997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
Creationblue
PostPosted: Sat Nov 16, 2019 12:37 pm    Post subject: Temp warning light Reply with quote
Just out for a drive this morning and noticed the warning light was flashing as I drove off. Stopped for 5mins and it was off for the journey, next start up it’s back on. Any advice from you good people?
'99 C2.1 Tip Vert
‘08 X3 3.0SD
'70 VW Westy Corvair T2
 Filesize:  88.38 KB
 Viewed:  638 Time(s)
kurlykris
PostPosted: Sat Nov 16, 2019 1:03 pm    Post subject: Reply with quote
According to my owners manual, the temperature light will flash if the coolant level is too low, or if there is a fault with the engine compartment blower fan Thumb
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
Lukec4s
PostPosted: Sat Nov 16, 2019 1:44 pm    Post subject: Reply with quote
Have you checked coolant level?
Ferrari 360
996 c4s
Clio 182 track car - it’s fun
Creationblue
PostPosted: Sat Nov 16, 2019 3:09 pm    Post subject: Reply with quote
T’was coolant level. Thanks for taking the effort to reply Thumb
'99 C2.1 Tip Vert
‘08 X3 3.0SD
ScoobyDoo555
PostPosted: Thu Nov 21, 2019 1:20 pm    Post subject: Reply with quote
Just to add to this - I'd also be querying why the coolant was low......
usual suspects are:
expansion tank (hairline crack)
faulty expansion tank cap (common fault)
Leaking radiators..... VERY common with all the crud that collects in the air dams.... (usually means new rads, and while you're there, do the AC condensors)
Mine was down to leaking rads....
Hope this helps
Dan
Porsche 996 Carrera 4
Mods: "new car" magic tree. Pioneer F900bt, Alpine SPG10C2 x 4, JBL GTO 804 8" subs x 2, Shiny new rads & AC! Hartech-rebuilt engine & Sports exhaust
997 C2s discs. She stops quite nicely!
Creationblue
PostPosted: Thu Nov 21, 2019 1:22 pm    Post subject: Reply with quote
I have a very slight leak on the OS rad Dan, will change them both next year
'99 C2.1 Tip Vert
‘08 X3 3.0SD
ScoobyDoo555
PostPosted: Thu Nov 21, 2019 1:37 pm    Post subject: Reply with quote
thumbsup
Bluebird911
PostPosted: Thu Nov 21, 2019 4:07 pm    Post subject: Reply with quote
Hi Creation,
If I were you I would get the rads changed sooner to make sure your engine is protectively cooled.
When there's a leak in the cooling system, the pressure of the liquid drops and so does the boiling point of the coolant/antifreeze. Cooling systems are pressurised to raise the boiling point of the fluid to provide effective cooling. If the boiling point is lower, the coolant around the cylinder walls and heads will bubble boil at the hot surface, so will not effectively transfer heat to the flowing coolant in these areas which could be damaging.
With the boiling point being lower, you will not be aware of it on your temp gauge as it will show 'normal' temp.
Particularly for high performance engines, it is important the cooling system is kept in the best condition. I also suspect that the cold weather could 'find out' any imperfections in your rads.
Creationblue
PostPosted: Fri Nov 22, 2019 8:25 am    Post subject: Reply with quote
Bluebird911 wrote:
Hi Creation,
Thanks for the input, great advise. My only reasoning is that I wont really be using the car now until the spring but will get the job done Thumb
'99 C2.1 Tip Vert
‘08 X3 3.0SD
