997 : 2004- 65
Boxster : 1997- 31
Macan : 2014- 6
FZP
Estoril
PostPosted: Mon Nov 25, 2019 3:58 pm    Post subject: A bit of DIY, a bit of parts supply Reply with quote
So I have a few items that I need to tick off the list, and with ECP doing the black Friday sales at 50% off, I thought I'd buy the bits I need in one hit.
Discs and Pads. This is the first time I'll be changing them since I've had the car, can anyone tell me what brand the OEM are. I want to say Brembo, but not sure. I'll be getting my local mechanic to do the as I'm not one to muck around with brakes. A brake line is looking tatty so will get that done at the same time.
A/C Condensors. Mine need replacing and as I want to do the mesh inserts from behind, thought I'd have a crack myself at swapping them out. I'm going to go with Behr Hella as these are the OEM units, but can you advise everything I'll need to do the job parts wise to complete the job. Also any gotchas I need to be aware of whilst doing it.
That ticks off the health check and back up to scratch.
TIA
FZP
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Nov 25, 2019 4:20 pm    Post subject: Reply with quote
Don’t forget wear sensors and anti-vibration pads too, unless you plan to see if the existing ones can be reused.
I reckon if you fancy doing the condensers you could do the brakes too. Even I managed it.
systech1
PostPosted: Mon Nov 25, 2019 10:25 pm    Post subject: Reply with quote
I believe Porsche use various brake manufacturers but have read that the disks are mainly Sebro and the pads are Textar. However I’ve used Pagid and Brembo and they are in my view at least as good.
Long time Porsche fan. Previous cars include 911T 2.2, 911E 2.2, Carrera 3.0, 986 Boxster S. Current car is 997.2S Manual (with PSE, H&S Backbox bypass, Sports Chrono, SSK, DSC PASM controller, Carrera Sports wheels, Ducktail/Diffuser and splitter, Sport Design steering wheel etc.)
PostPosted: Mon Nov 25, 2019 10:43 pm    Post subject: Reply with quote
What's the score with pads and OPC warranty if they are not OPC supplied Dont know
Re the condensors I'd go for the cheap ones as they're almost a replacement part and if you protect them they should last probably longer than you keep the car.
I paid £75 for the evaporator in my 964 against £300+ for OEM rose tinted plated one Rolling Eyes Never had a problem
The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Nov 25, 2019 10:44 pm    Post subject: Reply with quote
I bought a cheap condenser for my 996 and had to send it back as it didn't fit. Behr/Hella was only a tenner more.
Billy Bumpsteer
PostPosted: Tue Nov 26, 2019 8:01 am    Post subject: Reply with quote
You cant get true OEM discs, Sebro are certainly OEM quality though. Textar are OEM on the pads.
I would think DIY on the brakes is easier than the condensers? Dont know
MisterCorn
PostPosted: Tue Nov 26, 2019 8:21 am    Post subject: Reply with quote
I think they are pretty similar, the brakes can be a PITA is you get stuck bleed nipples or problems removing caliper bolts. One of those jobs which is easy in theory but can be anything but. Never had any real issues with condensers but then I have done a lot more sets of disks and pads.
PostPosted: Tue Nov 26, 2019 7:21 pm    Post subject: Reply with quote
Brakes are not really covered on the extended warranty so not really a problem .. best not to try and claim for a brake squeal with these fitted though Smile
Biggest issue is on a 111 point check to renew the warranty .. if the brakes look like non porsche then it will fail under the NO third party items fitted rule .
It all comes down to if they look like genuine parts or not .
Bearing in mind we don't take the wheels off for this check so it's not much more than cursory glance ..
If they look like porsche parts then it will pass .
For any warranty claim then if non Porsche parts have been fitted the mechanic / Porsche have to decide if these items have caused the problem being claimed for ...
ie a non Porsche battery will have no effect on a blown engine so they cant reject the claim based on that .
Grills fitted .. whilst on the outside limits could be argued as hindering airflow and there by overheating the engine .. extreme i know but you get the idea .
A solid flywheel ( non dual mass ) and a snapped crankshaft which was a warranty claim has been rejected in the past .. a definite link as porsche put it .
v6matt
PostPosted: Tue Nov 26, 2019 10:13 pm    Post subject: Reply with quote
I never find ECP that cost effective for Brembo brakes, as they sell in singles.
Go to Brembo's website and get the part code, stick it into a few other websites such as Autodoc, Amazon and partsinmotion.
Would be surprised if they werent better value.
Oh and also try carparts4less, as this is the sister site to Eurocarparts but a much lower base price plus 20% off via voucher typically.
2008 Carrera 4 - Gen 1 997
FZP
Estoril
PostPosted: Fri Nov 29, 2019 7:39 am    Post subject: Reply with quote
So last night I was watching a few "how to" videos on swapping out discs and Pads. By the time go get all the tools recommended, along with pastes and sprays that I need, but I don't have, it's going to be cheaper to get my local guy to do it. Seeing as it's a task that I've not needed to do for the last 5 year's, it's not economical.
Add in I need to change a brake line and it makes sense to pass on this. But I will be sourcing all the parts to do the work
Thanks for the advice though, appreciate the efforts.
FZP
Estoril
PostPosted: Fri Nov 29, 2019 8:18 am    Post subject: Reply with quote
PC
PostPosted: Fri Nov 29, 2019 8:51 am    Post subject: Reply with quote
Tbf brakes are easy in theory, all simple until you get a problem like a nipple that won’t release etc etc, and all the more likely on a ten year old motor nooo
Your still a puff for not having a go though Grin
991 C2S PDK - X51 430 powerkit, Carbon GT2 folding buckets, PCCB, PDCC, PSE, Carrera S alloys, Sports design bodykit with ducktail and Alcantara steering wheel. If Carling did a 991S...
“Herman yellow, the last of the naturally aspirated. ”YKIMS"
Apparently other colours are available?
maldren
PostPosted: Fri Nov 29, 2019 9:07 am    Post subject: Reply with quote
Read the 996 threads on sticking nipples, you must use a 'T' bar rather than a ratchet to remove them so you don't 'bend' them as well as twisting. Using a good release agent (e.g. Plusgas - not WD40) the day before may help.
Good luck
Mike
Mike
FZP
Estoril
PostPosted: Fri Nov 29, 2019 9:08 am    Post subject: Reply with quote
Playing the long game🖕
PostPosted: Fri Nov 29, 2019 9:11 am    Post subject: Reply with quote
You could of course have a car in bits in the garage like mine at the moment Grin
