997 : 2004- 60
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
G-996
PostPosted: Sat Dec 14, 2019 2:36 pm    Post subject: Water discharge under car Reply with quote
I noticed some water discharge under my 2003 996 C4 more than I would normally expect due to AC condensation. Water was coming from the middle of the car, roughly in line with the door mirrors. When I took off the front underbody panel to investigate, it was clear that the water was coming from the short rubber pipe in the middle of this photo (you can see it is wet). I guess this is some kind of overflow / expansion outlet valve? Does anyone know what that is?
There has been no drop in coolant level. I’ve had the car 5 years, and the level of water discharge under the car is more than I’d expect due to AC condensation. It’s formed a puddle about 10cm across.
I’d appreciate any advice / confirmation of what this “overflow” (?) pipe is for. Thanks
 Filesize:  294.23 KB
 Viewed:  683 Time(s)
alfazagato
PostPosted: Sat Dec 14, 2019 3:55 pm    Post subject: Reply with quote
Is this not the end overflow pipe for the area in front of the scuttle.
PostPosted: Sat Dec 14, 2019 5:42 pm    Post subject: Reply with quote
It is indeed the a/c water outlet pipe to drain away the water generated from the a/c matrix .... its normal Smile
Indy Mechanic .
G-996
PostPosted: Sat Dec 14, 2019 6:08 pm    Post subject: Reply with quote
Many thanks Thumb
