997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
PostPosted: Thu Nov 28, 2019 8:25 pm    Post subject: Reply with quote
The sensor will have a signal wire going to the control unit .. you connect a scope to this wire and see what values it reads .
A PWM signal will be between 10 volts and about 2 volts with anything above or below that being a short circuit to either earth or battery positive .
Whilst we have no set values for what it should be we can still get an idea .. the value will fluctuate in a smooth manner up and down as the car is driven .
With no values from Porsche as to what's correct then you are looking for something that's not right .. ie a constant speed and the value jumping up and down ... a defective sensor in other words .
Indy Mechanic .
wjk_glynn
PostPosted: Thu Nov 28, 2019 10:40 pm    Post subject: Re: 997.2 Targa 4s PDK issues Reply with quote
cardy wrote:
...Here in Canada...
FYI that if you want feedback from Canadian and/or US based 997.2 owners, take a look at the Rennlist 997 board: https://rennlist.com/forums/997-forum-113/
Lot's of PDK related threads there...
Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers
cardy
PostPosted: Fri Nov 29, 2019 9:52 pm    Post subject: Reply with quote
I've seen the North American stuff, was looking for other ideas
Thanks for the link though
PostPosted: Sat Nov 30, 2019 5:49 pm    Post subject: Reply with quote
I've done a little more digging , best guess is it's the distance sensor as thats all thats listed on the shift rods .. it doesn't appear on the parts list and it does look like a total strip down of the box to replace it ...
Interesting the voltage is 5 volts so on a PWM scope check i would assume the signal will be between 1 and 4 volts and a static signal after it has shifted the rod from end to end .
Indy Mechanic .
 Filesize:  258.85 KB
 Viewed:  582 Time(s)
wjk_glynn
PostPosted: Mon Dec 09, 2019 12:02 am    Post subject: Reply with quote
Related discussion...
https://rennlist.com/forums/997-forum/1172826-guide-to-repairing-a-pdk-transmission.html
Karl.
Goto page Previous  1, 2
Page 2 of 2
