject: Reply with quote
Right tools and space but no major time constraints make most jobs okay and a little fun in a sadistic kind of way Laughing .
Glad to hear its going relatively straight forward.
Goto page 1, 2, 3  Next
Page 1 of 3
