997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 29
Cayman : 2005- 22
Macan : 2014- 7
freddie44
2007 Porsche 997 GT3
PostPosted: Wed Dec 04, 2019 11:01 am    Post subject: Single mass flywheel Reply with quote
Thinking to upgrade to a single mass flywheel at clutch change time next year but would really like to hear one in situ before I commit.
Anyone near West London, Berks area with a single mass in a 996/997 GT3 I could come and stick my ear to?
Anyone had experience with the swap from dual to single?
I'm only cautious as I like to use the GT3 as an all-rounder not just tracks (but also tracks)
crash7
PostPosted: Wed Dec 04, 2019 5:08 pm    Post subject: Reply with quote
I have one fitted to a 996 C2 and am in Berks if it helps.
freddie44
PostPosted: Thu Dec 05, 2019 11:11 am    Post subject: Reply with quote
Brill, PM'd you
Diggermeister
PostPosted: Thu Dec 05, 2019 11:48 am    Post subject: Reply with quote
Interesting to hear your findings. It's an upgrade I'd often wondered about.
FWIW I had the Guards, Cup style diff ramps put in my LSD earlier in the year and it was a definite improvement. Even in my hands.
Kryton
PostPosted: Thu Dec 05, 2019 4:20 pm    Post subject: Reply with quote
Think you'll regret fitting one if your car's a daily.
I had a ride in a GT3.1 single mass and the bag of nails sounds was horrendous.
The GT3.2 had a twin plate and that bag of nails sound had gone thank god!
2019 718 Boxster
2020 Weissach GT3 RS
Stuart
2004 Porsche 996 GT3 Mk2
PostPosted: Fri Dec 06, 2019 9:02 pm    Post subject: Reply with quote
One of the best things you could do for the GT3. Like everything it soon becomes the norm, I used mine in central London traffic all the time, not a problem. Noise is slightly increased but again you get used to it and certainly adds to the visceral GT experience.
freddie44
PostPosted: Sun Dec 08, 2019 8:15 am    Post subject: Reply with quote
Great to hear Stu Thumb
Going to sample next week
Roro
PostPosted: Sun Dec 08, 2019 7:08 pm    Post subject: Reply with quote
Subscribed Cool
2007 997.1 GT3
2017 F87 M2
Senoj
PostPosted: Sun Dec 08, 2019 7:38 pm    Post subject: Reply with quote
It’s fab for improving throttle response. Not massively noticeable in gear as the drivetrain is loaded up though intensely noticeable when h an t and blipping for a downshift.
Only comment would be that pedals on 997 are not brilliantly placed for H and t on the road. Track is fine but road driving it’s harder to get the brake pedal down far enough unless performing a massive stoppie.
freddie44
PostPosted: Mon Dec 16, 2019 1:18 pm    Post subject: Reply with quote
Thanks for comments!
Having been able to sample a GT3 with a SMF fitted I'm 100% sold.
No real downsides and adds another element of fun. Defo going for it Thumb
Diggermeister
PostPosted: Tue Dec 17, 2019 11:47 am    Post subject: Reply with quote
Any idea of budget yet?
Are you doing this because the clutch needs changing anyway?
crash7
PostPosted: Tue Dec 17, 2019 1:48 pm    Post subject: Reply with quote
You will need.,
Flywheel, TTV / Aasco - I have a contact if anyone is interested.
Uprated sprung clutch, - Sachs.
Also worth going for a performance pressure plate - Sachs
Replace the release and spigot bearings (Sachs & Porsche) while your in there as well as new flywheel bolts. (ARP)
Circa - £1600 on parts.
NXI20
Paul Ricard
PostPosted: Tue Dec 17, 2019 4:58 pm    Post subject: Reply with quote
Use the 964 flywheel & the 4.0L clutch pack. Stick to Porsche stuff throughout the job, release bearing, tube & fork all worth changing while you're in there.
Nick
freddie44
PostPosted: Thu Dec 19, 2019 10:03 am    Post subject: Reply with quote
Thanks Nick and hope you're well!
Need to get the diff checked too - cup plates?
NXI20
Paul Ricard
PostPosted: Thu Dec 19, 2019 11:45 am    Post subject: Reply with quote
Yes, standard ones are chocolate
Nick
Diggermeister
PostPosted: Thu Dec 19, 2019 4:09 pm    Post subject: Reply with quote
crash7 wrote:
You will need.,
So if/when you need a clutch, a very opportune time to make the upgrade then.
FWIW, got my Guards plates from JZM as I couldn't find any OEM motorsport ones at the time I was buying.
-ollie-
PostPosted: Sun Dec 22, 2019 6:26 pm    Post subject: Reply with quote
If fitting a LWFW to a non RS 997 GT3 it is imperative you also fit an OEM 997 RS crank damper at the same time.
If you do not, the non RS damper will be out of balance with the rest of your now modified rotating assembly, the bolts will vibrate lose and the damper will fall off.
I know this for fact, as I did exactly that. Lost power steering, alternator etc and had to get recovered.
Fitted the RS damper, been perfect for 1000's of miles on circuit since.
Learn from my mistake! Thumb
RS & non RS dampers are different - they look different, have a different part number and are even a different colour for this reason alone - you need it.
freddie44
PostPosted: Mon Dec 23, 2019 3:05 pm    Post subject: Reply with quote
Thanks Ollie - message understood Grin Do you know the two different part numbers?
Yes Digger good time to make the change Thumb
Cheib
PostPosted: Fri Dec 27, 2019 10:16 am    Post subject: Reply with quote
There’s a bit on the Sharkwersk website about it.
https://www.sharkwerks.com/transmission/p4056-porsche-lightweight-flywheel-clutch-upgrade-kit-for-996-997-997-2-gt3-rs-4-0-964-PORT154
I believe RPM have some experience of doing this....might be a worth a visit just to pick their brains.
997 GTS Manual
Cayenne S Diesel
Ruby Star 718 Boxster - Mrs Cheib's car
Lava Orange 991.2 GT3 Manual
Sport Classic Grey Macan Turbo PP
-ollie-
PostPosted: Fri Dec 27, 2019 9:49 pm    Post subject: Reply with quote
Laughing Apologies, I was keen to make sure it was personal experience I was referring to rather than learned internet hearsay Thumb
I don't know the part numbers, but a quick call to Matt @ Fearnsport and he'll be able to tell you Cool
Enjoy your noisy rattly flywheel, it will sound totally broken when the 'box is hot at idle at traffic lights. Great for making passengers thing your car is a hound, but even better for heel & toe downshifts/rev matching on circuit thumbsup
Ollie
