997 : 2004- 65
Boxster : 1997- 26
Schwaben
PostPosted: Thu Dec 26, 2019 9:48 am    Post subject: Accurate oil measurement 997.1 C2S Reply with quote
Hello, I bought my 997.1 last week and am stumped with oil measurement. I've trawled websites and cannot find a consistent answer so hoping that there is an accepted 'truth'. On picking up car it had a replaced AOS and I filled oil up as it was on min bar. I checked when cold, first thing in morning on level drive. After a short drive when again cold measurement was one bar down, however on checking after a subsequent drive and post 5 min wait (engine was warm) it read full. Next day when cold it read one bar down.
I do not want to over fill but concerned about over use of oil. Can you please educate me on which reading to trust. I note the manual says that car checks automatically when refuelling so car is obviously warm. Others say do it when cold. V confused newbie who misses analogue dipsticks. Thanks.
NLW73
PostPosted: Thu Dec 26, 2019 11:34 am    Post subject: Reply with quote
i always run from one from the max level or to max level.
needs to be on flat surface to measure plus if you can for a run not all the oil will have settled to the place it needs to be.
997 C2s Schwarz
Marky911
PostPosted: Thu Dec 26, 2019 11:56 am    Post subject: Reply with quote
As above. Engine hot after a good run, but give it a minute to settle.
Gauge is usually very good. I run mine at max which is actually one segment down from top, so one empty segment showing is max.
Not that I’ve had to top-up in between services for years. Thumb
Schwaben
PostPosted: Thu Dec 26, 2019 12:09 pm    Post subject: Reply with quote
Thanks. So concensus is to measure post run after indicated 5minutes wait? For note, I do measure at the same place on near flat driveway.
jl-c
PostPosted: Thu Dec 26, 2019 9:27 pm    Post subject: Reply with quote
Hot to cold, I find on mine is one segment or bar ( display NOT pressure), so I fill and check cold to one bar below full and then when hot it indicates full. Beware even the slightest slope, if you have a nearly flat drive take the car for a run and park it on the drive, wait 5 minutes, check oil. Take it for another run, park it on the drive in the opposite direction, wait 5 then compare readings, you may well be surprised! Long winded I know but you only need to go through it once. My drive though ostensibly flat has a difference of 2 bars depending on drive in or reverse in!
Schwaben
PostPosted: Fri Dec 27, 2019 12:09 am    Post subject: Reply with quote
Interesting. Your 1 bar difference between hot and cold tallies with my experience. For consistency I'll park in same spot and carry out reading after run with warm engine.
PostPosted: Fri Dec 27, 2019 1:29 pm    Post subject: Reply with quote
Welcome to 911uk Schwaben.
That gauge is only measuring the final 1.5 litre of oil in your engine so the single bar variance that you're experiencing is only about 0.2 litres.
As long as it stays in the middle of those min/max lines on the gauge I wouldn't be concerned.
me&my997
PostPosted: Fri Dec 27, 2019 7:17 pm    Post subject: Reply with quote
Confused now Confused i did with previous 911's & do with current 997 check the oil before each & every drive Dont know never bother as the car goes away post drive Embarassed have i got it back to front Surprised
964 C2 / sold in haste - 2010
996 C2 / bought in haste - 2011
997 C4 / back in the game - 2019
http://911uk.com/files/dsc_5307_2_764.jpg
https://www.instagram.com/andy911wheels/
jl-c
PostPosted: Fri Dec 27, 2019 7:28 pm    Post subject: Reply with quote
that works fine as long as it shows 1 segment below full Very Happy
PostPosted: Fri Dec 27, 2019 8:32 pm    Post subject: Reply with quote
http://911uk.com/viewtopic.php?p=1517003#1517003
Indy Mechanic .
