997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
NedHan79
PostPosted: Tue Nov 12, 2019 6:53 am    Post subject: Solid rear subframe bushes Reply with quote
I’m planning on stripping the rear subframe as part of my overhaul. On a google last night I see design 911 do some solid bushes which change the height. What they’re saying is that on a lowered car it will help bring the geometry back into spec.
Has anyone gone this way?
Will this do away with the need for adjustable toe arms?
Also these are £200 for a very simple looking bush and washer. Has anyone had these made?
As usual, all help and pointers welcome
#modified996mk1
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Nov 12, 2019 7:07 am    Post subject: Reply with quote
I think I ended up with the elephant racing ones. You are right that there isn't a lot to them. My understanding is thatbit raises the subframe around 1/2" to the same as the GT3. The hardest part of fitting then was pushing out the old bushes from the subframe. I haven't had my geometry done yet so can't comment on that aspect, but I'm running adjustable arns anyway.
911munKy
PostPosted: Tue Nov 12, 2019 8:12 am    Post subject: Reply with quote
I bought adjustable toe arms for around £160 so I can’t see the point in bushes costing more Dont know
2000 C2 996
NedHan79
PostPosted: Tue Nov 12, 2019 8:33 am    Post subject: Reply with quote
Thanks mc. Should’ve known you’d be down that road. Looks very simple but I also see polybushes aren’t expensive but it’s the height that has me interested.
911 munky. It’s not so I don’t have to get adjustable toe arms as such, it’s more that the original bushes will be well past their best and I’ll have it all out at some stage here. Saying that, I’d say if I go the solid bush route, I’ll probably not bother with adjustable arms as I’m only on lowering springs on my m030 shocks.
#modified996mk1
911munKy
PostPosted: Tue Nov 12, 2019 9:56 am    Post subject: Reply with quote
Same as me then, I used Eibach -30mm springs with my M030 shocks but they seemed lower than others and I needed 10mm spring perch spacers and adjustable toe arms to get the car to X74 geo spec. Anyway all sorted now.
2000 C2 996
NedHan79
PostPosted: Tue Nov 12, 2019 10:20 am    Post subject: Reply with quote
Sounds good. Is this x74 spec all it’s cracked up to be?
I don’t really know what to expect
#modified996mk1
NedHan79
PostPosted: Fri Nov 22, 2019 11:34 am    Post subject: Reply with quote
I don’t suppose by any chance you haven’t fitted them yet mc? Bit of a long shot but I was hoping to get my hands on some and get a few sets made for the good of all on here. Can’t be too much to make
#modified996mk1
MisterCorn
PostPosted: Fri Nov 22, 2019 1:32 pm    Post subject: Reply with quote
Sorry, already fitted.
NedHan79
PostPosted: Fri Nov 22, 2019 1:58 pm    Post subject: Reply with quote
No problem. If I can get the correct sizes I’ll probably get a few sets made up if anyone else is interested
#modified996mk1
Shalmaneser
PostPosted: Fri Nov 22, 2019 2:38 pm    Post subject: Reply with quote
This picture illustrates it rather well:
The angle of the lower links is ideally horizontal at rest - when you lower a car these can end up in a sub-optimal position which can lead to issues with roll centre. Pulling the subframe up higher can help to counteract this.
Plus being solid removes any uncontrolled movement at the expense of some NVH.
NedHan79
PostPosted: Fri Nov 22, 2019 2:41 pm    Post subject: Reply with quote
Yip. Saw that. I might end up with adjustable arms but the standard bushes have had it anyway so I may as well start with what it actually needs
#modified996mk1
Toml
PostPosted: Fri Nov 22, 2019 4:15 pm    Post subject: Reply with quote
Have you seen that power flex do subframe bushes? No mention of them changing height but I wonder if the washers shown will do that? Price wise though I guess they won't be far off the elephant racing ones.
https://www.powerflex.co.uk/products/996+%281997-2005%29-525/1.html
NedHan79
PostPosted: Fri Nov 22, 2019 11:52 pm    Post subject: Reply with quote
Hi tommi. I don’t think poly will change the height any. I will however need to rebush a lot of it and I’d say polybush is the way I’ll go.
#modified996mk1
Toml
PostPosted: Sat Nov 23, 2019 9:18 am    Post subject: Reply with quote
You might ask them to design them for a height change. Seems they are very open to feedback since they changed the design of the gearbox bush after feedback from Alex on here I think
NedHan79
PostPosted: Sat Nov 23, 2019 3:09 pm    Post subject: Reply with quote
Polybushes are very easy to make if you can be bothered to make a mould. On that note I might have a stab at it for the dog bones and others. Big advantage is you can choose the compound you want and make them for peanuts when the moulds are right
#modified996mk1
