997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
robrac
PostPosted: Mon Nov 18, 2019 11:19 pm    Post subject: Hello New to forum and going paranoid. Reply with quote
Hello
I have just joined the forum to see if its just me thats going paranoid, or are there any other 997.1 owners suffering the same condition as me. Its call Enginus Tappetus. (common symptoms know as tapping and bore scoring.)
Ok,,, I have a 2006 Carrera S full service history and 80k miles.
After reading forum posts, experts notes, Mr fixxit quotes and the like, I have gone paranoid about an imminent self destruction of my baby.
I would like an opinion from the sensible and experienced members.
Its 2000 miles since full service
Slight tapping sound when cold from area of cylinder 6, and it is slightly louder when warm.
Slight smoke on starting then not really seen again.
Drain oil, sump off and its virtually spotless. Oil has no obvious debris.
Cut open oil filter and "read it" and it too is as good as spotless
Plug out of cylinder 6 and it looks oily and cruddy. Piston crown looks damp.
My borescope shows a very small amount of oil sitting in the bore.
Some scoring on the upper part (12 oclock) looks very slight but its there.
So, my question is this......... what do I do at this point?
Do I just jump in and spend an inordinately large amount of hard earned cash or ...............................
Question
GMG
PostPosted: Tue Nov 19, 2019 6:44 am    Post subject: Reply with quote
...it's not looking good tbh...oily plug and piston on number 6 ?
Others on here will be able to offer an experience based view...so don't panic until you have an informed opinion...
PostPosted: Tue Nov 19, 2019 7:05 am    Post subject: Reply with quote
Personally id take the view its a high miles, high performance engine that will need a rebuild at some point. That point is probably some distance in the future, and until it actually does, continue as you are Dont know
991 C2S PDK - X51 430 Powerkit, Dynamic engine mounts, Carbon GT2 folding buckets, PCCB, PDCC, PSE, Carrera S alloys, Sports design bodykit with ducktail and Alcantara steering wheel. If Carling did a 991S...
“Herman yellow, the last of the naturally aspirated. ”YKIMS"
Simples ‘Yellow Porsche’s are the best’
FZP
Estoril
PostPosted: Tue Nov 19, 2019 7:29 am    Post subject: Reply with quote
I would get the engine inspected by a professional "with extensive experience in these engines". There have been misdiagnosed cases both ways previously, so save yourself the headache and go get checked.
RXP.
PostPosted: Tue Nov 19, 2019 7:35 am    Post subject: Reply with quote
Hey bud,
Tough situation to be in.
I would certainly wait for counsel from the likes of Demort and Baz and others that have been in a similar situation.
However if I was in your shoes i would perhaps consider the following before a rebuild.
How many miles do you do per annum?
How long is each journey? is it mixed driving?
You didint mention burn rate of the oil?
What condition is your AOS in?
Would you consider renewing plugs and filters (since they are already out?) and filling with millers nano?
Then monitor the situation over the next 2k miles?
RXP.
PostPosted: Tue Nov 19, 2019 7:38 am    Post subject: Reply with quote
Also how loud is the tapping? Definite change is db when idling when warmed up?
Rising with revs?
PostPosted: Tue Nov 19, 2019 8:03 am    Post subject: Reply with quote
Get a borescope done off someone who knows what they're on about, then decide on your next course of action from there.
NLW73
PostPosted: Tue Nov 19, 2019 8:34 am    Post subject: Reply with quote
agreed on the check and done professionally.
however my mates 997 had these symptoms and it was bore score on cylinder 6 and the tapping got louder which was eventually Piston slap due to over heating in that chamber and the piston going out of shape and tolerance.
its nothing in normal measurement terms but in a high performance engine you don't need much for things to start going amiss.
the scoring and noises will probably get worse over time.
997 C2s Schwarz
carcrazypop
PostPosted: Tue Nov 19, 2019 9:28 am    Post subject: Reply with quote
For your own sanity, I'd definitely get it checked out by a reputable Porsche Indy; they should allay your fears one way or the other, and if it's bad news, they'll be able to give you a way forward with costs.
If you're anywhere near Bisley, Woking, I'd recommend a visit to Porsche specialist Eporsh, they're great guys and won't take your pants down.
If you post up your rough location, I'm sure many on here will be able to make more recommendations.
Good luck.
2005/55 997 C2S Tip. Coupe.
MJK1
PostPosted: Tue Nov 19, 2019 12:31 pm    Post subject: Reply with quote
When you borescoped it did the top of any of the pistons look like this. If so this is likely to be the source of the knocking as it hits the underside of the cylinder head. If so the wear is already well advanced, allowing the piston to tilt in the cylinder. Unfortunately, it’ll then be a rebuild required.
 Filesize:  128.06 KB
 Viewed:  2771 Time(s)
Rhodris-dad
2015 Porsche 991 Carrera 4 GTS
PostPosted: Tue Nov 19, 2019 1:26 pm    Post subject: Re: Hello New to forum and going paranoid. Reply with quote
robrac wrote:
Hello
Question
You don't say whether the start up smoke is from one side of the exhaust. and whether on cold only start-up.
Is your oil consumption starting to increase?
If the above aren't too bad, you can still drive the car for ages until you are ready to bite the bullet.
I ran my 996 for 12 months until the water pump went. (80k too)
This is the worst case scenario.......as others have rightly said, get a proper diagnosis by someone qualified.
