997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Cayenne : 2003- 4
AdamD
PostPosted: Tue Dec 17, 2019 6:31 am    Post subject: Strut top recommendations Reply with quote
I’ve decided the next project for my anniversary 996 is going to be a suspension refresh.
Originally I was planning to simply replace like for like (M030) but having read the great reviews about Ohlins R & T, think I may as well opt for those given the relatively small difference in price.
I’m planning to do the work myself and then get someone to set up the geo but the first job is to source the required parts.
Obviously I’ll be changing the strut tops and bearings while I’m at it, so can I simply use Sach items or should I be looking at using OPC? Also, I’m guessing I can use regular C2 strut tops and don’t need to replace with M030 strut tops if I’m going down the aftermarket route?
Any advice or suggestions would be appreciated.
GMG
PostPosted: Tue Dec 17, 2019 6:37 am    Post subject: Reply with quote
...Prior to refreshing my front suspension following a snapped spring I contacted centregravity and Chris advised OPC for strut mounts as the cheaper stuff is crap quality...I took his advice...
He said that the bearings rarely fail thus can be cleaned up,regreased and refitted...
Martin996RSR
PostPosted: Tue Dec 17, 2019 7:40 am    Post subject: Reply with quote
MO30 Strut tops are the same as standard strut tops, despite what Design 911 would have you believe. The X75 strut tops are the only ones that differ from standard.
coullstar
PostPosted: Tue Dec 17, 2019 9:23 am    Post subject: Reply with quote
In what way do they differ?
Martin996RSR
PostPosted: Tue Dec 17, 2019 10:09 am    Post subject: Reply with quote
I believe they are angled in a way that supports more camber.
Billy Bumpsteer
PostPosted: Tue Dec 17, 2019 11:07 am    Post subject: Reply with quote
Eh? No such thing as a M030 top mount & IX75 is diff lock
IX74 is the Exclusive Sports Suspension which have their own front top mounts
IX73 is the Turbo Sports Suspension, as fitted to optioned turbos & C4S, which have the same mounts as IX74
Anniversary cars are 2WD, it may have the IX74 option? Dont know
Martin996RSR
PostPosted: Tue Dec 17, 2019 11:34 am    Post subject: Reply with quote
Sorry, Billy, I meant X74. I hope the error hasn't thrown the guy asking the question.
I know there is no such thing as an M030 top mount, it's just that D911 list an M030 top mount on their website for silly money despite some of us knowing there is no specific M030 top mount, and the M030 setup just uses a completely normal stock mount
Billy Bumpsteer
PostPosted: Tue Dec 17, 2019 11:48 am    Post subject: Reply with quote
Correct, although worth running your VIN through OPC just to check Very Happy
Billy Bumpsteer
PostPosted: Tue Dec 17, 2019 11:50 am    Post subject: Reply with quote
Looking at their site it looks like they are confusing IX74 as being the same as M030 Dont know
AdamD
PostPosted: Tue Dec 17, 2019 8:47 pm    Post subject: Reply with quote
Thanks for all the replies and for clearing up the confusion around M030 top mounts. You were quite right, I was pricing up parts on the D911 website hence the reason for my question.
MaxA
PostPosted: Wed Dec 18, 2019 9:25 am    Post subject: Reply with quote
You might want to check what the R&Ts come with: mine (albeit not on a 911) came with the strut tops /plates from Öhlins.
AdamD
PostPosted: Wed Dec 18, 2019 9:52 am    Post subject: Reply with quote
I’ve managed to secure one of the last January Saturday clinic slots with Centre Gravity. I thought it prudent to get their view on what actually needs replacing rather than needlessly buying kit because I think the car would benefit from it.
Since my original post, I’ve read a few threads about the lifespan of the factory dampers with some reporting they are still operating well at 150k? Seems hard to believe but we will see.
AdamD
Martin996RSR
PostPosted: Wed Dec 18, 2019 11:17 am    Post subject: Reply with quote
It wouldn't surprise me if the fronts could live that long, but the rears would be totally shagged by that mileage.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Wed Dec 18, 2019 11:28 am    Post subject: Reply with quote
Me too... at CG on 4th Jan Very Happy
Unless a previous owner changed them, my dampers have 115k on them so it will be interesting to see what the test rig reveals...
If you've not read the latest 911&PW 996 suspension test then I'd recommend it - it seems the standard Ohlins springs are too firm for road use.
Pickse
PostPosted: Wed Dec 18, 2019 6:35 pm    Post subject: Reply with quote
Bell & Colville have a useful web site with parts diagrams which also advise when a part has been superseded by a newer one.
Their prices are also very similar to OPC and probably less than D911 so worth a look.
https://www.deroure.com/diagrams.asp?TBL=2586&MAK=3&MDL=25&SMA=0&SMO=0&ST=99737503303&SC=1
Pickse
03 Arctic Silver 996T Tip S
Now 9E38 - An improved! 996T
cvega
PostPosted: Wed Dec 18, 2019 7:16 pm    Post subject: Reply with quote
I, too, managed to secure a slot in Jan - 25th. I'm on ohlins and car is firm AF. Need to determine whether they are actually seized or just need adjustment.
2003 996 C2 (Ohlins R&T suspension, Toyosport/Spyder exhaust)
AdamD
PostPosted: Wed Dec 18, 2019 9:00 pm    Post subject: Reply with quote
I may see you there as I‘m also booked in on the 25th @ 11am.
Thanks for the Bell & Coville link. Will check it out
