997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
ScoobyDoo555
PostPosted: Thu Nov 21, 2019 9:22 am    Post subject: Talk to me about water pumps...... Reply with quote
Mine's making some rather funny noises, so it's time to get it changed!
Looked on Design911 and there's a huge range of choice (based on wallet-size)....
https://www.design911.co.uk/fu/pt878_882_-cma81-cmo110-ct346/Porsche/996--911--1997-05/996-C4-3-4L-1997-08-01/Water---Coolant-Pumps/
Any recommendations - I'd prefer not to be bent over for the Porsche one though Very Happy
Dan Smile
Porsche 996 Carrera 4
Mods: "new car" magic tree. Pioneer F900bt, Alpine SPG10C2 x 4, JBL GTO 804 8" subs x 2, Shiny new rads & AC! Hartech-rebuilt engine & Sports exhaust
997 C2s discs. She stops quite nicely!
Martin996RSR
PostPosted: Thu Nov 21, 2019 9:58 am    Post subject: Reply with quote
I replaced mine out of fear of failure as I hadn't done it during my five years of ownership and I'd been warned it's a service item. I got a Pierburg metal impeller one from Euro Car Parts. I can't remember the price, but it wasn't crazy high.
dc2100k
PostPosted: Thu Nov 21, 2019 10:31 am    Post subject: Reply with quote
Pierburg water pump (with composite impeller) is what Porsche supply, available from other sources for approx. 50% of OPC prices. Comes with a gasket but it will be damaged in transit so buy a separate gasket from OPC or elsewhere for £10.
Might as well do your thermostat at the same time for £40-ish, standard or low temperature.
You'll need a pair of stainless hoseclamps, a 20-32mm for the pump and a 40-60mm for the stat.
While you've got it apart you might want to do the deflection/tensioner pulleys and belt too, these will cost you more than the pump and stat combined!
PostPosted: Thu Nov 21, 2019 12:18 pm    Post subject: Reply with quote
ECP do the genuine Porsche pump and its not expensive.
Mallone
PostPosted: Thu Nov 21, 2019 12:44 pm    Post subject: Reply with quote
I've just done this job on my 996. Autodoc were cheapest for the Pierburg pump by a fair amount - https://www.autodoc.co.uk/pierburg/965622
In the end I got the pump, low temp thermostat and gaskets for around £210 delivered.
Autodoc get a fair bit of stick online but, other than a fairly lengthy delivery time, were good for me.
Previously: 2000 996 C2, 2004 986 Boxster S
Current: 1999 996 C2
ScoobyDoo555
PostPosted: Thu Nov 21, 2019 1:13 pm    Post subject: Reply with quote
Thanks for the heads up Smile
The belt and tensioners were only done at the last service anyway. Thermostat was done when Hartech did the engine surgery too.
So it really is just the pump and gasket - everything else has been done.
I'll look out for the Pierburg one then Smile
Cheers!
Dan
Number21
PostPosted: Mon Nov 25, 2019 5:43 pm    Post subject: Reply with quote
The Pierburg pump is currently on sale on Autodoc too - 30% off.
ScoobyDoo555
PostPosted: Tue Nov 26, 2019 11:29 am    Post subject: Reply with quote
Cheers Smile