2015 991.1 C4GTS PDK
2010 997 C4S PDK sold
2003 996 C2 Tip sold
PostPosted: Tue Nov 19, 2019 2:11 pm    Post subject: Reply with quote
As already said get it scoped by someone like Hartech , and maybe send some oil for analysis, Millers oils offer this service then dependant on findings decide what to do . unlike IMS borescore is gradual ,I know someone who's still driving their car regularly 2years after borescore was first diagnosed. but assuming the worst and it is scored you have a number of options
Get just the one cylinder replaced thats the cheapest option
get just the 1 bank replaced
get a full rebuild using OE parts from someone other than Hartech this may be cheaper than using Hartech.
get a full Hartech rebuild using their new style liners
get a Harlech 3.9 conversion for added grins.
But start saving a bit each month and you May well have most of the money you need before it gets so bad it has to be sorted. And remember this lets assume you spend 12k on a rebuild and you have had the car a year or moorland plan to keep it another few years at least . the rebuild will cost you no more that what you would have lost on depreciation over the same period had you brought pretty much any other marque , the 997 wont have hardly depreciated at all in the same period . So its all relative as theres no such thing as free performance car ownership . Thumb Thumb
PostPosted: Tue Nov 19, 2019 2:47 pm    Post subject: Reply with quote
Have a read of this review , it may be worth considering a chat with these guys as they sound like an extremly well priced set up for rebuilds etc . you may end up getting a price for a fix that doesn't give you sleepless nights.
http://911uk.com/viewtopic.php?t=130564
robrac
PostPosted: Wed Nov 20, 2019 12:18 am    Post subject: Sanity starting to return Reply with quote
Thank you wise ones,
Rather ironically I am a retired engineer dealing with race engines for motorcycles.
I would not have hesitated in the past to bore a cylinder out and use a liner but reading the various posts, good and bad, I get the feeling to use liners would instantly render me liable to be flogged within an inch of my life with an old copy of exchange and mart.
Interesting about the lack of clearance of the head.
I will scope it again and will have a look at it tomorrow.
Many thanks Question
resigner
PostPosted: Wed Nov 20, 2019 12:43 pm    Post subject: Reply with quote
This. Can't say enough, someone who knows what they are looking at, is essentail
Whereabouts are you? Sure we can recommend someone trusted.....
Also, have to ask how much oil you use? Mine is doing about 1200 miles a litre, which is some, but nowhere near to much, and is on 87k miles. Borescope came back clean as a whistle recently, turned out that my new AOS was faulty, so we had another put in......
A good Indy is essential.
-- 997 --
PostPosted: Wed Nov 20, 2019 6:50 pm    Post subject: Reply with quote
When i bought my 997, approx year later i had the dreded tapping noise, the more i revved the engine faster the tapping up until a certain revs and then you wouldnt hear it, then on idle youd hear it, not condoning this and wouldnt do it but a close mate of mine did say give me your keys and then your car will go missing and ill give your keys back and give me a few days before you cry wolf. ( you know what i mean ) but i wouldnt this kind of thing!!
My car as well as others is show room condition, i decided to bite the bullet and save alittle each month and within 3 months i got the engine rebuild, top to bottom with all new everything!! And have to say the car is running as sweet as my rolex and dont miss a heartbeat!! Worth getting it built when time comes.. its a 997 why shouldnt you!!!!
J
robrac
PostPosted: Wed Nov 20, 2019 11:26 pm    Post subject: got it! Reply with quote
The borescoring rescope just showed very minor scoring in fact it was more of a discolouration rather than scratches)
BUT
there is a hairline crack in the crown of the piston in number 6.
Pressurising the cases proves.
So its to bits it must come
I will do all 6 while I am there Thumb
MJK1
PostPosted: Thu Nov 21, 2019 7:30 am    Post subject: Reply with quote
Sorry to hear that, will you do the work yourself and just send the blocks off to be relined?
PostPosted: Thu Nov 21, 2019 9:50 am    Post subject: Re: got it! Reply with quote
BUT
Thats very interesting , not great news but at least you know the reason and its not scored . now this may become the next thing 997.1 owners panic over Floor but in reality I would think its just one of those things that could happen to any car . at least you can build yourself a keeper and not worry any more
bazhart
Approved Trader
PostPosted: Thu Nov 21, 2019 10:54 am    Post subject: Reply with quote
As an engineer and with involvement in racing motorcycle engines - you should find commonality with me and my own experiences that would enable you to benefit more than most from the technical reports we have written and that can be accessed FOC by contacting our Sharon on admin@hartech.org
Just ask for details of the 4 main problems afflicting these engines but be warned it is long and technically detailed and is not for the faint hearted.
You may also be interested in another report available on our oversized engines.
It sounds like you could manage to strip and rebuild the engine yourself (or perhaps after someone else built the bottom end as it requires some special tools) an alternative we are happy to offer.
This section of the post has been moved by a 911uk moderator to a separate thread.
See --> Hartech Name and Shame Policy Discussion
Being probably the most well recommended repairer - we get some stick from competitors and trolls alike (especially over the slightly more expensive Nikasil plated aerospace liners we have fitted by their thousands without issues) and as a result - tend to steer away from posting details about the increasing number of engines we are getting in for a proper rebuilds after a failed one has already gone wrong built by a growing number of others trying to get in on the increasing level of business.
Of course we are not the only specialists capable of carrying out a reliable rebuild but you mentioned liners and I would specifically draw your attention to reading about them and seeing our photos of just how many of the growing number fitted elsewhere that we have had to replace with our own after cheaper rebuilds conducted elsewhere had failed prematurely.
If you read through our report you should benefit from it more than most although from the sound of your own experiences your own engine might well run on for some time - although as an engineer and competition engine builder - I would expect you to want it done right whether you do some of it yourself or not.
Baz
Click here for the Hartech
www.hartech.org
Goto page 1, 2, 3  Next
Page 1 of 3
