997 : 2004- 62
Boxster : 1997- 26
Cayman : 2005- 20
Cayenne : 2003- 4
Pjt73
PostPosted: Sat Dec 14, 2019 12:08 pm    Post subject: Battery dead Reply with quote
Ok. Was expecting battery to be dead after 3 weeks abroad. Should have put optimizer on but didnt. Unable to open boot to get to battery. Went to fuse panel but the little red tab is too far in to grab with the fuse pullers. So now im stuck. I know there is a release behind front wheel but my lock nut tool is in the boot as well. If i had hair i would be pulling it out. Any advice?? Thanks
997 carrera2. 04. Previous Car gsxr 1000
brownspeed
PostPosted: Sat Dec 14, 2019 12:30 pm    Post subject: Reply with quote
do you have any long nose pliers?
2004 997.1 C2S (Hartech rebuilt)
2002 TVR Tamora 3.6
1990 Mini Cooper RSP
Abarth 595
Pjt73
PostPosted: Sat Dec 14, 2019 12:35 pm    Post subject: Reply with quote
I do. But the tab is pushed too far in. Its beyond the plastic containment. If that makes sense?
TonyC911
PostPosted: Sat Dec 14, 2019 12:52 pm    Post subject: Reply with quote
You should be able to remove / loosen the NS front wheel arch liner, enough to get to the emergency release, without removing the wheel.
Pjt73
PostPosted: Sat Dec 14, 2019 12:57 pm    Post subject: Reply with quote
I cant even get my hand in mate.
Sorted now i hope.
Took off trim panel around fuse box and pushed red tab back out.
Had enough for today. Beer o clock lol.
m1kegibson
PostPosted: Sun Dec 15, 2019 12:05 am    Post subject: Reply with quote
Hi there. I had same issue; red tab pushed in beyond point that one could get at it. You can loosen the fuse panel itself (I don't remember if its fixed with screws or plastic tabs offhand), pull it forward (gently) allowing you to get a finger behind the red tab bit and push it back out.
NLW73
PostPosted: Sun Dec 15, 2019 8:05 am    Post subject: Reply with quote
You can always slide a ruler or thing plastic thing under the rear near side light
There is a cable in there to pull and it releases the engine cover
You can then get some jump leads onto the positive terminal under the small black plastic cover. Put the negative onto some
Metal in the engine
It’s another option if you can only get to the rear and not to the front where the battery is to jump the car
997 C2s Schwarz
Pjt73
PostPosted: Sun Dec 15, 2019 11:59 am    Post subject: Reply with quote
I did this mate. Now the charger i have doesnt seem to have enough oomf to power the lid. So off to buy another. 😠
Pjt73
PostPosted: Sun Dec 15, 2019 12:00 pm    Post subject: Reply with quote
Metal in the engine
Cheers. Need a new charger now 😠
Magic919
PostPosted: Sun Dec 15, 2019 12:04 pm    Post subject: Reply with quote
Some chargers won’t output if they don’t sense a certain voltage. Better off with a battery or power supply.
997.2 C4S PDK
Pjt73
PostPosted: Sun Dec 15, 2019 12:30 pm    Post subject: Reply with quote
If new charger doesnt work ill jump off the other car. Proper design flaw this is. But never mind.
jl-c
PostPosted: Sun Dec 15, 2019 12:34 pm    Post subject: Reply with quote
Just ensure you have got a proper earth not the door latch as it is not earth. The check strap however is.
