997 : 2004- 60
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
DarthFaker
PostPosted: Sat Dec 07, 2019 9:30 pm    Post subject: Opinions on an IMS failure.. Reply with quote
Hello,
I've sort of held of posting about this until I had thought about the questions I wanted to ask.
So I suffered an IMS failure, which I just caught in the nick of time without anything in the smashing into something it shouldn't.
There's some debris in the filter but not as much as one might think(somehow?).
I am assuming there's more deposited in deep and dark areas of the M96s oiling system, the bearing was utterly shafted and I think 50 more miles and it would have collapsed.
What's the general consensus on what to do at this point?
Kind Regards,
DarthFaker.
Poker2009
PostPosted: Sun Dec 08, 2019 7:50 am    Post subject: Reply with quote
Cough up and book it in at Hartech, or list on autotrader for a few thousand.
997.1 C2S, Black, Coupe, 6-Speed Manual, Ohlins R&T.
Millers NT+ 10W50, driven above 3000 RPM.. original engine.
GMG
PostPosted: Sun Dec 08, 2019 7:51 am    Post subject: Reply with quote
...sorry to hear this...
Same thing happened to me; bearing shaft snapped destroying the shaft. The biggest issue is the swarf which will be deposited all through the engine...
Consequently my independent changed many parts; all of the oil pumps, tandem pumps , camshaft actuators, solinoids etc, etc....
I also had new liners,pistons and rings and the heads over hauled.
The final bill was close to £14 k !
Once the case has been split you will have an idea of the damage caused and from this create a plan.
Good luck...
Griffter
PostPosted: Sun Dec 08, 2019 8:10 am    Post subject: Reply with quote
Either:
Fit a new bearing in situ and cross your fingers
or
Get a rebuild, being pleased you can reuse crank shaft, pistons etc and get the newer bigger IMS bearing at the same time
It’s a question of risk appetite and how long you want to keep the car IMHO.
adamw
Estoril
1998 Porsche 996 Carrera 2
PostPosted: Sun Dec 08, 2019 8:56 am    Post subject: Reply with quote
Sorry to hear this
Just out of interest, is the bearing shaft letting go different to normal bearing failure?
Dont know
98’ 996 C2 aero, Swartz Black, GT3 style fixed buckets, GT3 momo steering wheel, GT3 wheels, KW’s + lots more
EX : 02' 996 Turbo Coupe ( May 17 - Sept 19 )
GMG
PostPosted: Sun Dec 08, 2019 9:33 am    Post subject: Reply with quote
...sorry typo! The stud on the ims snapped which destroyed the bearing which in turn damages the shaft ... the swarf is the real killer...gets deposited everywhere as a consequence of the oil pumps which keep pumping during the bearing failure...
Ignore the advice to install a new bearing Dont know
adamw
Estoril
PostPosted: Sun Dec 08, 2019 11:21 am    Post subject: Reply with quote
Ok - cheers
Is that stud part of the actual IMS bearing assembly?
When you said shaft, I thought I hadn’t heard of the actual shaft letting go.. does this happen
What year / car is yrs ?
berni29
Watkins Glen
PostPosted: Sun Dec 08, 2019 12:19 pm    Post subject: Reply with quote
Hi
I'm a 993 owner so from the comfort of my armchair I can say that I would phone Hartech and see what my options are with them.
If it were my car I would drop the engine myself, dismantle it, send off the block etc for machining (at Hartech for me) replace what needs replacing then put it all back together myself etc.
Berni
993 C2 Tip 1994 187k miles. Black and Grey. M029 & Bilstein HD's, Elephant Racing RS bushes F&R, RS mounts, strengthened engine carrier, 100 cell cat inserts, HID's. Solid steering arms mod, top of the engine rebuilt, mapped by Wayne, suspension set up by Chris.
GMG
PostPosted: Sun Dec 08, 2019 1:55 pm    Post subject: Reply with quote
...the stud is part of the ims bearing assembly and early ones are so under engineered that they can snap off leading to an expensive mess !
You have essentially two choices...rebuild or sell as is ?
Just be prepared to dig deep as you can expect to need to replace parts as part of the rebuild that weren't necessarily impacted by the failure...
Good luck.
JTT
PostPosted: Sun Dec 08, 2019 2:22 pm    Post subject: Reply with quote
Assuming it is just the bearing and not the shaft as previous poster experienced, I'd do some investigation first before taking drastic measures.
