997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
k11pol
PostPosted: Sat Nov 30, 2019 8:02 pm    Post subject: Is it possible to upgrade PCM on 991.1 Reply with quote
Is it possible to upgrade the PCM on my 99.1 to the newer 991.2 version as im going to fit a reversing camera so ideally if the upgrade is possile to do it at the same time.
PostPosted: Sun Dec 01, 2019 9:19 am    Post subject: Re: Is it possible to upgrade PCM on 991.1 Reply with quote
Not possible and would surely be cost prohibitive. It’s one of the ways manufactures convince us to buy newer motors with better tech, so unlikely to be ever offered. You’d be looking at something like this for similar functions
http://www.naviplus.com.au/online-store/Porsche-PCM-3-1-Integrated-Apple-CarPlay-%26-Android-Auto-Upgrade-Package-p91428805
991 C2S PDK - X51 430 powerkit, Carbon GT2 folding buckets, PCCB, PDCC, PSE, Carrera S alloys, Sports design bodykit with ducktail and Alcantara steering wheel. If Carling did a 991S...
“Herman yellow, the last of the naturally aspirated. ”YKIMS"
Apparently other colours are available?
k11pol
PostPosted: Sun Dec 01, 2019 4:31 pm    Post subject: Reply with quote
That looks perfect I will have a thorough look at it when finished shift and see if it’s available in uk.
short-shift
PostPosted: Sun Dec 01, 2019 4:56 pm    Post subject: Reply with quote
Actually... there's a guy (I think it was on Rennlist) who has done exactly this but in my view you'd need to seriously deranged to attempt it. Not just the hardware and coding issues, but huge firmware challenges as well, from what I recall.
However, a reputable source for integrated reversing camera and CarPlay electronics for retrofitting to PCM3.1s is NM Automotive, based in Jersey. Also sells through eBay, I think. Link is here: https://www.nmautomotive.co.uk/carplay-androidauto
James
k11pol
PostPosted: Sun Dec 01, 2019 6:49 pm    Post subject: Reply with quote
Yea, i googled that earlier and thats exactly what i would like so once im home i will give them a call.
Jungle650
PostPosted: Mon Dec 02, 2019 1:19 pm    Post subject: Reply with quote
You can get a reversing camera retro fitted for circa £ 500-600.
http://911uk.com/viewtopic.php?t=132211
The main reason to upgrade the PCM is I presume for Apple Car play??. This You tuber ( Auto Amateur ) has recently done it. Might be worth a look.
https://youtu.be/B8zgCdINaAs
Jungle
991.1 C4S
Full Xpel Ultimate PPF
And loving it !!
JoPork
PostPosted: Mon Dec 02, 2019 7:51 pm    Post subject: Reply with quote
I considered it myself after reading the Rennlist thread. CarPlay can be added anyway with the NMAuotmotive kit, but really the PCM4 is just a better screen and experience. I tried a couple of well know Porsche specialists to see if they would undertake it but the problem is apparently coding the new unit to the car, basically Porsche won’t supply the code to put PCM4 into a 991.1 even though it would work. Other issue is that you would need a different Bose or Burmester amp as well because the connection is different. I think give it time and somebody will come up with a solution, there certainly appears to be a lot of interest in doing this, probably indictIve of the number of people that intend to keep their 991.1 for a while.
I’m also intending to get TPMS retrofitted at some point. Mine is a 2013 so not standard fit
Jo
