997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
Kendo88
PostPosted: Fri Dec 06, 2019 12:34 pm    Post subject: 997 exhaust tails olive ring Reply with quote
Just got new exhaust fitted and got new olive rings as old ones are shot. Do these need to be cut I take it to fit between exhaust and clamp?
PostPosted: Fri Dec 06, 2019 12:49 pm    Post subject: Reply with quote
do you mean this thing ,They normally have a section cut out to allow them to clamp up when tightened , most old ones break into 3 pieces when removed. Thumb
 Filesize:  8.75 KB
 Viewed:  941 Time(s)
Kendo88
PostPosted: Fri Dec 06, 2019 11:51 pm    Post subject: Reply with quote
Yes that's it but one guy said not to cut. Think I'll just take it to garage that changed my exhaust instead of doing myself
PostPosted: Sat Dec 07, 2019 9:48 am    Post subject: Reply with quote
it does need a bit cut out as it needs some movement for compression of the exhaust clamps . Thumb
bullet-proof_biscuit
PostPosted: Mon Dec 09, 2019 7:46 am    Post subject: Reply with quote
Yes cut a 3mm slot in it, exhaust tips need a 13mm socket. Easy job
