997 : 2004- 65
Boxster : 1997- 31
Macan : 2014- 6
Lee997
PostPosted: Sat Nov 16, 2019 9:42 am    Post subject: 997.1 spoiler disable! Reply with quote
Planning on fitting a fixed spoiler this weekend! Although I have access to a Launch diagnostic pad I’m not sure where to look.
So if I don’t disable in the cars electronics until I get to my indi Monday will it cause an issue apart from a warning light?
What will the car do ? (Wheels fall off ect-?)
Lee.
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Sat Nov 16, 2019 6:43 pm    Post subject: Reply with quote
Hi Lee, think I replied on fb but incase not,
If you fit the fixed spoiler it'll only generate an error if you
1. Hit the spoiler button
2. Go over c. 73mph
3. If engine compartment temp gets High - unlikely in winter and on a short trip
Indy can code for fixed spoiler, should be in a couple of spots iirc, rear control unit for auto lift, think front cu to turn off the button.
How did the fit go?
Hth
Lee997
PostPosted: Sun Nov 17, 2019 2:03 pm    Post subject: Reply with quote
2. Go over c. 73mph
How did the fit go?
Hth
Hi jonno, thanks for info, gives me an idea where to look.
Don’t think cooling will be an issue as fixed spoiler has the two air scoops directing air into engine bay and it keeps the original fan !
Didn’t get it fitted at weekend going to do it during the week.
Lee.
Blooders
PostPosted: Sun Nov 17, 2019 5:20 pm    Post subject: Reply with quote
Hi Lee. I fitted a Duck tail fixed spoiler and I used a Foxwell NT520 pro to disable the spoiler as the alarm was annoying when going over 73mph and then alarms when you slow down again!
Not sure of your location but I am near Peterborough if you want to use my Foxwell. Cheers Mark
2004 997 Manual C2S
Lee997
PostPosted: Mon Nov 18, 2019 9:48 pm    Post subject: Reply with quote
Thanks Mark, very kind offer, however I have around £1500 worth of Launch diagnostic m/c here with me but unsure we’re to find the option!
Spoilers fitted now and just the journey home was enough to annoy the hell out of me!
Lee.
PostPosted: Tue Nov 19, 2019 7:18 pm    Post subject: Reply with quote
Off hand i can't remember where it is but i would start with the rear end control unit coding as thats the logical place .. if not have a look in gateway.
btw if possible could you add what car you have in a signature .. Gen 1 and 2 are pretty different when it comes to things like this Thumb
