997 : 2004- 65
Boxster : 1997- 31
Macan : 2014- 6
Seventy Seven
PostPosted: Sun Nov 17, 2019 7:41 pm    Post subject: Rear mud guard delaminated Reply with quote
Hi all
Gave her a quick wash today and noticed that the mud guard at the bottom of the quarter panel, just in front of the rear wheel, has delaminated on one side.
Seemed to have some rusty metal behind it.... I cleared this out with a sharp tool, but the arch itself looks rust free...
I’ve done a search on here and DeMort seems to be the man in the know!
However, I’m unclear on how this is fixed and whether I need some sort of auto adhesive to get it back in place or do I need some clips which sit behind it, which may have rusted?
As usual, guidance appreciated.
Current:
997.2 C2S, Meteor Grey, PDK (with paddles), PSE, Sports Chrono, etc.... (2009)
Range Rover Evoque, Dynamic Lux, Black (2015)
PostPosted: Sun Nov 17, 2019 8:06 pm    Post subject: Reply with quote
Can you post a picture of the fault please so i know what i'm looking at .
Atm it just sounds like the base rubber strip has come loose .
If problems posting an image then just email it to me ..
De.Mort@virginmedia.com
Seventy Seven
PostPosted: Sun Nov 17, 2019 8:28 pm    Post subject: Reply with quote
DeMort - thanks so much. Email coming over shortly.
Current:
Milo72
PostPosted: Sun Nov 17, 2019 8:44 pm    Post subject: Reply with quote
You can buy a replacement on eBay for £45... left and right are on there.
997.1 C2S Tip.
 Filesize:  1.31 MB
 Viewed:  526 Time(s)
PostPosted: Sun Nov 17, 2019 8:53 pm    Post subject: Reply with quote
Images of the problem ..
 Filesize:  527.31 KB
 Viewed:  514 Time(s)
 Filesize:  714.11 KB
 Viewed:  514 Time(s)
 Filesize:  418.11 KB
 Viewed:  514 Time(s)
MR997
PostPosted: Sun Nov 17, 2019 9:12 pm    Post subject: Reply with quote
Had the same myself. As per deMort post I bought two replacements and they are straight forward to swap over. Be ready for the amount of crud trapped behind them.
Seventy Seven
PostPosted: Sun Nov 17, 2019 10:15 pm    Post subject: Reply with quote
Thanks all Thumb
Current:
-- 997 --
PostPosted: Tue Nov 19, 2019 9:05 am    Post subject: Reply with quote
I replaced both sides with new mud guards on mine and cleaned up the area where mud and crap gets lodged and when fitting all back i added alot of grease to the metal clip thats on the mud guard for future protection..
J
NLW73
PostPosted: Tue Nov 19, 2019 9:23 am    Post subject: Reply with quote
it happens and replaced mine too. the metal rusts and comes away from the plastic as the rivets corrode.
there is a lot of water and crap going in there and at pace/force at times.
take wheel off and get the car in the air as you need to get under neath for the torx screws and getting into position.
as said clear all the crap out and take off the first half of the rear arch lining to get to it. just be careful when getting the new item in and make sure you get the metal piece slid into the wheel arch to hold in.
997 C2s Schwarz
