997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
Moko
PostPosted: Sun Dec 01, 2019 4:42 pm    Post subject: Electronics Problem Reply with quote
I installed a new single DIN radio yesterday using a harness from Dynamic Sounds....I took the dash binnacle off to route the phone mic during the process the tiny locking tab that you have to depress before you unlock the bigger black tab broke on the grey connector.
Today when I drove the car I noticed the following things Reversing sensor stopped working, the computer control arm is unresponsive, dash centre display is stuck and most importantly Tiptronic switch’s on steering wheel don’t work.
All other electronics....lights, wipers indicators and the new radio are all working perfectly.
The only other thing I think may have happened is the new wiring harness has dislodged something inside the dash
So what have I done? Where should I look to solve the problem?
Porsche 996 Carrera 02 Tiptronic Seal Grey
 Filesize:  116.24 KB
 Viewed:  329 Time(s)
PostPosted: Sun Dec 01, 2019 4:52 pm    Post subject: Reply with quote
As per the image these items all go into Plug C which is the grey plug.
It's not making a good connection so have a look if its come loose .
 Filesize:  237.9 KB
 Viewed:  319 Time(s)
Moko
PostPosted: Sun Dec 01, 2019 5:41 pm    Post subject: Reply with quote
Thanks as always that does look exactly like the list of what’s not working.
Do you think just pushing the connector back in harder should fix it? I guess after 18 years the tiny plastic parts will get brittle.
The big black lever part was ok and went back down so there maybe a way to fix it but if anyone has any suggestions I would love to hear them.
PostPosted: Sun Dec 01, 2019 5:47 pm    Post subject: Reply with quote
see if its loose first .. if the black lever has no tab left and it wont stay closed then a small piece of duct tape perhaps to keep it in position .
Check the pins as well .. worst way and one is bent so forcing it in will only make it worse .
maldren
Usually ok on a hot summer day but they're especially brittle in this cold weather, a blast from a hairdryer can help.
Mike
Moko
PostPosted: Sun Dec 01, 2019 8:02 pm    Post subject: Reply with quote
The Force will not be strong with this one... Very Happy
I will check the pins are ok before doing anything....duct tape maybe the answer
PostPosted: Sun Dec 01, 2019 8:27 pm    Post subject: Reply with quote
Floor
Trust me .. after all these years i have learnt that if you have to force something .. then something is wrong !!!
tape is best as glue and you cant remove it again .. it may not look pretty but it will work Very Happy
Moko
PostPosted: Thu Dec 05, 2019 12:47 pm    Post subject: Reply with quote
Once again you were absolutely right....a little bit of contact cleaner on the plugs and some gaffer tape to hold it in place and everything works perfectly Very Happy
So thanks again for all of your posts ....for some of us they are an absolute god send. thumbsup
