997 : 2004- 67
996 : 1997-2005 34
Cayenne : 2003- 7
Macan : 2014- 6
gav_sw20
PostPosted: Sat Nov 16, 2019 10:43 am    Post subject: New head-unit has lost sound from bass in doors Reply with quote
Finally got around to fitting a Sony Car Play unit, what a god-send to have proper satnav and a decent UI !!!
Anyway, I’ve plugged it all in and it all works fine however I seam to have lost all bass from the door speakers and everything sounds very “thin”.
I’ve played with the EQ on the HU with no joy. Does anyone have any ideas at all please?
Dealer suggest “make sure blue wire is connected” but as I’m using ISO connectors it’s just plug and play.
Car is a 2005 non-BOSE.
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Sat Nov 16, 2019 5:27 pm    Post subject: Reply with quote
Easy mistake to make. Everything you need to get it h hi king is in this excellent thread:
http://911uk.com/viewtopic.php?t=111204
My 997.1 C2 ownership thread: http://911uk.com/viewtopic.php?t=134228
gav_sw20
PostPosted: Sun Nov 17, 2019 10:39 am    Post subject: Reply with quote
Awesome, thanks so much for the link.
Had a heck of a job moving pins in the ISO blocks so will just pop a bullet on I think.
Thanks again Thumb
PostPosted: Sun Nov 17, 2019 3:13 pm    Post subject: Reply with quote
Hope your now sorted mate Thumb Thumb As the actual Porsche speakers are not bad I also ended up fitted an rainbow beats amp instead of the stock non Bose amp and that really improved the sound quality the OE amp is very poor ,and its a fairly easy switch , I put the amp in the space in the trunk where all the now not required Nav dvd. etc was Thumb Thumb
gav_sw20
PostPosted: Mon Nov 18, 2019 6:30 pm    Post subject: Reply with quote
Have had a play with this and no joy Sad
I’m assuming this (black/red cable) is from the amplifier - this was in the black ISO but I pulled it out).
And this (blue/white cable) is what I believe to be the power aerial cable from the new head-unit. It had a bullet connector on it but swapped it as I had no females.
Anyway, I’ve connected them up and still got no sound from the other speakers Sad
Any ideas at all please?
 Filesize:  78.44 KB
 Viewed:  431 Time(s)
 Filesize:  1.82 MB
 Viewed:  432 Time(s)
resigner
PostPosted: Mon Nov 18, 2019 6:46 pm    Post subject: Reply with quote
Have you connected the amp power on to the electric aerial on? It uses that to tell the amp to power up. Without that connected, it doesn't turn the amp on, and you get no bass speakers. Pretty sure the amp only powers those......
resigner
PostPosted: Mon Nov 18, 2019 6:47 pm    Post subject: Reply with quote
Should of said as wel, was the amp working before you changed the head unit? They are notorious for packing up and again, no bass.... They can be fixed though.
PostPosted: Mon Nov 18, 2019 7:04 pm    Post subject: Reply with quote
Thats exactily what happened to mine and why I went with the rainbow beats amp. they just stop no warning and as resigner says no bass well a tiny bit of bass from the upper door speakers . Thumb no I am wondering if the OPs amp is shot.
gav_sw20
PostPosted: Mon Nov 18, 2019 8:43 pm    Post subject: Reply with quote
Thanks for the responses.
Amp definitely worked up until I removed it last week.
I will remove the head-unit again and test that there’s some voltage coming from the blue/white cable with my multi-meter (as I’m assuming there should be something coming out to tell the amp to turn on).
I’ll also trace the wire back to confirm it’s the correct one.
gav_sw20
PostPosted: Mon Nov 18, 2019 9:19 pm    Post subject: Reply with quote
I’ve connected the two wires pictured above together. My understanding is:
- Black/red=amp power
- Blue/white=electrical aerial on