Since you already checked the filter, next step is to drop the sump and have a look in there.
Next pop off the swirl pots on the oil return. The bottom of these twist off (1/4 turn lock). Have a look in the bottom of the pots. These are fed straight from the heads, so will often show up any swarf that has passed through the heads.
You can then pull off the oil pump and scavenge pumps on each head and have a look in there for glitter.
If you find glitter or swarf in any of these, your back to drastic measures. I had an IMS bearing failure that I caught in the very early stages. Personally I got lucky on mine, and I put it largely to using a zero bypass spin on filter (with adaptor). I had zero debris in any of these locations, only small amount in filter.
Don't panic. Think methodically and logically, but start preparing.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Dec 08, 2019 3:29 pm    Post subject: Reply with quote
The best way to clear all the swarf out is to strip the engine completely but it depends how much you want to spend as this is a lot of money considering the engine hasn't failed as such, but this will give you a chance to inspect everything and renew things that could fail in the future, chains and guides etc.
I would rebuild my own engine so its not too much of a problem but if it needs to go away it'll cost a fair bit.
The other option is to fit an IMSB in situ, remove the sump and clean that up plus fit a magnetic sump plug, change the oil (using some cheap oil) and filter, run the engine and repeat that again to flush the engine. This is risky for obvious reasons but I would think doing a few oil and filter changes would give you a good idea if you have cleared it all out eventually.
I have heard stories of engines having metal swarf in them from new but never going around the engine and only spotted because the engine has been apart.
dc2100k
PostPosted: Sun Dec 08, 2019 3:49 pm    Post subject: Reply with quote
Darthfaker, what symptoms did you have of failure? Was it caught on a routine oil change? I take it you’ve got the box off the car now, what does the IMS feel like - notchy? If the bearing hasn’t collapsed how much debris do you think it could realistically give up?
DarthFaker
PostPosted: Sun Dec 08, 2019 4:28 pm    Post subject: Reply with quote
It was caught during an oil change, the engine and box are out at the moment. Still being investigated.
I'll post a video of the condition of the bearing later down the line, at the moment there's a liability dispute on going so Im reluctant to release too many details atm.
dc2100k
PostPosted: Sun Dec 08, 2019 5:30 pm    Post subject: Reply with quote
Was this the original bearing or a replacement?
I guess it all boils down to whether you want to rebuild the engine or not. Given the discussions in the insurance thread about writing off cars for a minor bump to the rear then realistically any normal 996 needing a full rebuild is a write-off without even factoring the cost of any upgrades you might do whilst it is apart.
As I see it these are your options:
Option 1: sell for parts
Option 2: do actions as JTT advises, replace IMS and run without problems (cost £2k?)
Option 3: do actions as JTT advises, replace IMS and it blows up; sell for parts
Option 4: do actions as JTT advises, replace IMS and it blows up, complete engine replacement at c. £15k?
Option 5: complete engine rebuild of existing now at c. £12k.
I would have thought if there is at least a reasonable chance of option 2 happening it would be the best course of action.
mar1b0ro
PostPosted: Mon Dec 09, 2019 1:08 pm    Post subject: Reply with quote
Option 6 - put car back together, drive into nearest tree at 30mph avoiding cat that came out of nowhere, claim for total loss on insurance.
In the land of the blind, the one eyed man is king.
EGTE
PostPosted: Mon Dec 09, 2019 1:51 pm    Post subject: Reply with quote
That is of course fraud, well done.
Dammit
PostPosted: Mon Dec 09, 2019 2:44 pm    Post subject: Reply with quote
What model is the car in question?
bazhart
Approved Trader
PostPosted: Mon Dec 09, 2019 3:30 pm    Post subject: Reply with quote
E-mail our Sharon on admin@hartech.org and ask for the report on the 4 main weak spots in these engines (one of which is the ims bearing) and she will send you a lot of detailed information about the problem and alternatives solutions - FOC.
Baz
Click here for the Hartech
www.hartech.org
DarthFaker
PostPosted: Mon Dec 09, 2019 3:53 pm    Post subject: Reply with quote
Baz
Hi Baz,
She sent me it about 2 weeks ago I'm still reading it, I've spoken to Grant a few times recently too. You guys are super helpful.
DarthFaker
PostPosted: Mon Dec 09, 2019 3:55 pm    Post subject: Reply with quote
1999 Carrera 4 with an M96/02 3.4L
