997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
Epsom996
PostPosted: Sun Dec 01, 2019 6:40 pm    Post subject: Just bought my second 996 Reply with quote
Hello. I’m a newbie here but just bought my second 996. 1999 c4s cab with loads of history and immaculate bodywork. It’s got a couple of faults; squeaky windows and a mystery ticking sound on idle but I’m very happy. Should I be worried about the ticking noise though ?
fot0
PostPosted: Sun Dec 01, 2019 7:16 pm    Post subject: Reply with quote
The ticking could be sticking hydraulic tappet, but will usually disappear when engine warms up and oil gets hot. Could be a noisy injector.
Squeaking window usually passenger side can be fixed with silicon spray. May take a while to disappear with use unless you take door card off for direct access to mechanism.
Epsom996
PostPosted: Sun Dec 01, 2019 7:18 pm    Post subject: Reply with quote
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon Dec 02, 2019 2:04 pm    Post subject: Reply with quote
how many miles? Thicker oil quietened mine down a lot.
Still ticks at idle when cold a bit not after a few mins or when hot. 0w40 has no place near a 100k+ engine IMO.
Squeeky windows- form the door seal or mechanism?
If mechanism, door card off and regrease sliders and cable.
Door seals wear the felt off leaving the rubber to squeal on the window. New doors seals are well over a hundred each.
I use gummi fledge on mine (google it) and polish the glass, cuts it down a lot.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Dec 02, 2019 2:26 pm    Post subject: Reply with quote
+1... I clayed the windows, and coated with RainX. I also clean the felts inside of the seals, and pull them 'away' from the window all along the top of the door from time to time. Seems to have largely shut them up apart from hot days.
