Author |
Message |
dc2100k Newbie
Posted: Tue Nov 12, 2019 2:59 pm Post subject: Best Trolley Jack for 996
Hi All,
I'm fed up using a scissor jack to get my car up on axle stands and I'm looking to get a decent trolley jack for my 996 principally, but no doubt it will also get used for my Landcruiser Amazon (2.8 tonnes!) and the wife's 3-series. Anyone got any recommendations?
I was looking at something like the many 1.5 tonne racing jacks available for about £100:
https://www.google.com/search?client=firefox-b-d&q=1.5+tonne+racing+jack
or maybe the 2.5 tonne versions for about £130, which might be more suitable if I ever lift the Toyota.
The alternative is a chap near me is selling a 3 tonne Snap-on Blue Point jack for £150 but I'm not sure I need something so large and that the size/weight (36kg) will be a hindrance in my single garage!
Anyone got any good experience on this subject?
Thefinn Suzuka
Posted: Tue Nov 12, 2019 3:04 pm Post subject:
check out SGS Engineering they should have something that suits your needs and their kit is good quality stuff. So far I have two of their tool chests and 1 jack but i think much more might be on the cards in the future.
www.sgs-engineering.com/ _________________ 997.1 C4S CAB
peterg1955 Silverstone
Luddite Nürburgring
dc2100k Newbie
Posted: Tue Nov 12, 2019 3:22 pm Post subject:
Thanks for the recommendations, I will check SGS out.
Does anyone know how low-entry the jack needs to be to clear GT3 geometry? My 996 is standard but I wouldn’t rule out going to M030 or GT3 spec in the future.
Hertsdriver Nürburgring
Joined: 12 Nov 2018 Posts: 476 Location: Hertfordshire/London
2004 Porsche 997 Carrera 2
dc2100k Newbie
Posted: Tue Nov 12, 2019 4:30 pm Post subject:
Thanks Hertsdriver, that jack does look sensible! I think the main advantage of the 2.5 tonne racing jacks is that it lifts up to 450+mm, as opposed to 330-360mm of most of the others. I don't know how much of an issue this is with a 996 but 330mm would only just reach the jacking point of the Landcruiser and wouldn't lift the wheels off the ground.
I understand there is a place on the rear engine casing where it is safe to lift the rear and get the axle stands under the jacking points, as opposed to lifting by the jacking points and putting the axle stands on the suspension mounting points. Is this correct?
Kbald Monza
Joined: 11 May 2018 Posts: 191 Location: West Yorkshire
Posted: Tue Nov 12, 2019 7:45 pm Post subject:
I use two jacks 1) a cheapo for lifting the sides ie on the jacking points to get 1 wheel off and 2) a 3 tonne high lift sgs one where I can jack the whole front or back to get either my 3 or sgs 6 tonne axle stands under, but I need to run it onto my ramps first to give clearance to get the big one under. I can then get the Porsche up in the air how I want it dependent on the job but can use the big one on my range rover as well. If I were to lift a landcruiser I would be going as big as I can for a jack as it's a beast to lift quite similar to the range rover. All in all I spent circa £160 for the 2 jacks and car ramps. About £80 extra for both sets of axle stands, but they all get used across multiple vehicles.
In regards to jacking the rear there is a point on the subframe that works perfect to jack the car and then under the toe arms with axle stands. On the front can't remember off hand but there are guides on here and I use axle stands with rubber pucks on at the reinforced point shown on the pelican parts 101 projects book and site. _________________ 2000 Carrera C4 Cabrio Tiptronic
Disco Estoril
Joined: 13 May 2008 Posts: 3978 Location: Hertfordshire
2010 Porsche 997 GT3
Posted: Fri Nov 15, 2019 12:30 pm Post subject:
Hertsdriver wrote: | Given that a 996/997 have a curb weight of under 1500kg, buying a 2.5 tonne jack is a bit overkill in my eyes, but if you want to spend £130 go for it! |
This is a sound argument as long as you only ever use it on your 911. But if you have a 1.5 tonne jack and if you find yourself needing to lift something like... lets say... a 3 series cabriolet and wistfully just use the jack that you have... Yeah - I am going to be buying twice after that one...
 _________________ Colin
Black 997 GT3 3.8 CS - Acquired for the 2012 season and beyond
Black 996 GT3 Mk2 - Gone, but will never be forgotten
maldren Suzuka
Posted: Fri Nov 15, 2019 1:43 pm Post subject:
I have a Clarke (machine mart) jack that was recommended by AutoExpress, it's reasonably low entry, cheap and fine.
