997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
dave421
PostPosted: Fri Dec 06, 2019 11:23 pm    Post subject: Can I lift the car on the cills with a scissor car lift ? Reply with quote
Hi
I have purchased a mid hight scissor car lift. It is the type that has two long flat plates either side the run under the cills. You have to put the black rubber blocks between the ramp plates and the car, my questions is can the rubber blocks go on the cill lip pointing down (like a 2 post ramp) or do I have to put them under the jacking points? TIA.....
MJK1
PostPosted: Sat Dec 07, 2019 7:47 am    Post subject: Reply with quote
Use the jacking points, sills are not designed to support the weight of the car.
Rojdog
PostPosted: Sat Dec 07, 2019 9:19 am    Post subject: Reply with quote
As above, also I doubt you will be able to get the under trays off if resting on sills.
911tom
Watkins Glen
PostPosted: Sat Dec 07, 2019 9:27 am    Post subject: Reply with quote
You definitely do not want to do that! I use something similar to these on my lift.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F123439684508
996 Turbo - Link to my 3.8L turbo build thread
2011 Cayenne
718 Cayman GTS
350Bhp astra van for work, semi-retired from daily duties
2009 Ariel Atom 3 Supercharged SOLD but never forgotten
dave421
PostPosted: Sun Dec 08, 2019 10:09 am    Post subject: Reply with quote
Hi
Thanks everyone, jacking points it is Thumb
Rojdog
PostPosted: Sun Dec 08, 2019 10:53 am    Post subject: Reply with quote
Never seen those before they look fantastic. Just ordered a similar design rubber set, have been using blocks of wood which can make it awkward. Thanks!
jl-c
PostPosted: Sun Dec 08, 2019 11:52 am    Post subject: Reply with quote
You are better off using the hard rubber version of the “puck” as the metal ones remove the paint/ sealant from the jacking points and then ………………………… they rust Surprised
[url] https://www.ebay.co.uk/itm/Porsche-Axle-stands-Jack-pads-Tough-Rubber-911-964-993-996-997-991Cayman-Boxster/273516844526?hash=item3faedfd5ee:g:u~EAAOSwwgVd7Lxs[/url]
easternjets
Watkins Glen
PostPosted: Sun Dec 08, 2019 2:39 pm    Post subject: Reply with quote
There used to be a member on here that sold the solid plastic/resin jack point inserts, I have 2 and they are a must have.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
SRDavis
PostPosted: Sun Dec 08, 2019 5:10 pm    Post subject: Reply with quote
Or try these;
https://www.amazon.co.uk/Universal-Porsche-Polyurethane-Protector-TMB/dp/B01LZYGI63/ref=sr_1_5?keywords=porsche+jack+pad&qid=1575824883&s=automotive&sr=1-5
Simon
2007 997.1 Targa 4 Cobalt Blue
Rojdog
PostPosted: Sun Dec 08, 2019 6:07 pm    Post subject: Reply with quote
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F254221927798
I went for these x 4 for £26 and single piece design.
jl-c
PostPosted: Sun Dec 08, 2019 7:17 pm    Post subject: Reply with quote
And so did I ! Thumb
dave421
PostPosted: Mon Dec 09, 2019 10:42 pm    Post subject: Reply with quote
Hi All
Thanks for the suggestions, im interested in the 4 jack pads for £26. Do you push these into the jacking points and twist so they stay in ? im using a scissor ramp. TIA
easternjets
Watkins Glen
PostPosted: Tue Dec 10, 2019 12:16 pm    Post subject: Reply with quote
Yes locate and twist through 90 degrees, easy in and out.
997 Turbo Gen 2
Porsche 928 S4
dave421
PostPosted: Tue Dec 10, 2019 8:25 pm    Post subject: Reply with quote
Hi
Thank you, I will order them now thumbsup
Clanky
2007 Porsche 997 Turbo
PostPosted: Tue Dec 10, 2019 10:42 pm    Post subject: Reply with quote
I have the alloy ones which I put thin gasket rubber on between the alloy & where they sit. Perfect for lifting.
As a testament to how well they fit, I forgot I had them fitted & drove the full NC500 with them still attached! They stayed in all the way.
Stupid mistake which I wont make again!
996 C4s (Gone)
997 Turbo
S3 Daily Driver
