997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
SRDavis
PostPosted: Sun Dec 01, 2019 8:26 pm    Post subject: Flat battery; causes? Reply with quote
After not using the car for 2 weeks, the battery was as flat as a pancake. I've read many posts about how to use a second battery to start the car and lots of debates about makes of batteries and chargers, but haven't found anything that says why 997 batteries go flat.
I have a circuit tester but not much expertise with vehicle electrics, so can anyone tell me, (as in giving facts, not hearsay / opinion), as to what are the typical causes of battery drain on our cars?
Simon
2007 997.1 Targa 4 Cobalt Blue
PostPosted: Sun Dec 01, 2019 9:02 pm    Post subject: Reply with quote
An interesting question .. the reasons ...
Lack of use .. the battery will always have a discharge but it's in the 30 milliamps range .. so approx 5-6 weeks for a new fully charged battery to get to 9 Volts .. ish so that there is not enough power to spin the starter fast enough .
less for an old battery .
As above but short journeys .. more out of the battery than in .
A poor performing alternator .. you may not get a battery light but you can get a low voltage from the alternator .. to test you always have the engine running and all electrical loads turned on .. ie lights , seats , blower fan at max ..
You want at least 13 volts at this point .
An electrical discharge .. something drawing a current .. a Tracker is a possible .. roughly a 1 amp intermittent discharge every 30 seconds .
Constant 1 amp and its a radio or an alternator fault .
Pulsing 6 amp and its stuck seat button .. i could go on here ...
An old tired battery that cant hold its charge .
Those are the obvious reasons and you always test with a seperate voltmeter .
NLW73
PostPosted: Mon Dec 02, 2019 8:07 am    Post subject: Reply with quote
cold weather and lack of use.
if your battery is a few years old and you don't use it then this recent drop in temps will just kill it. especially when it goes sub zero. same with a normal phone when you are out in low temps. battery life just drops
when you are asking it to crank a big lump then its like no thanks. plus all the electrics running in this weather such as heating and lights and heated seats etc.
997 C2s Schwarz
timbo1811
PostPosted: Mon Dec 02, 2019 10:01 am    Post subject: Reply with quote
The alarm uses a bit, if you are in a position where you dont need to lock it it will last longer.
Lotus Elan, Lotus Elan +2, MGA Mk11, TR4, 230 Compressor, 320 coupe, 944, Boxster 2.7, 997.1(current), VFR 1200, CBR 1100 Blackbird
chunkymonkey1982
PostPosted: Mon Dec 02, 2019 10:23 am    Post subject: Reply with quote
I’ve read up on this too. I had the same issue a few months back. What I found out was that my battery was 3 years old, and was a genuine Porsche one which I understand are not the best battery. My car also has a tracker that drained the battery. Replaced with a Bosch equivalent, no issues. Had not used the car for 2 weeks and started no issues yesterday.
C4Silver
PostPosted: Mon Dec 02, 2019 10:37 am    Post subject: Reply with quote
At this time of year the number 1 contributing factor to a car battery health is Weather,
The battery may well be tired and old, the Alarm will drain some a tracker will also drain but the weather will highlight any issues pretty sharpish especially the past few nights of sub zero temps we have had around here.
Another effect that i think often gets over looked, the battery is away from the engine compartment and doesent have the benefit of being kept warm for a few hours after the car is parked up,
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Mon Dec 02, 2019 11:04 am    Post subject: Reply with quote
This /\/\/\
A 911 battery is always more likely to go flat, the cable run from front to back is a power sapper, and as said above it is physically colder than a battery stored in an engine compartment (im sure this is a good thing in a hot country...)
I also think the standard battery is an engineering compromise of power to weight, whereas on a bog standard hatchback an additional half a kilo doesnt matter, so a battery will be slightly larger and therefore have a better capacity than is required, a 911 battery is right on the edge and therefore has to be kept in top condition. Thats only a theory though Floor
My 997.1 C2 ownership thread: http://911uk.com/viewtopic.php?t=134228
C4Silver
PostPosted: Mon Dec 02, 2019 11:41 pm    Post subject: Reply with quote
Floor
As theories go it’s about as un scientific as mine...... it’s just one of those things that works in my head when I think 💡
If the engine bay was keeping the battery warm it would stay in better condition......
I know a lot of More modern cars have the battery in the rear floor under the boot floor, I have a car with a battery in the wheel well, it’s about twice as big as the 911 battery.
-- 997 --
PostPosted: Tue Dec 03, 2019 2:09 pm    Post subject: Reply with quote
When my car is locked up and i dont use it a while i disconnect the battery! Even now in winter its all disconnected!! Safer in my opinion!
J
PostPosted: Tue Dec 03, 2019 7:27 pm    Post subject: Reply with quote
If your going to leave a bonnet open then its always best to drop the latch ..
By this i mean ...
use a screwdriver flat blade .. push the lock down a small amount and you will see a bar start to move from the o/s to the n/s ..
Put the screwdriver behind this and move it towards the n/s whilst pushing down a bit .
You are doing what the bar in the bonnet does basically .
Latch locked and there is no way it can be shut accidentally .. you can also alarm the car should you wish if not disconnecting the battery .
Something i do many times per day to turn off the bonnet interior light .