However when I was at CG, I met another owner, Ian, who recommended a Costco 'racing' jack' at about £100. I bought one and never use the old jack any more. It's rated at something like 3 tons and it weighs a lot itself so why do I like it? I has a long reach (goes well under to get to suspension points), it has a very low entry and raises very high with only a few strokes. _________________ Mike
sp1ke Trainee
Thefinn Suzuka
Posted: Fri Nov 15, 2019 2:49 pm Post subject:
If you do think about one of the cheap ones with the plastic hand to carry it watch out! I had one once and as i carried the jack over the car one day the handle broke in my hand and the falling jack left two rather nice large dents on my car where the wheels hit. lesson learned as the repair bill could have bought me several decent jacks to start with.  _________________ 997.1 C4S CAB
wasz Sepang
1999 Porsche 996 Carrera 2
Posted: Mon Nov 18, 2019 11:43 am Post subject:
You need two jacks
I have the lightweight arcan alloy one for the 911 and other cars. Easy to carry and much more usable than a heavy jack.
And a big heavy steel 3 tonne jack for 4x4s - a bit redundant now as I don't have one, but I do use it when I need two jacks, e.g. take the weight of the engine when removing mounts etc.
I wouldn't trust the light jack on a 4x4 and equally the heavy jack is not low entry and too heavy to be dragging around.
Actually I have a third, an Aldi cheapy from years ago that I never use since getting the arcan. _________________ My special order MY99 Vesuvious Charcoal 996 | Clutch, Fly RMS IMS AOS Job |
dc2100k Newbie
Posted: Mon Nov 18, 2019 2:36 pm Post subject:
Hi wasz, that's the sort of reply I wasn't looking for
I have found an alternative workaround in the meantime using a combination of a scissor jack and the bottle jack that came with the Landcruiser to get the 996 to a good height for the axle stands without much fuss.
Once I have recovered (financially!) from the present round of servicing expenditure I will look to get a nice alloy jack, probably 2.5T.
Thanks all for the advice.
TV8 Newbie
Posted: Mon Nov 18, 2019 7:16 pm Post subject:
Costco sell a couple of good quality jacks that are low enough. https://www.costco.co.uk/Tyres-Automotive/Automotive/Trolley-Jacks-Axle-Stands/Arcan-2750kg-3-Ton-Steel-Service-Jack-Model-XL2750EU/p/254971
There is a 2 ton rated one available in warehouses and its very good. I have one of those and a lighter load ally one from machine mart which is similar money to the Arcan one but not close on quality. If you get the 3 ton one, be advised, it is very very heavy to move around!
I had my new car up in the air this weekend and I was very surprised at how rigid the coupe is, especially when jacking at the back! The car was on the jack and only the diagonally opposite front wheel was in contact with the ground!!
It was a good opportunity to use a second jack and get the car properly on axle stands and have a check over underneath.
yo_clarkie Spa-Francorchamps
Posted: Mon Nov 18, 2019 11:24 pm Post subject:
And once you have one, go buy a Ice Hockey Puck to put on the jacks lifting pad.
Its the thing that works perfectly _________________ 2003 996 C4S in Silver, Manual, PSE, new in UK, now in New Zealand
Mods so far: K&N induction, Kenwood Navigation and AMP, LN Engineering IMS, fully replaced suspension with new factory parts
maldren Suzuka
Posted: Tue Nov 19, 2019 9:09 am Post subject:
It's the Arcan lift that I have, it was £100 when I bought it, perhaps the fall in the £/$ has increased the price or maybe it was a special offer. _________________ Mike
Rosselder83 Trainee
rabbitstew Hockenheim
Posted: Thu Nov 21, 2019 10:01 am Post subject:
I use a halfords low profile one, got it a good few years back when the had some 50% sale on, so it cost hardly anything. _________________ 2008 997.1 Turbo Manual - 585whp thanks to do88 & 9e
UncleP Silverstone
Posted: Wed Dec 04, 2019 4:23 pm Post subject:
I use a 2 tonne low profile from machine mart. It's ideal because the jacking lever is on a pivot which rotates it left or right so it's ideal for jacking cars up in a garage where you might struggle with these monster levered 3t jobs.
Another point on the weight thing. people seem to be going total overkill with the weight. If you lift 1 side or 1 end of a 996 you aren't lifting 1500kg. One side or end is still on the ground. Similar point on axle stands. 2t rated stands are PER STAND. Jack up one side of end and stick it on stands, each stand isn't carrying 1500kg.
