997 : 2004- 62
Boxster : 1997- 26
Cayman : 2005- 20
Cayenne : 2003- 4
rob_p
PostPosted: Fri Dec 20, 2019 6:05 pm    Post subject: Hesitation / judder... Reply with quote
Evening all
I pulled the car out of the garage this morning and within 200metres realised I had an issue.
There car has developed a hesitation/ resitantance under acceleration and a slight judder. It's all pretty modest but it's definitely there.
The engine management light came on for a short time and then went off again.
First thoughts are a misfire and therefore spark plugs and coil packs.
Any other thoughts?
Also - I know there are a couple of different diagnostic tools - any good or bad experiences to share? Happy to spend a bit more to get something that will do everything I might need over time?
Thanks in advance
Jeep Grand Cherokee WK2
Ex 991.1 C2
Ex Porsche Boxster 986
Ex Mazda MX5 mk1
PostPosted: Fri Dec 20, 2019 6:24 pm    Post subject: Reply with quote
I'll go with a coil or possibly the high lift solenoid on one bank being the fault .. if coil then i'll guess no.1 .
Fault code readout will say what the issue is .
The best tester is obviously a Piwis clone but they aint cheap .. durametric is a pretty good all rounder and a lot cheaper .
Indy Mechanic .
rob_p
PostPosted: Fri Dec 20, 2019 7:29 pm    Post subject: Reply with quote
Thanks. Any recommendations on a tester?
Much appreciated.
Ex 991.1 C2
Ex Mazda MX5 mk1
PostPosted: Fri Dec 20, 2019 7:33 pm    Post subject: Reply with quote
As above .. piwis or durametric pro Smile
There are cheaper but i have no knowledge of them im afraid .
Indy Mechanic .
rob_p
PostPosted: Fri Dec 20, 2019 7:43 pm    Post subject: Reply with quote
Like this?
Anyone have any experience of this unit?
http://www.diagnostic-world.com/pages/list_of_all_auto_diagnostic_tools_273181-z=960090&p=131264.cfm#content_item_131264
Ex 991.1 C2
Ex Mazda MX5 mk1
PostPosted: Fri Dec 20, 2019 8:19 pm    Post subject: Reply with quote
https://www.gendan.co.uk/porsche.php?gclid=EAIaIQobChMIj42en4bF5gIVhbTtCh0QeAm2EAAYASAAEgL2cfD_BwE
http://www.durametric.com/
Indy Mechanic .
timbo1811
PostPosted: Fri Dec 20, 2019 10:51 pm    Post subject: Reply with quote
+ one on coil packs, Just had the same symptoms which turned out to be coil packs.
Lotus Elan, Lotus Elan +2, MGA Mk11, TR4, 230 Compressor, 320 coupe, 944, Boxster 2.7, 997.1(current), VFR 1200, CBR 1100 Blackbird
NickHappy
PostPosted: Sat Dec 21, 2019 7:20 am    Post subject: Reply with quote
Does this only happen when cold or at all temperatures?
997 turbo Manual.
996 turbo Manual. ex.
rob_p
PostPosted: Sat Dec 21, 2019 7:22 am    Post subject: Reply with quote
Not sure I drive the car far enough to tell tbh.
I turned aoeund after a few miles and headed home - it was still doing it when I got home though.
Different thoughts?
Ex 991.1 C2
Ex Mazda MX5 mk1
NickHappy
PostPosted: Sat Dec 21, 2019 7:42 am    Post subject: Reply with quote
So many things hesitation could be from experience, at what temp. (If any) may help narrow it down.
Keep us posted on how you get on 👍🏻
997 turbo Manual.
antonio
2005 Porsche 997 Carrera 2S
PostPosted: Sat Dec 21, 2019 10:00 am    Post subject: Reply with quote
This is exactly what happened to me, CEL was flashing then car ran really rough, code reader came up with misfire on Cylinder one, i used the Foxwell NT520.
rob_p
PostPosted: Sat Dec 21, 2019 4:34 pm    Post subject: Reply with quote
Quick update.
I remembered that I bought one of the cheap as chips Bluetooth obd readers a while ago. I downloaded an app on the phone called car scanner.
Go to everything connected and read the fault log... misfire on cylinder 2.
I have ordered all new plugs and coils so will have a go at doing the lot over Xmas.
Had a quick look on YouTube - looks a bit fiddly but still diy'able.
Anyone disagree or any hints? Looks like taking the exhaust silencer off makes the job quite a bit simpler.
