997 : 2004- 65
Boxster : 1997- 31
Macan : 2014- 6
Lee997
PostPosted: Wed Nov 13, 2019 11:27 am    Post subject: Oil switch change! Reply with quote
Hi I all, going to change out my suspect oil pressure switch at weekend.
I’m up the workshop at the moment and don’t have car with me.
I know the new switch I got from design 911 is 19mm on the nut but not sure what the original one is!
Can someone advise please as I need to find some Crows feet!
Lee.
timbo1811
PostPosted: Wed Nov 13, 2019 2:35 pm    Post subject: Reply with quote
Hi Lee, I need to do this too, fairly sure its 19mm, crows feet available on ebay, you will probably need 3/8 wobble extensions too according to the research I did. I have tried to do mine but bottled it after I ran the car off the ramps (thats another story) so I would be very interested to know how you get on.
Videos I watched showed them doing it from underneath the car, I don't think you can get enough leverage form above.
Lotus Elan, Lotus Elan +2, MGA Mk11, TR4, 230 Compressor, 320 coupe, 944, Boxster 2.7, 997.1(current), VFR 1200, CBR 1100 Blackbird
Lee997
PostPosted: Wed Nov 13, 2019 7:12 pm    Post subject: Reply with quote
Hi Timbo, I’ve found a set of crows feet ranging upto 24mm at the workshop so I’m covered!
Gotta love Youtube! Looks a straight forward job, we have a decent car lift so hoping to get time to attempt this Friday. Looks a straight forward job.
I’ll let you know how it goes!
Lee.
PostPosted: Wed Nov 13, 2019 7:16 pm    Post subject: Reply with quote
19mm crows foot spanner from above .. it needs to be the flat type and not the ring type .. it can also be done from below with a bent spanner .
sensor is faulty if you turn on the ignition only and it reads anything other than 0 bar .
MarkGolf
PostPosted: Thu Nov 14, 2019 9:18 am    Post subject: Reply with quote
Did mine in 10 mins or with a crows foot, dead easy job
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
Lee997
PostPosted: Fri Nov 15, 2019 5:17 pm    Post subject: Oil switch. Reply with quote
Oil switch changed no dramas, took longer to grind down the crows foot so it would fit between the block and the switch body.
Changed my rear roll bar bushes while I was under there.
Switch works properly now and getting sensible readings.
Almost ready for the road trip to Stuttgart at the end of this month!
