997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
Moko
PostPosted: Mon Dec 02, 2019 8:40 am    Post subject: Month Storage Question Reply with quote
I am going to be away in December (work/holiday) and hence my car is not going to be driven during that time. Normally I drive it at least once a week and it always starts first time with no problems and the battery holds charge well.
It’s stored in a garage with no electricity supply so trickle chargers etc are out of the question.
So what’s the best thing to do? Disconnect the battery? Leave it and hope for the best? Or is there something I should do to preserve the charge?
Your suggestions are most welcome
Porsche 996 Carrera 02 Tiptronic Seal Grey
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Dec 02, 2019 9:22 am    Post subject: Reply with quote
I would disconnect the battery of it is stored somewhere secure.
PostPosted: Mon Dec 02, 2019 9:37 am    Post subject: Reply with quote
If you disconnect the battery don't forget to leave the frunk open.
mikeluke
PostPosted: Mon Dec 02, 2019 9:42 am    Post subject: Reply with quote
Is there any way that you could connect a solar trickle charger? They are not fantastic but probably enough to keep the car topped up whilst you are away
Current:
981 Boxster S PDK
BMW X5 4.0d M Sport
BMW M140i (Mrs L's)
VW Polo Match 1.2 (the lad's)
Former:
996 Turbo S Cabrio Manual
996 Turbo Coupe Tip
968 Cabrio Manual
Lee997
PostPosted: Mon Dec 02, 2019 9:48 am    Post subject: Reply with quote
You could connect another charged battery alongside your giving your car at least double its usual power supply.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Dec 02, 2019 9:58 am    Post subject: Reply with quote
I would be inclined to disconnect the battery, because getting at the flat battery if the frunk is shut is a right pain, also flattening the battery is not good for it.
As said above, leave the frunk open and if I were you leave something in the way of the latch as it’s surprisingly easy to forget and close it!
Moko
PostPosted: Mon Dec 02, 2019 4:18 pm    Post subject: Reply with quote
Thanks guys....disconnection of the battery it is and I will put a towel or something to prevent Frunk locking/closing.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon Dec 02, 2019 4:46 pm    Post subject: Reply with quote
Just leave it. I sometimes leave mine for a month and no problems (except, er, when I had a weak battery and a tracker draining it...).
It's just a car.
diverzeusy
PostPosted: Mon Dec 02, 2019 9:03 pm    Post subject: battery Reply with quote
Surprised no one has said,
take the battery off the car, take it home or where an electricity supply is available and put it on the trickle charger then it will be perfect and ready to take back and start the car Thumb
And yes put something under the bonnet to stop it fully closing Rolling Eyes