Ex 991.1 C2
Ex Mazda MX5 mk1
timbo1811
PostPosted: Sat Dec 21, 2019 5:22 pm    Post subject: Reply with quote
The new coil packs are slightly bigger than the originals which make it a bit more awkward, they come with new bolts. 3/8 socket set may be useful. The job can be done without removing the exhaust, but I guess it depends on what facilities you have. Sometimes the plug socket stays on the plug when you remove it, some duct tape sorts this.
montygraphics
PostPosted: Sun Dec 22, 2019 1:52 pm    Post subject: Reply with quote
In my experience a single misfire on diagnostics is usually a coilpack - a whole bank of 3 is usually a soleniod.
rob_p
PostPosted: Sat Dec 28, 2019 5:23 pm    Post subject: Reply with quote
Quick update. I have spent most of today tackling this job.
The plugs and coil packs are very fiddly but it is diyable. That said, I might think twice before taking this on again.
I did remove the exhaust silencer to get some space - albeit the exhaust hanger bracket is still right in the way!
I supplied my Indy with new coil packs when I brought the car in 2013 which he fitted. I was quite disappointed that #2 had failed. Imagine my surprise when I pulled #2 out and it has an original part number on it and is very obviously different to the other five! Hard not to conclude that I have been short changed!! (He has since retired so no comeback).
2 problems have arisen:
When I tried to remove the bumper retaining bracket the 10mm bolt which goes up into the chassis snapped off leaving the stud stuck in the thread.
I then decided to try and drill it out and in order to make some space I tried to remove an earth strap which mounts next to it. The nut snapped off freeing the earth strap but also leaving me no way of attaching it. This was all on the offside which surprised me - the near side I didn't have any issues with removing fittings.
I quickly gave on drillling out the other stud also so I am left with two problems.
I guess the 10mm can be drilled out and retapped by someone that knows what they are doing?
Can the earth strap be mounted to anywhere on the chassis or will that also need some specialist attention?
Thanks!
Ex 991.1 C2
Ex Mazda MX5 mk1
PostPosted: Sat Dec 28, 2019 5:36 pm    Post subject: Reply with quote
This is not sounding too good Sad
Can you get a photo of the snapped earth strap if possible .
Im guessing its the large earth strap o/s/r .. this is the main engine earth so not only do i think the car will not start i dont think its a good idea to attempt starting it either .
You can't really drill and fix this lead as its a box chassis section it fits to , it needs a stud welded on really .
I think it needs to goto a garage .. that will require being recovered or using a jump lead inside the engine bay to give it a temp earth .. a little risky i feel .
the above is assuming the snapped lead is the engine earth strap though .. hence a picture if possible .
Indy Mechanic .
rob_p
PostPosted: Sat Dec 28, 2019 5:56 pm    Post subject: Reply with quote
Oh dear... thanks for the reply. I will try and post a photo later.
Ex 991.1 C2
Ex Mazda MX5 mk1
rob_p
PostPosted: Sat Dec 28, 2019 6:48 pm    Post subject: Reply with quote
Thanks DeMort,
Photos below, one showing the sheared stud (there might be enough left to get some kind of nut extender onto it?) - is it M8?,
and one showing the strap hanging down.
Also note the bumper bracket bolt next to it where it has also sheared (obviously less urgent than the earth strap....)
Any advice welcome!
thanks
Ex 991.1 C2
Ex Mazda MX5 mk1
 Filesize:  355.02 KB
 Viewed:  668 Time(s)
 Filesize:  348.68 KB
 Viewed:  668 Time(s)
PostPosted: Sat Dec 28, 2019 7:04 pm    Post subject: Reply with quote
I see what you mean by bumper bracket now .. you can drill a hole and use a self cutting bolt / screw to reattach that .. it's no problem if left off for now .
As it stands and after thinking about it your car won't start .. i remember leaving off an earth lead on an engine drop in the past .. it wont start .
Fixes .. a welded stud is best .. body shops have this sort of equipment but that doesn't really help you atm ..
My suggestion if you want to try it ..
You use the kit in the link below ..
You basically drill a hole , insert the collapsable threaded rivet nut and use the tool to compress it .. you then have something to put a bolt into for the earth lead .
Access is the only problem with the tool .. it will stick out at a right angle from the chassis .. if you have the clearance then this is the best diy i can think of .
https://www.ebay.co.uk/itm/Blind-THREADED-NUT-RIVET-INSERT-TOOL-GUN-RIV-NUT-RIVET-M3-M4-M5-M8-RIVETER-Set/132927926036?hash=item1ef31f2f14:g:g7YAAOSwUMBcSJGb
Btw .. im happy to chat on the phone should you wish to , just say and ill PM you my number .
Indy Mechanic .
P9XX
PostPosted: Sat Dec 28, 2019 8:43 pm    Post subject: Reply with quote
Rob_p. I think you've already thought of this idea.
As a temporary or even permanent fix for the earth strap stud, you seem to have about 4 to 6 threads showing. If so, I would try a stainless rod coupler nut with Loctite onto the cleaned threads. Check electrical continuity from the coupler to the chassis. Then a short, M8 X 12 say, bolt to re-attach the earth strap.
2008 997.2 C2S PDK Basalt Black
 Filesize:  101 KB
 Viewed:  630 Time(s)
