997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
Mac996t
2004 Porsche 996 Turbo
PostPosted: Mon Dec 09, 2019 6:38 pm    Post subject: Reply with quote
I’d make a decision based on a close inspection of the old bearing and having a look in the sump at the oil pickups. I’d remove the covers from the bearing and have a look at just how much wear there is ,and if there are any bits of metal in there wether they were big pieces or a fine paste. The bearing will have been grinding away for a while so you will already have had bits circulating in the oil and so far they haven’t caused a blow up
Big pieces can jam in an oil pump and break the drive, or get stuck in the solenoids etc, fine pieces just scrape the inside.
I’ve had lots of engines apart over the years and most have shown signs of small amounts of debris going through oil pumps and leaving scratches etc, a small amount won’t make an engine fail.
If the only evidence was for fine particles I’d fit a new bearing and chance it and do an oil change in 1k miles and see how much you’ve collected
Mac
mar1b0ro
PostPosted: Tue Dec 10, 2019 12:51 pm    Post subject: Reply with quote
EGTE wrote:
That is of course fraud, well done.
Err, not if there really was a cat...bloody bad luck I'd call it.
In the land of the blind, the one eyed man is king.
DarthFaker
PostPosted: Tue Dec 10, 2019 2:43 pm    Post subject: Reply with quote
I think avoiding a cat isn't a good enough reason, but I believe a dog is. If I remember correctly from when I worked in insurance.
Martin996RSR
PostPosted: Tue Dec 10, 2019 3:14 pm    Post subject: Reply with quote
What about something cat-sized but quite rare, such as a Lemur?
PostPosted: Tue Dec 10, 2019 10:20 pm    Post subject: Reply with quote
mar1b0ro wrote:
Option 6 - put car back together, drive into nearest tree at 30mph avoiding cat that came out of nowhere, claim for total loss on insurance.
Floor
Option 7 - Electrical fault in frunk which had spare can of fuel in
UncleP
PostPosted: Thu Dec 12, 2019 1:15 pm    Post subject: Reply with quote
Recent post on Pistonheads revealed that its in the small print on many policies that they won't pay out for a fire caused by an electrical fault. It's viewed similar to a mechanical failure and not the insurance companies concern.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Thu Dec 12, 2019 1:18 pm    Post subject: Reply with quote
Not pelicans either...
https://jalopnik.com/the-guy-who-crashed-a-bugatti-into-a-lake-has-been-sent-1748158995
GMG
PostPosted: Thu Dec 12, 2019 5:58 pm    Post subject: Reply with quote
...he's an American what do you expect?
PostPosted: Thu Dec 12, 2019 9:01 pm    Post subject: Reply with quote
I just set the fuel line on fire with a lighter on my sister's Astra and they paid out straight away.
DarthFaker
PostPosted: Mon Dec 16, 2019 6:00 pm    Post subject: Reply with quote
So I made a little video with my thoughts on IMS bearings, it covers more than I can be bothered typing.
https://www.youtube.com/watch?v=5MOvFby-NCo
If you can bear watching a northerner rant for 8 minutes, and let me know what you think.
James.
Robertb
PostPosted: Mon Dec 16, 2019 7:44 pm    Post subject: Reply with quote
James.
Some interesting thoughts there James, but please don’t keep clicking your biro in the next video! what
Are you going for an EPS cylindrical bearing?
Your comments on more bearings failing as the cars get older is contrary to everything I’ve heard... what changed your mind on that one? Looks like you were lucky that your intermediate shaft didn’t let go and do loads of damage...
GMG
PostPosted: Mon Dec 16, 2019 8:12 pm    Post subject: Reply with quote
...a similar story to mine...immaculate FOPC history car at 69k miles...ims failed resulting in £14k rebuild...
Prior to the failure I spoke with Hartech whom said ignore the hype and drive the car!
My advice to anyone thinking of buying one is buy one with a rebuilt motor unless you can afford a £10k plus bill...because failure can't be predicted !
Equally I wouldn't touch one with more than about 80 ish k that hadn't been rebuilt because of the main bearing wear issues.
I won't mention borescore because you can at least detect this...
My prediction is that as the years pass anything that hasn't had a rebuilt motor will be worth peanuts ... why would one take the risk?
DarthFaker
PostPosted: Mon Dec 16, 2019 9:17 pm    Post subject: Reply with quote
James.
Because all things mechanical fail eventually and nothing gets better in a mechanical system without intervention.
There's a statistic for bearings called an L10 life which is a 10% failure rate at any given number of rotations at a given load and speed.
All bearings fail eventually, but as external influences, heat, poor lubrication and most significantly age/wear stack against any bearing, it will eventually fail.
These aren't pressure fed plain bearings with no surface contact, they're a ball bearing.
Goto page Previous  1, 2
Page 2 of 2
